Q9550 + LANParty UT X48-T2R incorrect ratio????
Q9550 + LANParty UTX48-T2R stuck at 3.4ghz (8.5x400)
Corsair 4GB DDR2 XMS2 Dominator PC2-8500C5 TwinX
Now the mobo defaults CPU to 2.8 (stock speed yes i know) BUT sticks the RAM at 800Mhz....CPU-Z says this is a 1:1 Ratio
If i up the RAM to 400/1066 then all is good but CPU-Z says its running on 3:4 ratio now.
Why doesnt it run at 400/1066 by default.
I have the RAM in slots 1 & 3 on the mobo.
1 Attachment(s)
How many phases do these boards have in the memory power?
The LANParty UT X48, LT X48, and UT P45 seem to have 4 chokes around the memory. Two on either side. From the processor Buck converter we have become used to one choke per phase.
What does this configuration represent? Separate 2-phase supplies to each bank of 2? A single 4-phase supply? The inductors run in series for a different inductance.
Note that we are used the chokes being the same size. Here, one is 1µH and the other is 1.8µH. On the X48 boards, one of the chokes in each pair doesn't have a cover.
DFI LanParty LT X48 T2R +2st Sapphire HD 4850 problem
I everybody (hi dr nick).
I hope that there is someone out there who will be able to help me. I have a DFI Lanparty LT X48 T2R board and i was running a 8800 GTS 512MB video card but I got a good deal on two Saphire HD 4850 Dual Slot cards (the one that has a new cooler that looks like the intel stock cooler). So i figured I would try running some crossfire action.
Well. I unstalled all Nvidia drivers and installed the Catalyst 8.11 drivers (win XP SP2) and tested the first card. I got some nice results but the fan seems like its running amost full speed all the time. The temperatures are great (40-45 degrees idle) and even if i set fan speed to 20% in CCC, the fan spinns down some, but still sound WWWWAY more then my old 8800 GTS. Anyway i then insrted the secound card and the fan is the same on that card to. I also installed both crossfire bridges. Uninstalled the drivers and reinstalled them. I got a nice little message that told me to enable Crossfire, so i did. I checked GPU-Z and both cards ar listed and crossfire is enabled. However one of the cards run at PCI 4x only. The other run at 16x. Well i started 3dmark03 just to test the performance. The loading screen for the fiorst test was REALLY slow and the test got me about 20-40 fps in 3dmark03! I aborted the test and disabled crossfire and tested 3dmark03 again. Now i get abour 500fps. So it seems normal. I the tried to remove one of the crossfire bridges and this time i get 16x on both cards in GPU-Z but the bad performance still persist. I also unsinstalled the drivers and reinstalled them, no change. I testeted v 8.10, still no diffrence. I have tried the lastest intel chipset drivers. Still the same. Im clueless. I dont know whats wrong. Anyone got any idees?
Which board is better to overclock a E8500 E0?
DFI DK X48-T2RSB Plus or
DFI LT X48-T2R or some other board? :confused:
I have 2 4870 512MBs to crossfire that is why I was considering the X48, also have 4x1GB CellShock D9GKX. :)
I need the highest overall performance for gaming. (so I do not care if I can overclock my ram better if my cpu overclock will suffer) :yepp:
Thank you :up:
