The ZIP file should be 100KB.
Make sure you clear your browser cache.
Hmm, it obviously didn't like K10 on AM2 board, reads normal temps for half a sec, then it reads a 9 digit number..
Yes it was a bug, I fixed it.
New version will be out soon
Its due the addition of G15 support and it's Low\High report.
So Core Temp output an address to a variable instead of the variable value (temperature) itself :p:
Version 0.97.1 - 7th March, 2008
- Fix: Phenom did not display proper temperature.
- Fix: Phenom randomly reports 255C (value ignored).
- Fix: Phenom displays more than a single system tray icon per CPU.
- Fix: Phenom 1/4 multipliers rounded improperly.
- Change: C° and F° now will display °C and °F accordingly.
downloaded, will test later and report back on it :)
cool!
Version 0.98 - 23rd April, 2008
- Fix: Core Temp sometimes crashes when another program tries to access the log file. - Still needs further testing.
- Add: Show load percentage per core.
- Add: Adjustable Tj.Max value via *.INI file.
- Add: Option to start Core Temp with Windows.
- Add: Support new Intel Mobile processors
- Change: Maximum logging interval is now 99999ms instead of 9999ms.
- Change: Log file layout. Shows current temperature, high\low temperature, core load, CPU speed.
:up:
Here's an update on the next Core Temp release, it may interest some of you:
http://www.alcpu.com/forums/viewtopic.php?t=405
ver 0.98 Does not display temp on my Board for some reason.
It's a bug with 0.98 and 0.98.1 and Phenom. Will be fixed in the next release.
as always great help and a great program your the coolest :D
Beta Version 0.99 - 2nd May, 2008
- Fix: Incorrect recognition of 45nm Mobile Intel CPUs.
- Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).
- Add: Shared memory - developers now have access to Core Temp data.
- Add: Register dump to text file function.
- Add: Preliminary Atom (Silverthorne) support - Untested.
Thanks brother it works but displays 4 read outs 28 -0 -0 -0 c :shrug: My question is this it should display temps on only one correct or all 4 ? Phenom is single quad core:confused: Just woke up sry;)
Ok thanks, I'll at it when I get home
For some reason with Asus P5E3 Premium + E8500 one core sits at 40ºC idle or load doesnt matter, do you have any idea why this can be?
Although this is an AMD section it may be a case of sticky sensors.
What does your other core run at?
DTS on some CPUs is really messed up, look here:
http://www.xtremesystems.org/forums/...103638&page=12 (starting with posts after 31st December)
Check this thread in the news section for more info on the new features and a nice little gadget for Vista users.
Core Temp's shared memory goes official. Everyone is welcome to read up on specs.
DLLs and demo projects showing how to use them are available for download here.
Beta Version 0.99.0.14 - 12th May, 2008
Changes from previous beta:
- Change: G15 LCD text layout and font changed.
Here's a pic:
http://img80.imageshack.us/img80/959...e005im9.th.jpg
How come for example S&M gives way more accurate temperature readings for me? What I hate the most with CoreTemp is that the temperatures can vary +/-1 in one second. Once it is 60/60, then it is 57/62, then it is 63/59 and so on. How am I supposed to know the temperature? The Coolest, can you honestly call that accurate? What about reading the temp for example 3 times a second, then take average of them and sum it up by the last seconds average and divide by 2? As far as I know, S&M uses similar method, which is far superior to what CoreTemp can offfer.
Just thought I would post that Core Temp is not diplaying the processor name of my Opteron 1210HE. It just says unknown Model F3 stepping or something like that.
The temperature inside the core can and does change very rapidly, so yes, it is possible that one second its a bit lower and the next a bit higher.
It is also possible that it's just the sensors margin of error.
Thanks for letting me know, can you please create a register dump file (in the options menu) and just upload it into [code][/code] tags here?
@ The Coolest Thanks a bunch for this app! I like it alot. Will be testing it out on the phenom momentarily
Not really related to CT, but for example CT shows that my CPU temp gets from 80'ish to 50'ish in 2 seconds, which can not happen really. Where does the heat go? At least not to HSF as it is near 70'ish still after 2 seconds. Neither does the CPU PCB cool the core.
Actually, core temperature is quite much the same as the HSF base temperature, except the "loss" which happens due to bad heat conductivity between core and HSF base. But as I said, this doesn't really have anything to do with CT.
CT might be accurate when reading the sensors, but doesn't really help when the sensors are so damn inaccurate.
