Module divisions are transparent... so does that mean natural multi-threading? meaning a single threaded app will be split among 2 cores at the module level?
Yes i already read the artciel...
The improtant part is other enhancements. ;)Quote:
The 3rd ALU does have some performance benefits, and AMD canned it to reduce die size, but AMD mentioned that the 4-wide front end, fusion and other enhancements more than make up for this reduction. In other words, while there’s fewer single thread integer execution resources in Bulldozer than Phenom II, single threaded integer performance should still be higher.
4way wide frontend is wide, but alone its useless if you can't process the ops fast enough, so the solution is higher clocks speeds aka turbo.
Again i said, its highly likely that bulldozer will have higher singlethreaded performance, but IPC will go down compared to a single deneb core.
IPC will go down?Are you serious ? :p:
Having more underutilized units is bad.Having less units that are constantly fed and always have something to do(the part you made bold) will make the "IPC",the relative and mostly meaningless number (that is 99% of the time <=2), higher. That's the whole point of this machine.
I doubt they will double pump the ALUs.The units will just be more utilized,a difference from the units in today's parts which sit idle a lot of time .
I think that the guy answering the question in the teleconference got a bit confused. It is possible that the new parts won't work in old boards (and the old CPUs will work in the new boards),but this has never been the case in the past : just look at the AM2/AM2+/AM3 comparison.
Read the AT article.It is the hardest thing to do indeed,but the way this machine is built allows it to go a bit further ahead of itself(with all the BP,data speculation,much improved out of order loads and stores capability etc). I guess the more in depth slides from HotCHips will shed more light on this subject later today.
Here is my take on how BD will operate on sockets AM3 and AM3+
Bulldozer CPU = AM3 and AM3+ compatible
BD + AM3 = Dual Channel DDR3 enabled
BD + AM3+ = Quad Channel DD3 enabled
I bet difference is a few extra memory features on socket AM3+, just as previously done with sockets AM2=>AM2+/AM3
Hmm somehow I doubt there will be 4 ch. on AM3+ boards.
well, I'm only speculating that the difference will be as such that you will get extra benefits on AM3+ but won't hinder AM3 compatibility
But its true QC won't be possible. but perhaps enhanced power features like the turbo mode, could be different on either sockets.
Ontario 2 core + DX 11 GPU die is about 75 sqmm based on analysis of photos of the wafer shown at Computex.
Yeah, I wonder how long we have to wait before we get an answer for that.
No matter if AM3+ have many or very few improvements, AMD won't tell us too soon I guess, because they want to sell as many CPUs and chipsets before BD as possible.
The 870/880G/890GX/890FX was launched this spring, and when was the specs revealed? Two or three months before? And that was even with a chipset with very minor updates, especially the NB.
This makes me think that it isn't very likely that we'll see any specs this year.
This socket confusion will get sorted out pretty soon tho.
if BD dosnt drop into AM3, it better be due to costing alot and competing very well, then maybe the extra 100-200$ would be worth while/irrelevant.
since i was just going to wait for AM3+ before dropping AM2+ anyway, im not feeling very hurt, but it does kinda suck
If all the web's complied with NDA, they'd have more info now. Those who did so have the new slides:rolleyes:
As for the socket compatibility, there is no info about it in the AMD slides and what was said during the conference call does not say as much as the webs, too. So I guess if they don't have another source they just made the informations trying to hit the mark.
I just can't understand how can you talk on 6 pages about infromations based on nothing? Calm down people! It's starting to be impossible to find something important betwen all the crap here. If it will continue this way, people will move to another forums:shakes:
FSB Interface was in the processor too, otherwise it couldn't communicate with the NB. So HT has nothing to do with a NB.
NB has always been memory controller, the main bus interface has always been present in the processor. K7 had an area called "Bus interface unit".
So I still can't see what part of the NB except the IMC that has been integrated in Phenom. :confused:
John is this true?:eek:Quote:
Fruehe says that AMD will be able to get six-core and eight-core Bulldozer chips in the 30 to 40 watt power range, which is pretty low for a server. "The question is this," says Fruehe. "Is there a need for a more discrete, less-threaded chip for servers?"
