I am going mad...Just did what rob2k and still f***ing doing the same!!
Running on 1001 bios but will flash the 1003 and load defaults and see maybe this one works better.
ROB2K CAN YOU POST your settings with 472 fsb please. thanks excuse me for my english i'm italian.
@ ragheb - Nightmare !!, another thing I did at the same time was to uninstall Memset just in case this was changing the settings whilst Windows was booting.
@ DerekT - Cheers for the heads up. 1003 is working well here too. I can now run Intel Burn Test and HyperPi at 475FSB
Attachment 92010
@ Gullo92 - Will PM my settings to you to save space.
hi there where you downloading the 1003 bios from , thanks
can you post bios 1003? i don't find it
1003 only seemed to be at these 2 earlier
http://support.asus.de/download/down...Language=en-us
http://support.asus.com/download/dow...Language=en-us
Here you go.
Yep. I am now fully game stable.
You know what rob2k I think you are absolutely right about Memset. It places an entry on the in the windows startup files.
I will disable this and see if that sort this weird thing up..thanks for the hunch.
rob2k..Well done :up:for your input. the mem timings now work but you neednt uninstall Memset, just uncheck the entry using msconfig and it should bypass the last saved file.
hi
in to bios do you have changed other settings?? example chipest ecc.. because the ram is unstable with voltage 2.05.
you put the ram into slot white or blue??
both slots generally similar but the white slots are supposed to be the best ones
i have q9550 rammpage extreme ad corsair dominator 1800( ram of rob2k) the overclock of cpu is with multi 8.5 my q9550 has multi 8.5. excuseme for my english i'm italian
worth a bit more work though as 200strap/tRD6 (above 475FSB) gives reasonable performance for CL8.
All other straps are slower with CL8/1:2 at 500FSB.
500x9 / 1000mhz / 200 strap / CL8 / tRD 6 / CT Strong
thanks cstkl1 for the GTL, IBT stability is better than with my GTL
Code:
AI OVERCLOCK TUNER =========================MANUAL
FSB FREQUENCY ==============================500
CPU RATIO SETTING ==========================09
FSB STRAP TO NORTH BRIDGE ==================200
PCIE FREQUENCY =============================101
DRAM FREQUENCY =============================2000
DRAM COMAND RATE ===========================1N
CAS LATENCY ================================8
RAS TO CAS DELAY ===========================8
RAS PRE TIME ===============================8
RAS ACT TIME ===============================24
AI CLOCK TWISTER ===========================STRONG
AI TRANSACTION BOOSTER =====================MANUAL
PERFORMANCE LEVEL ==========================06
PCPU VOLTAGE ================================1.375
LOAD-LINE CALIBRATION ======================ENABLED
CPU PLL VOLTAGE ===========================1.617
FSB TERMINATION VOLTAGE ===================1.391
CPU GTLVREF 0 ============================== +40
NORTH BRIDGE VOLTAGE =======================1.603
DRAM VOLTAGE ===============================1.908
NB DDRVREF ================================= +12.5
DDR3 CHANNEL A VREF ======================== +12.5
DDR3 CHANNEL B VREF ======================== +12.5
SOUTH BRIDGE 1.5 VOLTAGE ===================1.617
SOUTH BRIDGE 1.05 VOLTAGE ==================1.100
CPU SPREAD SPRECTRUM =======================DISABLED
PCIE SPREAD SPECTRUM =======================DISABLED
Thanks cstkl1 & cheapseats for your help:). I managed finally to get the following setup see picture as per cheapseats above bios settings. Memtest stable after 100% run but have not yet pushed my rig to fully be happy that it completely stable at these speeds.
Anyway, glad to have resolved this finally but now I want to hit 600 FSB & I was wondering what I need to put in bios in order to always get a 5:8 FSB to DRAM ratio?
__________________
Rampage Extreme (1003)
E8600 (Q822A438 / vid 1.25)
CM Cosmos S Case with 4 fans
Nvidia BFG 8500GTS 512MB
Zalman XT WCooling CPU, GPU & NB
CS3222271 2x1GB
CM M1000 Modular PSU
WinXP x86 on Gigabyte i-RAM 4x1 GB RAM
WD Raptor 75GB & Samsung F1 1000 HDs
very nice ragheb performance level 6 at ddr2040 , excellent :up:
Thank you Glenboy.
I was getting rather frustrated with my Cellshock RAM & I must say it is very finicky with vDIMM above 1.90 with huge instability in Windows. Nevertheless it maintains tight timings very well at that vDIMM.
Now, I'd like to get into the 600Mhz Club...
_________________________
E8600 (Q822A438 / vid 1.26)
CS3222271 2x1GB
Thanks for your guide too will try that out later...
Yeah that may solve my problem as well...as my E8400 E0 can run small FFTs overnight @ 1.33v/4.36Ghz but fails @4.5Ghz no matter how high the voltages I pumped...so does it means it maybe possibly related to DRAM CMD Skew? Thanks in advance...