Vista Sidebar Gadget - 14th May, 2008
A first public release of a Vista sidebar gadget for Core Temp, be sure to check it out. Latest Core Temp build also adds an option in the system tray settings to only display the Core Temp logo in case you're using the gadget and don't see the point for two places displaying temps.
Version 0.99 - 18th May, 2008
- Fix: CPU load would sometimes display -1% load.
- Fix: AMD K8 would sometimes spike to 206C, the false reading is now ignored.
- Fix: AMD K8 sometimes constantly reads -49C.
- Fix: Core Temp does not show up automatically on G15 LCD with 2.02 driver.
- Fix: Shared memory structure was not properly filled on multiprocessor systems.
- Fix: System tray setting "Show highest temperature of each CPU" only displays one temperature reading in a multi CPU system.
- Fix: Certain problems with font resizing should now be fixed.
- Fix: G15 LCD would not update after using soft buttons.
- Fix: On temperature display mode change, high and low records were not reset.
- Fix: Changing the reading interval in settings did not actually update, restart of Core Temp was needed to apply the change.
- Fix: Incorrect VID detection on 45nm desktop Intel parts.
- Add: Support for Intel Core 2 Duo E7000 45nm series.
- Add: Option to show a single icon instead of temperature in the system tray.
- Add: Custom font and size for G15 LCD screen or simply use the built in compact font and layout. (via Settings.ini)
- Change: Improved detection of L2 cache on Intel chips for more accurate recognition.
- Change: Rewritten temperature calculation to fix problems with shared memory. Needs more testing to confirm as 100% working.
- Change: Default G15 LCD text layout and font changed.
- Change: Doesn't create a log file containing session start and end times if logging is disabled.
- Change: Settings.ini file is automatically created with default settings in case one doesn't already exist.
MircCoreTemp plug-in - 17th May, 2008
You need SystemInfo script and latest Beta Core Temp
This is currently in a very early development. I've been working on this for the last couple of days.
If anyone ever saw PerfMonitor by Franck (CPU-z), then the idea came from his work, and he has helped me out a bit on several points.
Anyway here are the screenshots:
http://img87.imageshack.us/img87/7057/graph1vo9.png
http://img142.imageshack.us/img142/3577/graph2tk3.png
The graph is resizable. I still need to work a little bit on the efficiency of this thing but it's looking good right now.
All colors are customizable:
Background
Text color
Graph color
Grid color
Frame color (yellow in the pics)
0° graph (not shown in the pics)
Title text (up to 30 chars)
Do let me know what you think.
Updates on the progress can be seen here:
http://www.alcpu.com/forums/viewtopic.php?t=422
hey The Coolest i still get -49 with my chiller setup on core 0
Could it be anyway possible to have a setting which would affect how the core temp shows the temperature, like average temp of last 2 seconds etc.
Something like:
I think it is quite self-explanatory. Read temps 4 times per second, and take the average temperature from last 3 seconds. As I have said before, that even though CoreTemp is accurate at reading the sensors, sensors aren't so accurate for humans. This feature could somewhat compensate the sensor "inaccuracy".Code:[AVERAGETEMP]
UpdateInterval=250
AverageTime=3000
Also, I'd love to see average temperature of the cores with one decimal accuracy!
Well, I think this could be done with external program aswell without big hassle, but I am qite sure I am not alone with these feature wishes so the best way could be having those in actual main program. :)
Grapher update
Originally Posted by The Coolest
Download
http://img515.imageshack.us/img515/273/graph8fm6.png
This is a little add on for Core Temp. Currently it's in public beta phase, not ready as final, but ready enough for public testing.
Simply extract both files in the ZIP, run the exe. Core Temp 0.99 must be running for it to work.
A 3rd file "Grapher.ini" is created with defaults. You can edit that file and restart to program to apply changes. (You can also click the Actions --> Reload colors to update the colors on the fly from the ini file, without the need to restart the app).
All settings are pretty straight forward. A later version will include a GUI for the settings.
Please post all bugs, problems and suggestions in this thread.
CT Grapher 1.0 Beta, build 1.0.0.2 - June 9th
- Add: Logging, creates a PNG file per graph with full history.
*Note: Please delete the old ini file before use.
Download
I'll have to give this a try at some point here
Version 0.99.1 - 10th July, 2008
- Fix: Layout when using upto 125% DPI.
- Fix: Layout problem and extra systemtray icons with Phenom.
