Max BCLK Super Pi 32M Benchable
Did a fresh hard drive install which is WinXP Pro SP3 & Windows 7 beta dual bootable before attempting max Super Pi 32M benchable Bclk frequency tests. This time with 3x1GB Samsung HCF0 based modules for triple channel :)
System specs
- Intel Core i7 920 3836A756
- Thermalright Ultra 120 Extreme + LGA1366 Bolt Thru kit + 2x 120x38mm Scythe UltraKaze 2000rpm 87cfm fans in push/pull
- DFI LP UT X58-T3EH8 R.A51 - 01/06 beta bios
- 128MB Gainward FX5200 PCI
- 2x1GB Corsair DDR3-2133C9DF Dominator + 1GB G.Skill PC3-12800HZ (3x Samsung HCF0)
- Ram cooling: 3x 60x25mm Sunon 23.5cfm Maglev fans
- 80GB Hitachi 7K80 SATAII
- Pioneer DVD-RW
- 1KW Corsair HX1000 psu
- WinXP Pro SP3 full nLite updated hotfixes / Windows 7 beta dual boot
Triple Channel CPUZ Validation @229Bclk
Haven't pushed ICH 1.5 Voltage yet like I did for 230Bclk, so that will be next up for testing.
http://valid.canardpc.com/cache/banner/485164.png
QPI Frequency = 4123Mhz!
http://fileshosts.com/intel/DFI/DFI_...z_valid_tn.png
Super Pi 32M
Ignore the times just testing with loose timings. Higher Bclk do require more vdimm that usual due to QPI ceiling. Without enough vdimm DFI post diagnostic LED = CF code for lack of vdimm voltage.
@226Bclk bios set - QPI Frequency = 4063Mhz
http://fileshosts.com/intel/DFI/DFI_...9m01s750ms.png
@226Bclk setFSB windows set - QPI Frequency = 4074Mhz
http://fileshosts.com/intel/DFI/DFI_...9m00s468ms.png
@227Bclk - QPI Frequency = 4088Mhz
http://fileshosts.com/intel/DFI/DFI_...8m57s750ms.png
@228Bclk - QPI Frequency = 4110Mhz
- had to bump vdimm, vcore and CPU VTT Special percentage added
- either a bad run, or lack of volts for either vdimm or CPU VTT or both led to slower 32M Pi time ?
http://fileshosts.com/intel/DFI/DFI_...9m00s203ms.png
01/06 Beta Bios settings used:
Code:Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1024M
DRAM Command Rate: AUTO
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): 88
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): 16
ACT to ACT Delay (tRRD): 6
Row Cycle Time (tRC): 31
Read CAS# Precharge (tRTP): 6
Four ACT WIN Time (tFAW): 31
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: 1.350v * 1.3875v
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.875v & 1.905v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: +0.0375v & +0.0500v
CPU VTT Voltage: 1.53v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.25v
IOH Analog Voltage: 1.20v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 22x
2 core Max Turbo Ratio: 21x
3 core Max Turbo Ratio: 21x
4 core Max Turbo Ratio: 21x
CPU Non-Turbo Clock Ratio: 18x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO
CPU Base Clock (BCLK): 226 to 229 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 103 Mhz
DRAM Frequency: 8x
UnCore Frequency: 16x (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
