you can go into msconfig and check off "no GUI" boot...that will shorten the boot time.
the other thought is a driver taking its time to load.
Its a bare Vista install I always trash installs with hardware swaps :)
Will see what else I got kickin around in there.....anyone got problems with enabled onboard audio+LAN And this sort of issue?
EDIT: Maximus on 0505 at same settings compared to my P5K Premium is showing some impressive performance gains from an everest standpoint at least :)
so should i enable it?? or not? some one told me if disable it i will get better temps...
The better temps come from the actual applied voltage being lower....
In theory say you set 1.5v after windows load and load on processor it goes to 1.4v yes its going to be cooler, but no its not giving the right voltage.
With it on theoretically 1.5v should stay 1.5v or as near to that as possible.
So keep loadline enabled, whoever told you to disable it is mistaken since you dont want differences(at least that much) from BIOS set voltage to actual windows and usage load voltage.
You dont have my ram, or my chip :)
That 1066 stuff you are using probably cant use those subtimings, might come close but nothing at those voltages. And I have a beast of a G0 quad so only use my settings as a reference not verbatim unless you have similar equipment.
On that note heres the fruits of my labor, the following stuff is 24/7 stable.
http://i11.photobucket.com/albums/a1...x9ddr29003.jpg
http://i11.photobucket.com/albums/a1...8ddr2900-1.jpg
Everest test was run 2x just for consistency sake.
And heres quick comparison (sans the Maximus's subtiming control, and ability to use higher transaction booster settings. P5K premium wouldnt run Transaction well at all, so I used DRAM Static Read)
http://i11.photobucket.com/albums/a1...0x8ddr2900.jpg
You may draw your own conclusions :)
Considerably better read/write and 10ns difference. I would say Maximus is clear winner :)
EDIT: Oh yeah heres the 1M calc :)
http://i11.photobucket.com/albums/a1...nX/Capture.jpg
X38 - 14.359s
P35 - 14.835s
Id say thats a nice improvement.
well i atually change the ram values to :
BIOS 0505
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency :450
FSB Strap to North Bridge :AUTO
PCI-E Frequency: 120
DRAM Frequency: DDR2-900
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : auto
Row Refresh Cycle Time : auto
Write Recovery Time : auto
Read to Precharge Time : auto
Read to Write Delay (S/D) : auto
Write to Read Delay (S) : auto
Write to Read Delay (D) : auto
Read to Read Delay (S) : auto
Read to Read Delay (D) : auto
Write to Write Delay (S) : auto
Write to Write Delay (D) : auto
DRAM Static Read Control: DISABLED
Ai Clock Twister : STRONG
Transaction Booster : ENABLED (2)
CPU Voltage : 1.5v
CPU PLL Voltage : 1.6v
North Bridge Voltage : 1.49v
DRAM Voltage : 2.18v
FSB Termination Voltage : 1.4v
South Bridge Voltage : AUTO
Loadline Calibration : ENABLED
CPU GTL Reference : .63x
North Bridge GTL Reference : AUTO
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : ENABLED
this is how my bios looks
is actually my ram...when ever i run the prime small test. it will run perfect. so it is my ram.... what can i do or what should i do?
should i get new memory?? like the same but a new pack??
Nope... it probably wont change. The difference between your memory, and my memory is about 250$ difference per 2GB kit, and alot more binning as well it was binned for CAS3 DDR2 800.
Just relax some of the settings in your bios, and tweak some voltages and keep trying it. Every rig is going to act differently.
is there any software better than core temp to measure cpu temps??
my mem should be better than your right?
No, at date of purchase my ram was about $900, the Dominator 8500's were only about $500-600 for 4GB kit and are like 2nd from bottom of the dominator lineup.
IMO 9136 and 6400C3 (and I would say my 6400C3's can hold their own against 8888's at 2.4v considering I run 1000 4-4-4-12 at 2.18v) are about on the same playing field, where 8888 and 10000 are high performance.
The binning on 6400C3DFs is alot higher than the 8500s, its considered more of a "performance" part than the 8500s are since my ram will do right up to DDR2 1100 4-4-4-12. 8500s are CAS 5 @ 1066, and my subtimings can be alot tighter given they are higher binned chips...then again in the semiconductor world its all really random from each piece even if it is meticulously binned for performance.
EDIT: Also note, they have discontinued Micron IC's on the 8500 lineup... not sure of the production cutoff date, but the newest kits will not be micron based.
Source:
http://www.xtremesystems.org/Forums/...d.php?t=158651
If you purchased those recently Miguel, check your sticker on the side of your ram...you might not have Micron if they are brand spankin new.
cant make my memory stable :(
You should be perfectly fine mate :)
@Miguel - did you set Transaction booster to 1? or even off you might not be able to run it at all.
Also try this
BIOS 0505
Extreme Tweaker
FSB Frequency :450
PCI-E Frequency: 100
CAS# Latency : 5
RAS# Precharge : 5
RAS# to RAS# Delay : 4
Row Refresh Cycle Time : 30-35 (should work)
Write Recovery Time : 4
Read to Precharge Time : 4
Ai Clock Twister : AUTO
Transaction Booster : AUTO
CPU Voltage : 1.5v (try going lower, run Prime95 on SmallFFT Priority 9 with round off checking to find lowest Vcore setting)
North Bridge Voltage : 1.51v
DRAM Voltage : 2.20v
any questions about that feel free to ask Miguel.
After you find lowest Vcore for your CPU using SmallFFTs from Prime95---- Go ahead and mess around with RAM settings and run Memtest 86+ 1.7 and let it loop 2-3 times and see if it comes up with any red.. if not tweak a little more see if you get any and repeat till you get red. Then relax and try 1 more loop and if your happy with your current timings and voltages then go for a 12-24hr Prime95 Blend with roundoff checking.
the 8500C5D's if they are still micron, if not its a toss up between the 2 kits.
My ram is the 6400C3DF found here.
http://www.newegg.com/Product/Produc...5&Tpk=6400c3df
and yours will be alot better than what i have right now? BTW my is the new version 2.2..
Mmmh I think my CPU isn't really good because I can't pass 460Mhz for the FSB, and I had the same problem with same CPU on the Blitz Formula ...
Is it possible for an E6850 ES to be at maximum at only 460Mhz FSB ?
