http://www.jedec.org/
Memory is kinda loosey goosey ... there is a consortium organization, whose membership of course includes most all the major memory makers as well as Intel, AMD, nVidia etc. You can find the JEDEC standards for DDR2 memory at that web site.
The voltage for JEDEC standardized DDR2 is 1.8+/-0.1 Volts for DDR2-800, as I recall (and I may be wrong), JEDEC never ratified any specs for memory above this speed... for DDR2 anyway.
Anand has summarized the JEDEC specs for DDR2/DDR3 in this article:
http://www.anandtech.com/printarticle.aspx?i=2989
This of course does not stop memory makers from trying to woowooo your wallet with promises of faster memory or lower latency but outside of the standards -- you will commonly find low latency DDR2 but speced out at 2.0 or higher volts (operating voltage). nVidia even skirts this by the SPD to store special 'overclocked' settings for the memory used in it's SLI certified memory brand.
Nonetheless, Phenom, with the IMC, was likely built to withstand x% above and beyond the JEDEC spec, however it appears that limit is at or below 2.2 volts... so if you are looking for 1067 memory, or even low latency DDR2-800 ... pay attention to the voltage spec.
