I finally got around to get this template for you guys, sorry the delay...
This setup came with the summer. I know I was already with 4700Mhz stable setup but this 4500Mhz/4Gb_1200DDR2 is good because of the low voltages and maybe possible on AIR with good Hs's out there. the mem's used where the well known G.Skill's PI edition (4Gb).
Volts used: 1.32vcore / 1.34vtt / 1.50pll / 2.0vdimm / 1.40mch
CPU Cooling: WC Swiftech MCR : Thermalright XWB-1 : MCP655 : NBM-MAT 120mm Fans : 15000 BTU AC in the Room
Bios: F8. (works with any BIOS actually).
This also proves that degradation on these Quads is almost a Myth, this CPU is the same I had from the start and every time I prime95 an old setup I had it just blows the barrier of low voltages all the time. I need less and less voltages to achieve same clocks. This same cpu and gskill had to endure this to be here:
http://www.xtremesystems.org/forums/...d.php?t=227129 :ROTF:
I always try to send as many pics of the entire testing process (beginning/middle/end) because it shows the real voltage used with all the tests.
[Prime95 Blend Started: EP45-UD3P + Q9650@4500Mhz + 4Gb_DDR2@1200Mhz PL8]
Please notice the time stamps and uptime on Everest OSD Panel:
http://i43.tinypic.com/1567i3p.jpg
Prime95 12hrs:
http://i42.tinypic.com/3580too.jpg
Final test: IBT 15 passes & 3DMark:
http://i39.tinypic.com/2nkmo3l.jpg
[BIOS Settings]
Note: This was achieved using ALL the power saving options enabled.
http://i41.tinypic.com/2cf3vdf.jpg................http://i39.tinypic.com/34x6o.jpg
http://i40.tinypic.com/21dkb3m.jpg................http://i41.tinypic.com/2z4ljjt.jpg
http://i43.tinypic.com/mhdgxw.jpg
Some settings will be hardware specific, like CPU and MCH ref and also memory settings will vary according to what your ram is capable of.
:up:
