ASUS P5Q3 Deluxe discussion
Hey people, lets start a new thread for the ddr3 board, as it acts very different from the ddr2 board, the first board i got was defective, the 2nd board i got had scratches on it, the 3rd one will be here shortly..............please share your settings and experiences with this board :up:
Sorry mod can you change the title to P5Q3 please, sorry about that.
This is important, please read and post me the info
Gentlemen
How many of you with the P5Q3 deluxe and OCZ memory are running Western Digital hdd's?
I run Raptors here, i see one of 2 of you run similar.
Please post up if you have WD drives.
Me too, and with 2G kit...
(also posted on http://www.ocztechnologyforum.com/fo...d.php?p=278514)
Hello,
I've got an Asus P5Q3 with an OCZ3P16002GK kit and Q9450 processor, and could only install a system and boot under Splashtop/Linux/Windows by setting DDR3-800 in the BIOS. All other settings I tried with DDR3-1333 (voltage, timings, skew) were unstable. I tried all available BIOSes, even 801 one.
Today I decided to do some tests. Now I've got Prime95 running stable for half an hour (self-test 1024K passed) with the following BIOS settings in System Performance Settings :
DRAM Frequency : DDR3-1333MHz
DRAM Static Read Control : Disabled
DRAM Dynamic Write Control : Disabled
DRAM Read Training : Disabled
DRAM Write Training : Disabled
MEM. OC Charger : Enabled
Ai Clock Twister : Lighter
DRAM Voltage : 1.80
NB Voltage : 1.20
All other settings : Auto
The OCZ kit is on orange slots, the others aren't populated.
Some settings may be useless, but now it's stable I will try setting back each parameter one by one to Auto and lowering DRAM Voltage later, and test stability.
At the time of this writing, Self-test 8K passed.
Hope this helps...
Another thing : SPD says this RAM is PC3-10700... shouldn't it be PC3-12800 ? Btw, when I bought this, the vendor said "DDR3-1600".
Thanks,
Olivier