- Fix: Potential crashes while saving a register dump file.
- Fix: Core Temp icon wasn't showing in About box.
- Fix: Menu shortcut keys were not available for all menu items.
- Fix: A few old unnoticable bugs.
- Add: Initial Intel Nehalem support.
- Add: Initial support for AMD's Griffin cores - Untested.
- Add: Improved Intel Atom support.
- Add: Support latest AMD K8 CPUs.
- Add: Support for HyperThreaded CPUs. Core Temp will only display the physical cores and average load on each core.
- Add: Support for Pentium E5000 series.
- Add: Display core and thread count per CPU.
- Add: GUI Adjustments of Temperature offset and G15 applet via the Settings window.
- Add: Create a screenshot function. Access from "Options" menu or by F9 shortcut.
- Add: Shortcut key for register dump file: F7.
- Add: Update register dump output: APIC ID, CPU number, Core number, Thread number.
- Change: Move all settings to the ini file out of the registry.
- Change: Rename ini file to CoreTemp.ini.
- Change: Temperature offset adjustment works for AMD CPUs as well.
- Change: Atom Tj.Max adjusted for more accurate readings.
- Change: Cleaned up code a little bit.
Many thanks The Coolest for your ongoing work :clap: :up:
Version 0.99.2 - 18th August, 2008
- Fix: Start with Windows option was broken in 0.99.1.
- Fix: Default color for the second system tray icon is invisible with WinXP blue theme.
- Fix: Save screenshot function would create a corrupted BMP in some viewing software.
- Fix: Nehalem does not report VID like earlier CPUs. VID field now disabled for Nehalem.
- Fix: Incorrect 65nm Turion X2 code name detection.
- Fix: Potential bug of improper K10 and up recognition.
- Fix: Enabling distance to Tj.Max with "Highest temp." for system tray would show the largest distance to Tj.Max instead of smallest.
- Fix: Vendor ID and Device ID values were reversed in the register dump file.
- Fix: 3/4 temperatures logged for Phenom X3/X4 instead of 1.
- Add: Support for Core Temp plugins. (Still in beta phase and not in GUI yet).
- Add: Full support for AMD's Puma platform CPUs (in previous version reffered to as Griffin).
- Add: Initial support for 45nm AMD processors.
- Add: Update K8 and K10 recognition code to support all currently known CPUs.
- Add: Default TDP detection for Nehalem.
- Add: On the fly CPU speed detection.
- Add: Close to system tray option.
- Change: Log file is now produced in CSV format - easily import your logs into Excel.
- Change: Logging interval is now in Seconds instead of miliseconds.
- Change: Default logging interval is now 10 seconds.
- Change: Logging is now off by default.
Hello.I have a phenom.Just downloaded core temp but it shows only 1 core.
Attachment 83862
Phenoms only have a single thermal sensor.
And the previous version would record 3 or 4 temperatures (depending on the CPU) in the log file.
thnx
newest coretemp reads EO e8600 TJ as 105, are these 105 are are they 95 liek the C0's
thanks coolest
We don't know what TjMax they really are yet, we should know this Thursday, though.
any news on that TJ ??
cheers
Following Intel's presentation about the DTS at IDF yesterday, Core Temp has been updated.
Version 0.99.3 - 22th August, 2008
- Add: Correct TjMax values for 45nm Core 2 series, according to this document.
- Fix: When TjMax = 0 (undefined) "Delta to Tjunction" was not added to the temperature string.
Thank you.
Version 0.99.4 - 23rd January, 2009
Major changes:
Completely rewritten base code.
Core Temp is now available in both 32 and 64 bit versions.
- Add: CPU detection improved, efficiency improved, speed improved, clock speed detection improved.
- Add: Initial support for Core i5 (Lynnfield).
- Add: Automatically detect Core i7/i5 series TjMax.
- Add: Show real-time TDP of Core i7 processors (still needs work).
- Add: Alternative clock speed detection for Core 2, i7 and i5 series and up.
- Add: Support for all currently available and some future processor families. (Intel & AMD)
- Add: Temperature changes color when temperatures hit high levels to alert the user. (Orange = hot, Red = critical)
- Add: Show (!) besides the temperature of a core which hit critical temp as a notification of past overheating.
- Add: Invalid temperature values are followed by (?) for both Intel and AMD.
- Add: AMD AM2+ 65nm processors get a 21c offset to fix incorrect temperature reporting (info from AMD).
