The HDD rack is well built it is hard to describe but there is the shell that house the drives, then they have 2 metal panel that fit on the side and use rubber mounts..this panel is what you are placing the screws in.....
http://www.specialtech.co.uk/spshop/...53&page=1#tabs
best pics
http://www.dreamwarecomputers.com/re...p51/index2.htm
I did remove the stupid perforated panels behind the fan for better airflow..the fan is very quiet
Turn the HDDs around...that probably would work then you could run the cables through the bottom of the HDD rack ..Hmm
Damn you ..now I need to buy more cables...the power sata cable with our psu should fit through perforation in the bottom of the rack...hmm..looking at pics not sure if they will fit
still dont think there is a way for the dvdrw cables to pass ok...unless you modd the cage with holes...
