Change your RAM to 1:1 and PL to 9
Great results everyone!
Have some questions to ask. The bios vcore's set to 1.33, but in cpuz, my cpu vcore under load's reflected as 1.30. Which is the true reading?
So i got my q9550 to 471x8.5 stable @ 1.3v (cpuz), but i suspect it could be lower - i'm still quite lost with all the mch/vtt settings. I noticed that at 471FSB, my chip is unstable as hell if my mch is @ 1.3, but once i bump the MCH up to 1.32, it runs 50 rounds of LinX w/o issues.
Any ideas how i can proceed from here to tweak the oc?
Here ya go, 500*9 @ 1250 5-5-5-15 PL8 in standard mode. Ill run it in turbo later to see if it makes a difference, last time I checked it was only maybe 1 sec faster than standard and virtually no difference in bandwidth. I only have the trial version of everest so I cant post the pretty blue benchmark screen. :( If you really want I can post pics of the individual tests, but its does 10423 R, 10640 W, 10789 C and 49.2 L. :up:
http://i131.photobucket.com/albums/p...mapImage8b.jpg
Thank you, much apprecieted, :up: :) really nice to see a DDR2 vs DDR3 P45 comparison with a Q9650 and 2x2Gb ram and both in Windows 7 RC 64bit, if Iīm not misstaken.
So 500 4,5 2x2 DDR3-1600 777 21 tRD9 does almost perform the same as 500 4,5 2x2 DDR2-1250 555 15 tRD8 with Super Pi 32M, itīs pretty close I most say and so is the bandwidth and latency.
Do you care to run some more comparison tests, we stay with the same CPU bus, clock and memory speed as in Super Pi, should be nice to have a test that responds well on ram bandwidth and latency, any suggestions.
My first run was in diagnostic startup mode with Windows 7 RC 64bit (less change to corrupt when run tests) but I did a rerun i normal startup mode to see if it was different but it wasnīt, it was within 1sec.
http://i282.photobucket.com/albums/k...tRD9Turb-2.jpg
Im on 7201 which is probably not going to make a difference vs 7100. This is with the same settings as before just on turbo mode instead of standard. Its only a half second faster so it still doesnt seem like turbo does any good vs standard, bandwidth is also basically the same.
http://i131.photobucket.com/albums/p...apImage11h.jpg
Nice work Hoss331. Would you mind posting your bios settings using this template? Thanks a lot!! Again Great Job!!
Code:******Gigabyte EP45 UD3P******
Robust Graphics Booster.........................[ ]
CPU Clock Ratio.................................[ ]
Fine CPU Clock Ratio............................[ ]
CPU Frequency 4.25GHz...........................[ ]
******Clock Chip Control******
CPU Host Clock Control..........................[ ]
CPU Host Frequency (Mhz)........................[ ]
PCI Express Frequency (Mhz).....................[ ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ ]
PCI Express Clock Drive.........................[ ]
CPU Clock Skew..................................[ ]
MCH Clock Skew..................................[ ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ ]
(G) MCH Frequency Latch.........................[ ]
System Memory Multipler.........................[ ]
Memory Frequency 1066...........................[ ]
DRAM Timing Selectable..........................[ ]
CAS Latency Time................................[ ]
tRCD............................................[ ]
tRP.............................................[ ]
tRAS............................................[ ]
******Advanced Timing Control******
tRRD............................................[ ]
tWTR............................................[ ]
tWR.............................................[ ]
tRFC............................................[ ]
tRTP............................................[ ]
Command Rate (cmd)..............................[ ]
******Channel A and B Timing Settings******
Static tRead Value [ 0 ] ................[ ]
tRD Phase0 Adjustment [ 0 ] ................[ ]
tRD Phase1 Adjustment [ 0 ] ................[ ]
tRD Phase2 Adjustment [ 0 ] ................[ ]
tRD Phase3 Adjustment [ 0 ] ................[ ]
tRD 2rd (Differnt Rank) [ 0 ] ................[ ]
tWR 2wr (Differnt Rank) [ 0 ] ................[ ]
tWR 2rd (Differnt Rank) [ 0 ] ................[ ]
tRD 2wr (Same/Difft Rank) [ 0 ] ................[ ]
Dimm 1 Clock Skew Control.......................[ ]
Dimm 2 Clock Skew Control.......................[ ]
DDR Write Training..............................[ ]