- Add: AMD Black Edition processors identified by "BE" suffix after PR rating.
- Add: Display time and date on G15 LCD.
- Add: Complete DPI awareness - Core Temp GUI now scales perfectly with any DPI setting.
- Add: Rewritten algorithm for "Register dump" function, works much faster and more accurate (no ghost devices).
- Add: Redesigned log file system:
1) Settings window allows to start logging when Core Temp starts.
Logging can be toggled on or off from the Options menu or simply by pressing F4.
2) Layout is completely changed. Now it's easy to create graphs and the output is more coherent and understandable.
3) CSV file format is preserved.
4) Each logging session creates a seperate log file named with time and date of session start.
5) Logging is now off by default.
- Add: Register dump provides much more information:
1) Supported instruction set.
2) Supported features.
3) Manufacturing node.
4) Default CPU speed, multiplier range and maximum VID.
5) Bus ratio multiplier.
6) Processor and OS thread counts.
7) Cache: Count and size.
8) Processor topology.
9) PCI register dump also lists device names when "PCIDEVS.TXT" file is added to Core Temp's directory.
Link (scroll down a little)
10) Better output layout, easier to read.
- Fix: Core Temp crashes on Intel multi-processor platforms with Socket #0 unpopulated.
- Fix: Countless minor bug fixes due to rewritten code base.
- Fix: System tray icons do not appear after explorer.exe crash/restart
- Change: Core Temp will now work with A0 and A1 revisions of 65nm Core 2 processors.
- Change: Core Temp will not work on some/all virtual machine software.
- Change: TjMax values for 65nm Core 2 series adjusted.
Hi...thank you for the update...
Ahtlon X2 4850e Brisbane Rev.G2 shows correct temperature now...but wrong name...It is recognised as "AMD Athlon X2 3850e (Brisbane)"...
I am using the 64bit version on Vista Ultimate x64...
Thanx
I'll take a look, thx.
awesome tnx for the new release
Congrats on great work!!
BTW
code name for Turion X2 Ultra ZM8x series of AMD's mobile processors is Griffin not Lion ;)
Reads my 5000be x2 perfectly on 1 core..second core is off by 10c...can you make it so the offset can be set individually for the cores?
this is such a cool program..you are a smart guy to be able to build this .....
Are you sure, I looked it up on Wikipedia, in 0.99.3 it was Griffin.
http://en.wikipedia.org/wiki/Griffin_(processor)
I'll look into it, I know this is a problem with many X2s.
Great program finally something that can show the temps on my 65nm Brisbane correctly, AMD Athlon x2 4000+ 2,1ghz @ 300 x 10 = 3000mhz 1,41v
Idletemps was:
Core #0: 31-34
Core #1: 30-33
So i tried running LinX with this and here's the results.
But as above the temps is abit off:
Core #0: 48 - 52
Core #1: 58 - 63
So i can only assume that Core #1 is correct while Core #0 is off, but this only at load, seems to show correctly idle. Never thaught my temps was that high lol.
Also it shows my CPU at 285.75 x 10 = 2857.54mhz and that the voltage is at 1.3000v. CPU-Z shows correctly.
All I can say is keep up the good work!
Core Temp only shows the VID, not actual vcore.
Regarding speed, there is a problem, especially with AMD CPUs... I'm working on it
All OK on Phenom II 940BE :up:
yeah it's Griffin
http://hosting03.imagecross.com/imag.../1483CPU-Z.jpg And this is how CoreTemp see it: http://hosting03.imagecross.com/imag...-0.99.4-2-.jpg
Heh, you know that Franck is also human. I will talk to him and try to see who is right on this one.
Either way if he's right I'll fix this.
*EDIT:* Ok I think you're right, I just didn't read that article on wiki correctly. I'll fix this in the upcoming bug fix release. Thanks.
Very nice Coolest, supporting 64 bits is aways a great deal :up:
No VID.
Foxconn Bloodrage mobo G16 bios.
http://www.xtremesystems.org/forums/...1&d=1232759189
Although this should be in the Intel Core Temp thread. Nehalem does not report VID, so this is not a bug.
That's really not a big problem, but this is:
http://www.abload.de/img/error7xk4.png
Vista Ultimate x64, Phenom X3 8750@ 3 GHz, ASUS M3A32-MVP Deluxe
Previous version is working just fine.
funny enough, all cool here too !!! (under water)
http://media.bigoo.ws/content/saint_...gif/gif_85.gif
This is a Beta bug-fix release. Please report if you find any problems or have any suggestions please let me know so they can be fixed/implemented before the final release.
