Need some help with stability
Hello,
My setup has been working fine but lately has become a slight bit unstable ( sudden reboot when doing some firefox functions). So I adjusted a bit and ran orthos stability test (small) and it only lasted about 4 hours. I included my settings, please let me know what I should adjust to attain stability again. Thanks for your inputs.
Clock 4420.3
Temp Idle 38
Temp Load 55
Orthos Stable 3 hr 40 min
Ai Overclock Tuner Manual
OC From CPU Level Up Auto
CPU Ratio Control Manual
Ratio CMOS Setting 8.5
FSB Frequency 520
CPU Clock Skew Auto
North Bridge Clock Skew Auto
FSB Strap to North Bridge 333
DRAM Frequency DDR2-1042MHz
Dram Clock Skew CH1 A1 Auto
DRAM Clock Skew CH1 A2 Auto
Dram Clock Skew CH1 B1 Auto
Dram Clock Skew CH1 B2 Auto
DRAM Timing Control Manual
1st Information 5-5-5-15-3-52-6-3
CAS# Latency 5
DRAM RAS# to CAS# Delay 5
DRAM RAS# Precharge 5
DRAM RAS# Activate to Precharge 15
RAS# to RAS# Delay Auto
Row Refresh Cycle Time Auto
Write Recovery Time Auto
Read to Precharge Time Auto
2nd Information 8-3-5-4-6-4-6
Read to Write Delay (S/D) Auto
Write to Read Delay (S) Auto
Write to Read Delay (D) Auto
Read to Read Delay (S) Auto
Read to Read Delay (D) Auto
Write to Write Delay (S) Auto
Write to Write Delay (D) Auto
3rd Information 14-5-1-6-6
Write to PRE Delay Auto
Read to PRE Delay Auto
PRE to PRE Delay Auto
ALL PRE to ACT Delay Auto
ALL PRE to REF Delay Auto
DRAM Static Read Control Disabled
Dram Read Training Disabled
MEM OC Charger Enabled
Ai Clock Twister Auto
Transaction Booster Manual
Common Performance Level 11
Pull-In of CHA PH1 Enabled
Pull-In of CHA PH2 Enabled
Pull-In of CHA PH3 Enabled
Pull-In of CHA PH4 Enabled
Pull-In of CHA PH5 Enabled
Pull-In of CHB PH1 Enabled
Pull-In of CHB PH2 Enabled
Pull-In of CHB PH3 Enabled
Pull-In of CHB PH4 Enabled
Pull-In of CHB PH5 Enabled
PCIE Frequency 100
CPU Voltage 1.41875
CPU-Z Core Voltage 1.408
CPU PLL Voltage 1.59275
FSB Termination Voltage 1.27225
DRAM Voltage 2.15775
North Bridge Voltage 1.48425
South Bridge Voltage 1.5 1.5
South Bridge Voltage 1.1 1.1
CPU GTL Reference 0 Auto
CPU GTL Reference 1 -40mV
CPU GTL Reference 2 Auto
CPU GTL Reference 3 -40mV
North Bridge GTL Reference Auto
DDR2 Channel A REF Voltage Auto
DDR2 Channel B REF Voltage Auto
North Bridge DDR Reference Auto
CPU Configuration
C1E Support Disabled
Max CPUID Value Limit Disabled
Intel Virtualization Tech Enabled
CPU TM Function Disabled
Execute Disable Bit Disabled
Load Line Calibration Enabled
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
