I know that the temps are high but when I run LinX (max problem size, max memory use) it gets very hot @ ~1,35v, when I run P95 small temp drops by ~10C and I can drop vcore by ~0,10v.
Everyone that have run LinX (LinPack) with max problem size, max memory use knows that the CPU gets very hot even though the vcore is relative low.
If I back down on NB GTL to lower then +70 Crysis wouldnīt run, it freeze and I have also tried CPU GTL from +50, auto, +50, auto to auto, -50, auto, -50 and seems that the system are most stable with auto, -40, auto, -40.
I can play games, web browsing, watch movie, encode, decode, run LinX, run P95 small FFT, loop 3DMark06 and Vantage for hours and other daily things without problems with the setup I have now but I are not stable with P95 blend. :confused:
So maybe I have to get into the black magic art of DRAM Skew but I donīt have a clue :shrug: where to start.
Thank you for your input
