Nice Amigo :)
Can U Submit Some 3D Banch Testing? With That Frquenc 4800MHZ
I Sell DFI And Give UD3R Next Week
I Just Know This Frquency What Can Give CPU Score In 3D 06?
Tanx M8
Nice Amigo :)
Tanx M8
Gracias amigo :)
That was my first boot at that frequency, will keep making in stable for bench and tweaking volts, as its a very low vid chip its hell at those volts but either way i will push it :yepp:
either way as an advance here's a ss for you at 4707 3DM06 also booted from bios
http://img411.imageshack.us/img411/8674/47073dm06.jpg
Cheers :up:
Sergio
thanks mate :toast: but dont have to dedicate to me
thats just 4.8 foreplay right there^ at such low voltages
set vtt to 1.7 max
set vmch to ~1.8
set vpll @ 1.74/1.8 whichever boots up
set vcore @ 1.55-1.575
set vdimm @ 2.5 trust me i got the same kit and runs ~2.7 on a daily basis :up:
ram timmings: set 5-5-5-15 and the rest of the timmings set to what the bios shows
try both 1:1 4:5
you havent seen what your setup can do yet mate.. give it hell and you shall reap new oc clocks :toast:
Nice job Sergio :up:. Very hard to boot above 530.
very hard to boot over 530 ??
2x q9650 545fsb windows booted + validation @ 4.9ghz on air.. no easytune
http://img515.imageshack.us/img515/5507/4905od4.jpg
http://valid.x86-secret.com/show_oc.php?id=422821
http://img158.imageshack.us/img158/4319/4905zr0.jpg
http://valid.x86-secret.com/show_oc.php?id=434280
1.2125vid: lower vcore @ higher temps
1.2500vid: higher vcore @ lower temps
both air cooled by the same ifx14
havent checked but i think its still the wr on air
dont worry mate im not attacking oc nub
just wanted to show that a good mobo/right voltages and settings.. high clocks can be booted even on air.. thats all
i just checked the q9650 wrs: http://www.ripping.org/database.php?cpuid=851
so mr. hoss331 here claims that his best clock 4958.98 is on air ??
http://valid.canardpc.com/show_oc.php?id=509199
lying lamearse bastard.. you water/freezing water cooling (you said it yourself) and then you claim "air" :shakes:
good luck with your bulls{}t
Managed to hit 4914mhz on the Q9650 today, can't boot close to that or run it stable close to that though...
I'm just running 1.62v CPU and 1.54v MCH.
1.8v on the MCH core? Seems like a lot, what cooling is your mobo on?Quote:
set vtt to 1.7 max
set vmch to ~1.8
every ep45 can run @ 1.8vmch air cooled
if it seems like a lot to you.. dont run/set it @ 1.8
you guys keep comparing ud3 vs my dq6/extreme while none of you got the same components i do.. not all ep45s are the same.. you guys went against everything (components/voltages) ive suggested.. dont expect the same results.. if one cant afford the same components i dont hold it against and never did
Are you kidding me, your getting worked up over nothing. :down: Calm down killer.
Maybe you didnt understand this well but it means, yes I currently use water now, but I DID NOT a few months ago. I switched over to water in mid MAY and if your so concerned about it I can probably find the receipts for you. That validation WAS done on air (S1283 w/FM123 fan) on February 16th, 3 months before I had any water parts. I havent even tried for a higher clock on the 9650 or 3380 for that matter since the water setup has been put on. Again, you need to calm down. :up:
Anyone know why I get a rejection from CPUZ? I submit a 4851mhz oc and get this email:
http://img245.imageshack.us/img245/7576/rejected.png
I cannot boot in w7-64 at these clocks so i use et6 to go up.
Ok so I boot up at normal 4500mhz, try and validate and get another reject. WTF am I doing wrong? Prime blend 10hrs 4500mhz but fail CPUZ lol?
CPU-Z 1.52 tried ?
Ive heard sometimes win7 will cause it so try it in vista or xp if you have them. My xeon always got rejected no matter what clock it was at in vista and win7, havent tried in xp yet though.
Don't have an install of xp or vista. May have to install to get validated. In version 1.52 the "Validation" Is grayed out. I guess it is w7 causing the problem.
If you get the final 1.52 "validate" is not greyed out. :up: Maybe its not win7 or atleast not 7600, just tried the xeon and it validated for the first time. :shrug:
Thanks guys :up:, works now.
Whoa there! I already quashed your false statements down one after another on technical ground and also got you to admit your mistake, so what's the yapping about?
Having trouble handling the truth? I described precisely what you're doing: fleeing from one defeated subject to another. Can't tell what you pulled was all irrelevant? Well finish your EE classes first by listening and learning than yapping! And now you want to pick up yet another fight after having lost all the technical debates, but c'mon, in English writing? How relevant is that to this topic and this thread? You just added more evidence to my precise description above.
