Originally Posted by
DarthShader
Thank you for confirming, that the 6970 was not meant to fight the 580. :)
You should say to that EVGA. They listened to you with their guarantees, maybe they will agree with you here too and drop their dual card. ;)
Joking aside, I am not sure I can agree with you. Part of what makes us currently percieve dual cards as useless is the 32nm cancelation/ 28nm slips which made the single cards come close to the 300W wall. At that point SLI/corssfire makes for both better performance and easier cooling. If nVidia was able to, I can guarantee they'd have a dual card already, 100%.
A dual card can still have it's uses. In the ultra high-end, it's easier to do quadfire with two dual-cards. In the lower regions, depending on pricing, it might be cheaper to get a cheap P67 board that doesn't have two at least x8 slots, a 2500K and a dual card, than an expensive board and two regular cards. There's also the mATX and ITX form factor, where Crossfire/SLI is troublesome or impossible. See Sugo SG07 for example. Finally, there are OpenCL/CUDA applications, where packing twice as much chips in the same space is going to give moar perforamnce etc.
