only 5:D 2 ud3r's and 3 ud3p's
i3-530's are fun but memory suks
i7-920's are the all around best though
high OC's and great memory performance
1366 setups are monsters machines:D
Anyone know where i can find a good deal on a EP45-UD3P or maybe someones looking to sell one ?
F11c
http://forums.tweaktown.com/gigabyte...tml#post369165
hey radaja
didn't realize you had so many boards.:fact:
I have a UD3R rev 1.0 I'm looking to sell so I can fund the purchase of a Q9550 or Q9650.
someone tested the F11c in UD3P ?
here, still use F10
q9550 @ 4.4 GH with 1.328v
Prime95 about 2 hours on Small fft
http://img715.imageshack.us/img715/4796/442h.jpg
Hello, you tell me any shop which sell the UD3P? and if it can be sent to Spain.
A greeting.
dont think shops carry them anymore.you have to buy used.
i will be selling a couple UD3P's soon.
Does anybody have 550+ stable fsb with quad?
could some one who has successfully done 560fsb+ using a c2d
post the settings used.i can get 560fsb prime95 blend 2hrs stable
but anything above just wont prime for more than 30m.this is with
two UD3R's and one UD3P,they all seem to crap out at 560fsb.
so im wondering if there is some kind of setting im missing that needs
to be adjusted after 560fsb,thanks
:up:Nice work! Can't help ya there, but I would love to see your 560fsb settings. Hell, I'm having trouble getting my E8500 and EP45C-UD3R to even boot at 8x500fsb. Driving me crazy:mad: So I'm stuck at 9.5x400 for now.
heres the 560fsb setting,this works for all three boards using the same ram and cpu.
http://i55.tinypic.com/21lsnzn.jpg
7.5x560@4200 Template
Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: AUTO
CPU Clock Ratio ..........................: 7
Fine CPU Clock Ratio.....................: 0.5
CPU Frequency ...........................: 4.20GHz (560x7.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ...........: 560
PCI Express Frequency (Mhz) ........: [101]
C.I.A.2 ......................................: [Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive..........................: 800mV
PCI Express Clock Drive................: 900mV
CPU Clock Skew (ps)...................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance..................: [TURBO]
Extreme Memory Profile (X.M.P.)....: [Disabled]
(G)MCH Frequency Latch..............: [400]
System Memory Multiplier .............: 2.00D
Memory Frequency (Mhz) .............: 1120
DRAM Timing Selectable ...............: [Manual]
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ........................................: 5
tRP'..........................................: 5
tRAS.........................................: 15
Advanced Timing Control
tRRD....................................: 4 [AUTO]
tWTR...................................: 4 [AUTO]
tWR.....................................: 8 [AUTO]
tRFC....................................: 68 [56]
tRTP....................................: 4 [AUTO]
Command Rate (CMD) ............: 0 [AUTO]
Driving Strength Profiles
Driving Strength ............................[AUTO]
Channel A
Static tRead Value........................: 10 [AUTO]
tRD Phase0 Adjustment..................: 0 [AUTO]
tRD Phase1 Adjustment..................: 0 [AUTO]
tRD Phase2 Adjustment .................: 0 [AUTO]
tRD Phase3 Adjustment..................: 0 [AUTO]
Trd2rd(Different Rank)...................: 8 [AUTO]
Twr2wr(Different Rank)..................: 8 [AUTO]
Twr2rd(Different Rank)...................: 7 [AUTO]
Trd2wr(Same/Diff Rank).................: 9 [AUTO]
Dimm1 Clock Skew Control..............: [AUTO]
Dimm2 Clock Skew Control..............: [AUTO]
DDR Write Training........................: [AUTO]
Channel B
Motherboard Voltage Control
CPU
Load-Line Calibration................: [Enabled]
CPU Vcore..............................: 1.250v [1.38v]
CPU Termination......................: 1.200V [1.34v]
CPU PLL.................................: 1.500V [1.57v]
CPU Reference........................: 0.755V [Normal]
MCH/ICH
MCH Core...............................: 1.100V [1.40v]
MCH Reference........................: 0.760v [0.788v]shows up as 0.70v in ET6
MCH/DRAM Ref.........................: 0.900V [Normal]
ICH I/O..................................: 1.500V [1.50v]
ICH Core................................: 1.100V [1.20v]
DRAM
DRAM Voltage...........................: 1.9v [2.26v]
DRAM Termination ....................: 0.900V [Normal]
Channel A Reference..................: 0.900V [Normal]
Channel B Reference .................: 0.900V [Normal]
Advanced Settings
Limit CPUID Max. to 3......................: [Disabled]
No-Execute Memory Protect..............: [Enabled]
CPU Enhanced Halt (C1E).................: [Enabled]
C2/C2E State Support.....................: [Enabled]
x C4/C4E State Support...................: [Disabled]
CPU Thermal Monitor 2(TM2) ............: [Enabled]
CPU EIST Function..........................: [Enabled]
Virtualization Technology..................: [Disabled]
Have you tried to add some skew like 0, 50 or 50, 50?
not yet,but NoGuru told me the same thing at ocn,so today im going
to play with the cpu and mch skews and also the dimm skews.
still curious as to what vtt and v NB people needed for 600 fsb?
@radaja...Thanks!
no problem:up:
managed 572fsb.this 1.0 board seems to be very nice.
apparently this board doesnt suffer the same problem
the other boards did.
this is without any tweaking yet.just the basic voltages.
maybe this will be 600fsb type of MB:D
settings are the same except for vtt is set to 1.36v
and vNB at 1.42v(also i had mch ref wrong in template)
should be 0.788v
also made a video of the actual bios and boot up for this run
its a little fuzzy but you can still see all the setting in it.
bios settings video
http://i56.tinypic.com/1o51de.jpg
http://i51.tinypic.com/30bi44l.jpg
