Okay I'll set those right now.Quote:
Changes/Things that you missed are displayed in red color
Code:PSU ( Power Supply Unit ) = Corsair TX650W Power Supply
CPU = Intel Core 2 Quad Q9450
RAM = OCZ DDR3 Platinum PC2-14400
HDD ( the one where you have your windows installation on ) = Western Digital SATAII 16mb cache 250GB
VGA1 = Nvidia BFG Geforce 8800 GTX OC2
SPU ( Sound Card ) = Creative X-Fi XtremeGamer Professional
NorthBridge Cooling = Default
SouthBridge Cooling = Default
CPU Cooling = Thermalright 120 Extreme
RAM Cooling = OCZ RAM Cooler
nFORCE Chipset Drivers Version = 9.64
ForceWare/GeForce Drivers Version = 175.80
Sound Card Drivers Version = 6.0.1.1304(???)
BIOS version 0801
BIOS Settings
Extreme Tweaker
CPU Level Up = Auto
Memory Level Up = Auto
AI Overclock Tuner = Manual
CPU Multiplier = x8
FSB - Memory Clock Mode = Unlinked
FSB - Memory Ratio = N/A
FSB (QDR) MHz = 1800
MEM (DDR) MHz = 1600
LDT Frequency = x5
PCIE Bus Slot 1 & 2 MHz = 100
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = Auto
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 = Enabled
P2 = Enabled
tCL ( CAS Latency ) = 7
tRCD = 7
tRP = 7
tRAS = 24
Command Per Clock (CMD) = 2T
tRRD = Auto (5)
tRC = Auto (33)
tWR = Auto (12)
tWTR = 25
tFAW = 31
tRD = Auto (9)
tRTP = Auto (6)
tRFC = Auto (72)
tREF = Auto (7.8uS)
Over Voltage
CPU Voltage = 1.3500
Loadline Calibration = Enabled
CPU PLL Voltage = 1.50
CPU VTT Voltage = 1.40
Memory Voltage = 1.76
NB Core Voltage = 1.56
SB Core Voltage = 1.60V
CPU GTL REF0 Ratio = -36
CPU GTL REF1 Ratio = -40
CPU GTL REF2 Ratio = -40
CPU GTL REF3 Ratio = -36
NB GTL REF Ratio = +40
DDR3 CHA1 Ref Volt = Auto
DDR3 CHB1 Ref Volt = Auto
DDR3 CHA2 Ref Volt = Auto
DDR3 CHB2 Ref Volt = Auto
CPU Configuration
CPU Internal Thermal Control = Disabled
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled
Execute Disable Bit = Disabled
Virtualization Technology = Disabled
Enhanced Intel SpeedStep(tm) Tech. = Disabled
CPU Core 2 = Enabled
CPU Core 3 = Enabled
CPU Core 4 = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum = Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
