first venice and now this s7? good job!
Whoops--almost forgot about this. Here's a run at default for me. I think I must be doing something wrong. Not sure how strongly effected by ECC this is, either. I run with ECC set to maximum protection. Come to think of it, this may be with underclocked memory. Let me check...
http://www.pcrpg.org/pics/computer/opty2427/stream.png
Default: 12x2200, DDR2-800, ECC Off...not a whole lot better
http://www.pcrpg.org/pics/computer/opty2427/stream2.png
Ohh thanks, those results look like single socket vs. dual channel. :)
Do you really have all four channels populated and ran with 12 threads? Beside that with six cores sharing two channels this benchmark is heavi imc speed limited. My 955be and also the AII 240 and 250 get best results if the nb runs one notch below the cpu. I hit a limit once the nb speed reaches 2xmem speed, so the optimum with ddr3 1333 is 2.8GHz/2.6GHz cpu/nb. If it's the same with DDR2 you should not be limited by the stock nb speed however since it's already above 1.6GHz.
Beside that I think only this ES has unlocked multis and voltages and the retail chips will be locked so using k10stats or similar to modify these settings on the chips msr register will not work and oc capability will be limited by the max possible ref HT the boards will offer.
@s7: I'm curious, what msr register did you modify? Was it the controll register or the p-state-0 register?
FASN8ing :up: (times 3).
I really hope some of these new G34/C32 boards will be made with "XS
people" in mind.
Definitely sounds like there is a 2P market here.
Many thanks for sharing S7. :clap:
can you run 3dmark 06? :)
Particle, Maybe it has something to do with the chipset difference?
So someone finally noticed...
http://www.fudzilla.com/content/view/15552/1/
Didn't they get it wrong though? this is 2x CPUs right? And all of the benches were run with 2 CPUs right?
Looks like the CPUs were definitely throttling:
http://img9.imageshack.us/img9/7927/wprime28.jpg
This run is over 1 sec faster than @ 3ghz.
Don't know how much I'll be playing with the setup today as I'm dead tired from my trip.
:clap: Great. Waiting for more.
WPrime 1.55 seems to have issues detecting the proper number of cores.....
http://img170.imageshack.us/img170/8762/wprime155.jpg
.....so does the Winrar bench:
http://img294.imageshack.us/img294/5459/winrart.jpg
Cinebench has the same problem as well...don't have a screenshot at them moment, but I'll post one later....
Yep...frequencies aren't adjustable. Only multi:
1.55 seems a lot slower:
http://img223.imageshack.us/img223/8140/wprime155a.jpg
Any programs out there that adjust memory timings?
