Is this right?is anyone using it?Quote:
GA-EP45-UD3P - F7a## bios
GA-EP45-UD3P-F7a
Info: OC Quad Test 450x8x2.40B und 500x8x2.00B...OK
Source :yepp:
Previous page:
Bios F7a instaled, system posts faster, same problem with S3 suspend mode
S3 works fine here....
Why is the EP45-UD3R at F5 and the UD3P at F7 ?
They are pretty much identical, or are they crippling the UD3R?
@stasio , do you work for Gigabyte, thanks for the latest bios.
the boards rock...
Uh I found that it is not a myth ... my Reapers would not work in Dual-Channel. They would only work in single channel mode. At first, when I tried booting ... I thought the board was no good because I had just used those Reapers ... but it is this board and those OCZ PC2 8500 Reapers. Almost RMA'd my RAM as well ... :p:
F7a for me ... working on getting FSB up to 500 on Xeon 3360 (Q9550) still a bit of a go ... but getting there ;)
new ud3 board out that runs ddr3..........http://www.newegg.com/Product/Produc...82E16813128364
they do work ... i try using 1066 ... but need to install with 1 ram ... go in Bios ... set timing and voltage ... then you can boot with 2 ram into window .. after that start tweaking ... i notiice that need to run 333 trap and 2.0 divider to start... but if use 800 .. might need to start with 266 ... good luck
I have a pair of 2x2 GB OCZ reaper PC2-8500. they run just fine in dual channel. (F5 bios)
I hope everyone's been checking the New DDR2 Speed Records being set with these new UD3 boards.
It would be sweet if they had an "Air Only" catigory for those of us who don't use LN2 or Dice...
But still want to burn up some ram... :woot:
Now it seems that Air is the Extreme because lots of people are able to use Monster Cooling...
Opps ~ just kidding :surf:
First release of EP45-UD3R is F3 and EP45-UD3P is F4,right.Quote:
As UD3P is top model,normally all testing and release first is for this board.
Somebody want to try UD3P-F6
just wanted to inform you that my raid didnt work anymore after i flashed the 7a bios. had to recreate it then it worked fine.
Black Friday deal...
$99.99 after rebate
http://www.newegg.com/Product/Produc...82E16813128358
I ordered my GA-EP45-UD3P today!:cool:
