anyone got some advice on settings for an e8500 and g.Skill PC8000?
i had gtl settings figured wrong :rofl:
but it worked for me :rofl: since i set cpuvtt higher than cpu core
my sttings for 500fsb
cpu 1.52v
xtraad 0
vdmm 2.27
sb 1.76
nb 1.6
cpuvtt 1.53
vdroop dissabled
cvc 3.45
buffer strong
slew weak
ennabled
gtl1 105
gtl2 105
gtl3 111
Well i wasn't satisfied with my high pwn and nb temps so i reversed the tornado on my HR-03 GT to blow at the nb heatsink and was able to ziptie an old Thermaltake fan(from a Volcano6cu) over the mosfet heatsink. Dropped my load temps down at least 12C on both and my videocard temp still stays under 40C while gaming. :) I tried another method before this and ended up messing my nb heatsink up. It looks like i've had this mobo for a while now. :(
I asked this question before but didn't get an answer. What's the max voltage i should run this X3210 for daily use on air? I know the Intel specs say 1.37v and that is where i'm at now. This chip can go higher with more volts but i'd like to keep it for a while and don't want to kill it.
zsamz_, what 4 sticks are you running @1200MHz? I have D9's and i'm not sure where i should draw the line for the voltage. I got them running at 2.19(in bios) and i know alot of people have had them die with anything more than that.
Most people consider 5-10% safe. Going from 1.37v, that means 1.44 to 1.5v.
However, of equal improtance is the cooling. I admit I am not as familiar with Xeon specs, but I can imagine that since it is a server-class CPU it's meant to handle a bit more than a consumer grade chip. Just make sure that whatever voltage you decide to put into it, that it stays well under the rated temps spec'ed by Intel for your CPU.
Hey guys I just sold my Q6600 (that could get into 9*450) looking to buy a low VID version of the Q6600 (1.20v or 1.21v max).
But now that I know those Q9450 will be out soon what do you guys think? I really don't know much about the 'overclokability' on those new Cpu's as for the Q6600 it can well hit the 70% OC mark.
Will I be able to run the Q9450 stable 8*500 in my rig to achieve 4000Mhz or at least set that goal or that's out of the question?
Also It would cost me only $85 to get the Q9450 instead of a Q6600 with a 1.20vid.
I'm pretty sure that 90% of them dying is due to lack of contact between the stock heatsink and the chips... Browse this Thread and you'll see that they come of the chips in very little time of use.
Combine that a 2.2v-2.39v = death in about few months without the heatsinks to cool them.
If the heatspreaders come off like mine did the extra cooling will do no good. I also have extra cooling for them.
What I did was take 2 vs 1gb out of the case and use these on the other 2:
http://www.xtremesystems.org/forums/...postcount=2106
The problem with that solution is that obliviously they look ridiculous and the 4 gigas wont fit there together.
So I'm thinking about using a 5% arctic epoxi + 95% arctic silver mix on the chips and re-attach to the sinks, but the warranty would go bye bye I guess.
Another think to consider is to use 3rd party hs and preserve warranty.
4 sticks are ballistix 8500s i only need 2.1v"real" to go 1200mhz
i got 2 amd cpu fans blowin on em:D they never get even warm
i retired my ballistix for now "only gonna use them on high fsb
since i not gaming now i put back my mushkins in they only like cas 4 i cant even run them cas 5 over 1000mhz
i need 2.22v for this
Active cooling a must http://i4memory.com/showthread.php?t=5508 :)
i thought i'd repost these its based on dfip35 but verry helpfull
first one is CPU And Northbridge GTL Default Settings
second one is Northbridge GTL Default Settings
@zsamz_: but that is based on 65nm procs right?
Got my board Finally.
I am trying to put this in an antec 900 case and with a 120 Extreme and the little NB and fans I am out of room.
I can't mount the TRUE facing out the back its heat pipes hit the NB so I face it up but I can't get a fan on it and the NB too.
ok I Should have gone water...DUMB but now with a $60 doorstop I need help what and how should I mount all this stuff ?
thanks for any help
ps put the video in slot 3 ?
crazyea:
i want to apologize for my conduct and swinging insults your way...you didn't deserve it and i really feel bad about it...it wasn't very christian of me to act like that...i shouldn't have taken it that personally about the way you indicate a post is not factually correct...i was wong!
PEACE:) to you, my friend!
Can you post a pic of your board in the case? I would think there should be room between the NB and the TRUE. My guess is either that the NB HS was installed with the fins near the top or the fan is sitting down too low on the TRUE. If the latter is the case, is there a way to slide the fan up over the base of the NB HS like on my Noctua NH-U12P?