Version 0.99.4 (Build 75) - 27rd January, 2009
- Add: Show high/low temperatures. (Press F6 or the Tools menu to reset values)
- Add: On/Off switch for G15 applet in Tools menu.
- Fix: Settings window would open centered, and sometimes out of the desktop area.
- Fix: System tray icon very small in Windows 2000/XP/2003.
- Fix: AMD Athlon X2 4x50e series detected as 3x50e.
- Fix: Add support for Mobile Athlon 64 X2 TK-xx series and Turion 64 MK-xx series.
- Fix: Workaround added for when Core Temp fails to find supported CPUs on Phenom based systems.
- Change: Reorganized menu.
- Change: Only detect ES status for Core 2 series. Core i7 and Atom detection was incorrect.
- Change: TjMax for mobile Atom processors changed to 90C.
- Change: "Lion" codename for AMD Turion was changed to "Griffin".
32bit
64bit
Thanx for fix...
This beta build 0.99.4 is showing good temps with my Brisbane G2(~30ºC idle and ~48ºC full @ 2800MHz 1.30v). Previous versions were showing wrong temps like 5ºC. Can I trust in the temps now? Something have changed to adapt the program to the readings of the internal sensor in Brisbane?
They meant AM2 65nm processors, I think I got confused and wrote the wrong socket in the change log
hmm... got plus 21degree on my x2, that´s 67/69 under load. Should I trust the new Core Temp version and check my mount or ignore it ?
(231x13 1,5V)
edit: nvm, checked coretemp forums, set -21 offset. Still going to check hsf mount.
I set coretemp to load in startup...after getting into windows, low temp values do not appear (shows 0 deg ) at all unless i reset high/low. Normally lowest temps should be the ones first recorded after startup, correct ?
Not sure why that happens.
What CPU is it?
And on another note here are a few new things I'm working on:
Mini mode:
http://img510.imageshack.us/img510/2995/minifullex8.png
Proper overheat protection:
http://img155.imageshack.us/img155/6683/optionskq2.png
Per core offset adjustment:
http://img17.imageshack.us/img17/3964/offsetyn1.png
Change log since the previous beta:
Version 0.99.5 (Build 6) - 7th February, 2009
- Add: Thermal protection mechanism. (Look at Options menu)
- Add: Mini mode for GUI. (Double click anywhere to switch between modes)
- Add: Per core temperature offset adjustment. (Look at Options menu)
- Add: Screenshots are now taken in the lossless but very compact PNG format.
- Add: User defined text colors for main Window. (Options --> Settings)
- Fix: PROCHOT signal from Intel CPUs was not picked up correctly.
- Fix: Core Temp would start out of the desktop area, and the main Window couldn't be seen/accessed.
- Fix: AMD K8 series incorrectly reports temperature at over 200C (CPU bug, workaround applied).
- Fix: High/low temperatures would be reversed when "Show distance to TjMax" was enabled.
- Fix: Clicking "Defaults" button in settings would enable logging when it should be disabled by default.
- Fix: "Show highest temp of each CPU" systemtray icon configuration sometimes reports duplicate readings.
- Change: Completely dropped support for older Windows NT OS, Windows XP or up is required.
(For Windows 2000: download GDIPlus.dll here http://www.dll-files.com/dllindex/dl....shtml?gdiplus)
Download:
32bit
64bit
Official support thread on Core Temp forums.
Hi,
this great little program compelled me to register to report a bug I find anonying. please bear with me...
when I run with CNQ on in Vista, CoreTemp frequency detection gets all messed up...
http://www.lookpic.com/files/CoreTemp_bug.jpg
this is the frequency the program shows for all 4 cores when it is suppose to be at "800MHz (199.99 x 4.0) (verified by CPU-Z) and not the above "2999.9MHz (749.98 x 4.0)."
Sequence that reproduces the wrong frequency reporting:
1) run with CNQ disabled. frequency reporting is fine.
2) run with CNQ enabled. program detects CNQ is enabled and changes to correct frequency at lowest power state (800MHz).
3) pressing the builtin refresh functions messes up the frequency detection to what is pictured above. Subsequent refreshes doesn't remedy the problem.
4) disable CNQ and now the program displays "11249.65 (749.98 x 15.0)." Enable CNQ and it goes back to displaying what is pictured above. Refreshing when CNQ is disabled will correct the problem and will display "2999.90MHz (199.99 x 15.0)."