So what's next after your English writing fight? Are you gonna argue "My dad is better than your dad"? How far off-topic do you want to drag this thread down? Looks like you're not only a rumor maker, you're a troll! You see, you just repeatedly proved you're helplessly clueless as you don't even know what forum you're trolling around yet you troll no matter what. :down:
A rumor is a rumor. You showed that you loved fabricating it and enjoyed sharing it among your circle. Now, you don't see your baby rumor circulating anymore that's probably because I have effectively killed it at its early stage. Feeling disappointed? Don't worry, with your special talent I'm sure you will have no problem fabricating tons more for the rest of your life. Keep up the good work.
And geez, do you even have an iota of idea of what a datasheet is? Datasheet and Specs are the type of documents written to offer clear-cut and unquestionable info for the targeted designers to directly follow or comply, with the least possible amount of confusion or room for interpretation. They are not meant for open debate, as you either understand these documents or you don't! Since you've shown much trouble "interpreting" statements from such document, that only means you don't have the required knowledge to understand the datasheet at all!
Now, the fact that you don't have the knowledge to understand the Intel datasheet, and yet you still brazenly made false assertion which you claimed coming directly from Intel, constitutes lying and that makes you an impostor as well. Liar or impostor's opinion is not welcome here. And they are not entitled to misinforming or misleading the public, either. :down:
No wonder you can't tell what's relevant and what's irrelevant to this subject, as you essentially can't read the datasheet. As an impostor who would do whatever just so you can "sound smart" on a technical board, you have been exposed miserably. Stop wasting everyone's time and the forum resource here. You're pissing a lot of people off when they just learned what they took from you was all but false info - an apology is overdue for them. It's in everyone's best interest if you stop posting baseless crap and stop trolling. And you'd better hope that you won't die of quack doctor seeing what you have done in life.
Highest I have been able to boot is 535x9 in w7-64, but managed to get up to 540x9 4860mhz using et6. Anything higher causes me to lockup in a few seconds. If I get time I will install vista 32 or xp pro this weekend and go for higher. I think 4900mhz+ is very doable with this chip.
i know its not great but tough gettin rex to pass 500fsb stable
CryptiK and vws, since you two can't agree each other's statement, can you guys just get moving on? Thanks.
Hey Guys Got UD3R Today :up:
Finnaly Sold Old Dirty DFI:rolleyes:
Some Test Few Next Day:yepp:
that's the same for the 65nm chips also right? even they max out at a higher voltage of 1.5v not 1.362v like the 45nm do... i'm just asking everybody knows more voltage comes more heat and that's what kills a cpu it's like running a engine in a car with no antifreeze or bad thermostat the block will
crack and lockup the same with these cpu's and heat produces wear and that produces short life...:yepp:
Congrats...I wish I could sell some old parts and mb's and whole computers i got laying for some new things..I need
what's the trick to do that ViViD?
finally got the w/c set up and running. got a quick and easy bump to 4400mhz, need suggestions to get 4500+
this is my setup:
ga ep45 ud3r f9
q9650 vid 1.1875
g.skill lv 9600 4x2g
corsair tx750
4870x2
cpu and nb water cooled now, and at the current settings below I run 52/53c prime and 66/67c intelburn- over 20c cooler than hsf before
here are my current settings:
******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio...........................[0]
CPU Frequency ...........................[ 489x9 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 489 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 50ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Turbo ]
Extreme Memory Profile (X.M.P)..................[ Disabled ]
(G) MCH Frequency Latch.........................[ 333 ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 1174 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[5]
tRCD............................................[5]
tRP.............................................[5]
tRAS............................................[15]
******Advanced Timing Control******
tRRD[4]......................................... auto
tWTR[4].........................................auto
tWR[8]...........................................auto
tRFC[72].........................................(54)
tRTP[4]..........................................auto
Command Rate (cmd)[0]....................auto
******Channel A Timing Settings******
Static tRead Value [ 8 ] ......................auto
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
Static tRead Value [ 8 ] .......................auto
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.2500 ]..........................[ 1.35625 ]
CPU Termination [ 1.200 ]....................[ 1.28 ]
CPU PLL [ 1.500 ]...............................[ 1.50 ]
CPU Reference [ 0.760 ]......................[ 0.863 ]
MCH Core [ 1.100 ].............................[ 1.34 ]
MCH Reference [ 0.760 ]......................[ 0.810 ]
MCH/DRAM Refernce [ 0.900 ]...............[ auto ]
ICH I/O [ 1.500 ].................................[ auto ]
ICH Core [ 1.100 ]...............................[ auto ]
DRAM Voltage [ 1.800 ]........................[ 1.80 ]
DRAM Termination [ 0.900 ]...................[ .90 ]
Channel A Ref [ 0.900 ].......................[ auto ]
Channel B Ref [ 0.900 ]........................[ auto ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
CPU Thermal Monitor.............................[ Enabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Enabled ]
I have tried to get more the past few days, using several different settings and what little I know from reading forums and observing what works and doesn't work in my system. I know the cpu seems to requie less volts than many of you. I spent several weeks testing different bios settings with th hsf, and hit the wall at 4.3g. Frankly, all I know to do is guess and keep trying. Windows 7 doesnt seem to like bios crashes, and I have had to do a complete reinstall from my server several times. If anyone has advise or could point me to a thread that tell the relationship between settings and how to intelligebtly overclock it would be greatly appreciated!
