Originally Posted by Wikipedia, talking about XOP
Compatibility issues:
AMD has changed the encoding from the original SSE5 specification in order to improve compatibility with Intel's AVX instruction set and the new VEX coding scheme.
All SSE5 instructions that were equivalent or similar to instructions in the AVX and FMA4 instruction sets announced by Intel have been changed to use the coding proposed by Intel. Integer instructions without equivalents in AVX were classified as the XOP extension.[3] The XOP instructions have an opcode byte 8F (hexadecimal), but otherwise almost identical coding scheme as AVX with the 3-byte VEX prefix.
Commentators[4] have seen this as evidence that Intel has not allowed AMD to use any part of the large VEX coding space. AMD has been forced to use different codes in order to avoid using any code combination that Intel might possibly be using in their development pipeline for something else. The XOP coding scheme is as close to the VEX scheme as technically possible without risking that the AMD codes overlap with any future Intel codes. It must be noted that this inference is speculative, since no public information is available about negotiations between the two companies on this issue.
The use of the 8F byte requires that the m-bits (see VEX coding scheme) have a value bigger than or equal to 8 in order to avoid overlap with existing instructions. The C4 byte used in the VEX scheme has no such restriction. This may prevent the use of the m-bits for other purposes in the future in the XOP scheme, but not in the VEX scheme. Another possible problem is that the pp bits have the value 00 in the XOP scheme, while they have the value 01 in the VEX scheme for instructions that have no legacy equivalent. This may complicate the use of the pp bits for other purposes in the future.
A similar compatibility issue is the difference between the FMA3 and FMA4 instruction sets. Intel initially proposed FMA4 in AVX/FMA specification version 3 to supersede the 3-operand FMA proposed by AMD in SSE5. After AMD adopted FMA4, however, Intel canceled FMA4 support and reverted back to FMA3 in the AVX/FMA specification version 5.[5][6][7]