:confused:
my system:
Vista with latest updates
Phenom II X4 940
Foxconn A79A-S with latest BIOS
CoreTemp 0.99.3, CoreTemp 0.99.4 beta build 75 & CoreTemp 0.99.5 beta build 6
Yes, this is a known issue.
I'm actually trying to figure out a way to fix this. Hopefully soon.
Fixed beta is here:
http://www.alcpu.com/forums/viewtopic.php?p=2401#2401
Please read the description before using it.
^ Thanks again for your continued effort in making your great app available :clap: :up:
Could anyone please confirm the new build from here works on their Phenom?
In previous versions up to 0.99.5 build 6 I was able to start the app but the frequency was incorrectly detected. (AMD X2 Brisbane BE) But now with the latest build 11 I can't even start the app, it shows an error message which I attached here. 64bit version, OS is vista x64 ultimate SP2 v113.
List of changes since the last official release:
Version 0.99.5 (Build 20) - 12th March, 2009
- Fix: Incorrect clock speeds reported on some systems.
- Fix: At startup Core Temp shows 0 (?) or 21 (?) on AMD K8 series.
- Fix: Turion MK series recognition was wrong.
- Fix: Properly detect Atom and Core i7 engineering samples.
- Fix: Tri-Core AMD CPUs incorrectly shown as having only 2 cores and 2 threads in 64bit Core Temp binary.
- Fix: System tray text was off center.
- Fix: Penryn (mobile Core 2) processors reported as having 85C TjMax instead of 90C.
- Add: Completely new code for processor speed detection.
- Add: A comprehensive processor information windows (F3 or Tools --> System information).
- Add: Running several instances of Core Temp is now possible (enable in Settings).
- Change: Temp turns Orange when temperature is over TControl, and Red when CPU is thottling/critical.
Works fine with Phenom II X3 720BE on Win7 64bit.
Now, if AMD just fixed Deneb's temp sensor. The offset to software reading is clearly more than 10°C based on my measuments with a k-type sensor on a DMM.
*shakes fist at AMD*
edit:
Looks like the label "Freq. #2:" for X3's core#2 is missing:
Attachment 96384
edit2:
"Freq. #2:" does appear when in minimized mode:
Attachment 96386
:p:
Could you please press F3 (system information) and post a screenshot? I haven't had a chance to test it on a Phenom yet.
Attachment 96385
Note the edit in my previous post...
Actually, the label "Freq. #2:" is where it's supposed to be when the app launches, but it disappears if I double-click-minimize the app and then return to the normal view.
Thanks largon. I tracked it down. Should be fixed in the following release.
Hey ,, nice work as always..
9950 :D
When i press F3 it shows Default Frenqency is @2700mhz( its 2600mhz for 9950's)
Also the last Tag (Core #3) ,, must of ran off with Largons #2..
http://i168.photobucket.com/albums/u...9950phenom.jpg
Temps read the same as 99.4 tested with DMM .. looks good with the Low / High Boxes now.. Adding the Overheat Protection mode and Double clik priceless:up:..
The label problem is rather funny, but it'll be fixed in the next release.
The default frequency part is problematic. BE Phenoms don't have a maximum multiplier, so Core Temp currently uses the P0 state values..
I guess that it's not a good idea doing things this way. I'll try to search for an alternative.
Version 0.99.5 - 3rd August, 2009
- Fix: Using a negative offset on AMD systems results in "42949672xx°C" being displayed.
- Fix: False overheating warning on AMD systems.
- Fix: False readings of over 200C° on AMD systems.
- Fix: 23xx and 83xx series AMD Opterons recognized as 83xx and 23xx respectively.
- Fix: System tray icons appear incorrectly on AMD K10 and newer CPUs.
- Fix: G15 applet did not work after resuming from Sleep/Suspend.
- Add: A comprehensive processor information window (F3 or Tools --> System information).
- Add: Thermal protection mechanism. (Look at Options menu, changed from 0.99.5.20 beta)
- Add: Support for the latest AMD and Intel CPUs.
Same problem here.
Strange, seems like it crashes on some AMD systems.
Final8ty, does it crash on your P-II 955? Or do you have some other system that it doesn't work on?
It works on Intel systems.
Not working on my system either, 99.5.20 works fine (what I'm using now).
EDIT: was trying the 64-bit edition.
