to my log.
So I've had a Lian Li TYR X-2000 for about 2 years now.
I was running a V1 zalman reserator with an upgraded pump(from day 1) and a 120 and 240 external rad.
Hardware is mostly 2 years old, hasn't been any games worth upgrading for lately.
I try to skip a gpu gen, got 4870s now, so the 6870s are looking good
I said I'd never dremel it, then one day during a forum discussion a few months ago about case grommet holes, i decided F*%$ it!
Not long after i saw the new HWL SR1 560, then found Aquacomputer.
A few couriers, $$s and cut off wheels later, here we are.
Ive just recieved my (maybe) last delivery and time to install.
I recently decided to change from 240/120 rads for exhaust to 280/140 to match the 560 intake.
So i have a minor issue with the hole on the top panel now being too big.
I made it big enough to drop the rad and fans straight in, with a radgrill on top. but the hole is now wider than 140mm fan holes.
Trying to get my hands on a 280 radgrill to sort it, but i may just fab something.
Still need to decide on best option and drill mounts and trim hole a bit.
Anyway, finally found the mini usb adaptor for sony camera , **&$#sony*$&%non*&$standard&*%(plugs*&#%@!!!!!*
So heres some pics of where I'm up to,
still in progress so ideas are welcome.
It may look like a pretty plain build atm,
but the last 2 pics give a clue as to what it may look like when finished...
Hardware
Asus Maximus II Formula
E8600 3.33ghz
Corsair Dominator 4GB
2x Saphire Radeon 4870 crossfire
6x 1TB Seagate 7200.12
Corsair HX1000
WC
HWL SR1 560/280/140
Enermax UCTB14 Silence 750rpm/45cfm/15dba 7x
AC Aquastream XT Ultra (might add a second..thoughts?)
AC Aquatube nickel res
AC Aquaero
AC Multiswitch
AC Flow sensor
AC Filter
AC Fillport
AC inline temps sensors 4x
BP Shinning silver fittings (asst 45/90/L/Q/etc)
BP True Silver 1/2 id CC5 32x
Tygon 3603 1/2id 8m
EK Supreme HF Nickel
EK Asus Mofset 3a 2x
EK Asus NB/SB1
EK NB S-Max
EK FC4870 CF 2x
to my log.
to my wallet.