My Crucial Value (D9JNL) also have this problem.
If I bump more then 1.9v no matter what frequencies I set (even 1066Mhz) it still got wierd memtest86+ errors. The error will count in but the details won't always show below the screen. And it's confirmed not overheat issue. While that kit REALLY disappointing as with 1.9v still cannot get 1664Mhz CAS7 Stable.:down:
Hi ci2kla,
check the post (http://www.xtremesystems.org/forums/...postcount=1812) where I managed 1800 with CL7 with my RAM.
See if you can replicate it using the same settings..
Good luck
ci2kla,
I see that you are using 0701 as bios ver from your sig. Have you tried 1003. Running stable at 485*9.5 at 1.4v & 88824 1T with PL=6 suprisingly & I think this has quite a bit to do with the latest bios.
can you help me with overclocking??. i have rampage extreme(with bios 1003) intel q9550 corsair dominator 1800 mhz 2n 2.00V 7 7 7 20(my ram haven't xmp function). help me please. can you post settings with my setup? excuse me for my english i'm italian. this is the settings of rob2k he is a qx9770( in this overclock have multi 8.5 q9550 have multi 8.5) rampage extreme and my ram.
475 settings - BIOS 1003
Extreme Tweaker
Ai Overclock Tuner: Manual
OC From Memory Level Up: Auto
FSB Frequency: 475
CPU Ratio Setting: 8.5
CPU Configuration
C1E Support: Disabled
CPU TM Function: Enabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Enabled
Execute Disable Bit: Enabled
Core Multi-Processing: Enabled
CPU Clock Skew: Delay 300ps
NB Clock Skew: Delay 200ps
FSB Strap to North Bridge: 400
PCIE Frequency: 101
DRAM Frequency: 1900
DRAM Command Rate: 1N
DRAM Timing Control: Manual
1st Information: 7-7-7-21-8-88-12-6 (7-6-6-20 @ 472)
CAS# Latency: 7
RAS# to CAS# Delay: 7
RAS# Pre Time: 7
RAS# ACT Time: 21
RAS# To RAS# Delay: 8
REF Cycle Time: 88
WRITE Recovery Time: 12
READ to Pre Time: 6
2nd Information : 8-7-6-4-7-4-7
READ to WRITE Delay (S/D): 8
WRITE to READ Delay (S): 7
WRITE to READ Delay (D): 6
READ to READ (S): 4
READ to READ (D): 7
WRITE to WRITE (S): 4
WRITE to WRITE (D): 7
3RD Information: 23-8-1-8-8
WRITE to PRE Delay: 23
READ to PRE Delay: 8
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 8
ALL PRE to REF Delay: 8
DRAM Dynamic Write Control: Disabled
DRAM Skew Control
DRAM CMD Skew on Channel A: Delay 75ps
DRAM CLK Skew on DIMM A1: Auto
DRAM CLK Skew on DIMM A2: Auto
DRAM CTL Skew on DIMM A1: Auto
DRAM CTL Skew on DIMM A2: Auto
DRAM CMD Skew on Channel B: Delay 150ps
DRAM CLK Skew on DIMM B1: Auto
DRAM CLK Skew on DIMM B2: Auto
DRAM CTL Skew on DIMM B1: Auto
DRAM CTL Skew on DIMM B2: Auto
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
Common Performance Level: 06 (Auto selected)
EPU II Phase Control: Auto
CPU Voltage: 1.468
Load-Line Calibration: Disabled
CPU PLL Voltage: 1.577
FSB Termination Voltage: 1.418
CPU GTLVerf (0): +50mv
CPU GTLVerf (1): +50mv
CPU GTLVerf (2): +50mv
CPU GTLVerf (3): +50mv
NB GTLVerf: +60mV
North Bridge Voltage: 1.630
DRAM Voltage: 2.05
NB DDRVref: AUTO
DDR3 ChannelA Vref: +12.5mv
DDR3 ChannelB Vref: +12.5mv
South Bridge 1.5 Voltage: 1.577
South Bridge 1.05 Voltage: 1.086
CPU Spread Spectrum: Disabled
other settings in to bios are default
i have tried with 472 fsb and 475 fsb but the ram is unstable help me!!!
well I can still remember just last 2 months I was getting mad sturggling to get 535 FSB stable on a DFI LP UT-X48-T3RS...compare with this board...just keep everything auto and adjust the FSB frequency to 600, fire it up, the BIOS screen pops up, bravo.:p:
IMO you must know what you're doing when you make any adjustments on overclocking...testing tools are also important to figure out which part of hardware is holding you back. Basic tools are like Memtest86+ v2.01 (Mostly used #5 and #7), HCI Memtest 3.8, ORTHOS SP2004 / Prime95, IntelBurnTest, Etc.
i don't expert with overclock can you post the setting that i put into bios?