Well guys finally made it :up:
Q9650 vid 1.1875 @ 4905 :D
http://img89.imageshack.us/img89/5637/49051.png
http://img134.imageshack.us/img134/1695/validacion.png
http://valid.canardpc.com/show_oc.php?id=670319
Cheers :up:
Sergio
here you go mate, you have same vid as me should be the same
http://www.xtremesystems.org/forums/...197802&page=96
i posted the template there
Cheers :up:
Sergio
Well DONE. Getting close to 5Ghz
I wish i had a lower VID (Maybe 1.2) . My Chip has a 1,3V VID !!!
Then i could trade some heat for a little less Voltage.
I need 1.45V(in bios) Vcore and 1.38V VTT Just to run 4.25Ghz Stable!!!! But my Max temps are 50 when loading with prime
http://i30.tinypic.com/hsurg9.jpg
How much Vcore do you think these Q9650 can handle on Water?
I have a question. What mb should i get for a q9650? The EP45-UD3P or the EP45T-UD3P. Witch will be best for oc the cpu? Or should i go for a core I7 instead.
Is a I7 worth the extra cash compared to the performance you get from the q9650 at say 4,5ghz.? Just wondering what to go for inn a new build. Going to build inn a lian-li b70, with eighter EP45-UD3P or EP45T-UD3P and q9650.
Or I7 something on a good mb. 2 wc loops and 2 HD 4870x2 cards i think. 2 MCP655 pumps, 2x240 rads or one 2x120 and one 360 rad. Hope it's not to OT..
but you can play further giving volts mate also i see you got an awesome PSU wish i had that you can have real fun with it...i have a low vid and im sharing the loop with the GTX285, higher vid quads require more volts but it's up to everyone if you decide to play with it, on the giga i pumped lots of volts and then my PSU starts shutting down i will swap for a corsair soon.
i benched it till 1,56vcore real / 1,75pll / 1,66vtt and 1,76 MCH and the 2x2 gskills till 2,4
Cheers :up:
Sergio
read napalms here
http://www.xtremesystems.org/forums/...197802&page=99
i think if you gonna hard OC the DQ6, the extreme is better on dividers and needs a vmod and the ud3p is awesome but need more volts
cheers
Sergio
I don't think i'm going to clock it mutch higher than 4,5ghz if i get a new system. Not a oc guru like you guys.. :) And if i need to mod something physicli i think i'll go for the other mb. Only inn the planing stage yet..
Congrats on the 4,9ghz by the way.. It's awsome...
Congrats on the 4900mhz Sergio :up:
Wow they actually released it! With I7 and I5 being released I figured they wouldnt bother with another 775.
OK not 4905 but getting closer Sergio. Very hard in 64bit w7.
http://img32.imageshack.us/img32/4363/4887.png
The price might drop. Hard to say with xeons but it's interesting at least. I'm still on 775 and loving it.
What were those 9550s going for like $150 at microcenter? Geez that would make a nice setup for anyone.
I guess its just a misprint that newegg says that one doesnt support 64bit... right?
I need some input from the ud3p v1.6 users. I have another ud3p comin in tomorrow from the egg, i assume it'll be a 1.6. Anybody know what the difference is between the different revision boards? Something would have to be way different for the 1.6 to use a different bios right?
There you go MrCape they been on sale now for 6 weeks straight at Micro Center:yepp: and there $169.99
http://www.microcenter.com/single_pr...uct_id=0299412
I was using my 24/7 setup as an example. I am 3d stable @ 4.6Ghz but that is with 1.57V (In Windows) but i am unsure of how much more it can take.
How do you now how much VTT to give your cpu? I find if i give it more then a certain percentage of the vcore it stops letting me boot. Is there some sort of stage where it starts to help? Ie: for me at 1.4VTT it is unhappy but maybe above 1.55V it will start helping?
Thanks for your response.
About the PSU. It helped my MAX OC on GPU by 65 MHZ on the core which i was glad about.
damn 1,57 is what i used for 4900 its amazing how different temps are on this chips being a lower vid to a higher
vtt it all depends mate, in my case till 4500 i dont need more than 1,36, but up to there it starts needing it, all depends. You should start to test slowly from a stable setting and then up till you get the most of it stable, then the rest will be bench or just screens.
Cheers mate and good luck :up:
Sergio