******Channel A and B Driving Settings******
Drive Strength Profile..........................[ ]
Data Driving Pull Up Level......................[ ]
cmd Driving Pull Up Level.......................[ ]
ctrl Driving Pull Up Level......................[ ]
clk Driving Pull Up Level.......................[ ]
Data Driving Pull Down Level....................[ ]
cmd Driving Pull Down Level.....................[ ]
ctrl Driving Pull Down Level....................[ ]
clk Driving Pull Down Level.....................[ ]
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.25000 ]...................[ ]
CPU Termination [ 1.20 ]...................[ ]
CPU PLL [ 1.50 ]...................[ ]
CPU Reference [ 0.760 ]...................[ ]
MCH Core [1.100 ]...................[ ]
MCH Reference [0.760 ]...................[ ]
MCH/DRAM Refernce [0.900 ]...................[ ]
ICH I/O [1.500 ]...................[ ]
ICH Core [1.100 ]...................[ ]
DRAM Voltage [1.800 ]...................[ ]
DRAM Termination [0.900 ]...................[ ]
Channel A Ref [0.900 ]...................[ ]
Channel B Ref [0.900 ]...................[ ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ ]
No-Execute memory Protect.......................[ ]
CPU Enhance Halt (CIE)..........................[ ]
C2/C2E State Support............................[ ]
C4/C4E State Support............................[ ]
CPU Thermal Monitor.............................[ ]
CPU EIST Function...............................[ ]
Virtualization Technology.......................[ ]
I was having trouble with a UD3P, would get bsod with any OC, ran fine before. Switched out all hardware, tried different case thinking it was a wire grounduing out. Today i get a new UD3P (not an RMA, ordered a new one), put everything together and same thing, boots fine at stock only. tried 2 cpu's 3 sets of ram, different gfx card, 2 different HDD's one with a fresh install, flashed bios. Left the back off of the case to have axcess to all case wires, I tried unplugging fan wires 1 at a time, restart try different wires, and still will not oc. I am stumped. Anyone have any ideas what may be causing this?
Thanks, this is what I used for the spi 32m and prime runs. Its not final yet since im still playing with the ram. :up:
more playing ram at 1275Code:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ + 0.0 ]
CPU Frequency 4.5GHz............................[ 500 x 9.0]
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 500 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 50ps ]
Performance Enhance.............................[ Standard ]
(G) MCH Frequency Latch.........................[ 266 ]
System Memory Multipler.........................[ 2.50A ]
Memory Frequency 1066...........................[ 1250 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
tRRD[3].........................................[ 3 ]
tWTR[3].........................................[ 3 ]
tWR[6]..........................................[ 6 ]
tRFC[54]........................................[ 54 ]
tRTP[3].........................................[ 3 ]
Command Rate (cmd)[0]...........................[ 2T ]
******Channel A Timing Settings******
Static tRead Value [ 8 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ 1200 ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.15 ]...................[ 1.40625 ]
CPU Termination [ 1.20 ]...................[ 1.300 ]
CPU PLL [ 1.50 ]...................[ 1.500 ]
CPU Reference [ 0.760 ]...................[ 0.848 ]
MCH Core [ 1.100 ]...................[ 1.400 ]
MCH Reference [ 0.760 ]...................[ 0.863 ]
MCH/DRAM Refernce [ 0.900 ]...................[ 0.970 ]
ICH I/O [ 1.500 ]...................[ 1.500 ]
ICH Core [ 1.100 ]...................[ 1.100 ]
DRAM Voltage [ 1.800 ]...................[ 1.940 ]
DRAM Termination [ 0.900 ]...................[ 0.970 ]
Channel A Ref [ 0.900 ]...................[ 0.970 ]
Channel B Ref [ 0.900 ]...................[ 0.970 ]
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
http://i131.photobucket.com/albums/p...apImage14b.jpg
Great price on the q9550, + free shipping. http://www.newegg.com/Product/Produc..._-Pst04Descrip
Yes! finally I succeeded in running 4500MHz stable. I decided to give it another try, this time with an AC unit blowing in direction of my watercooling rig.
I managed to get my temps down a bit
Before I was runing LinX with 31/ 31/ 37 (stuck) / 29 idle and 81/ 79/ 76/ 76 stressed
But with the AC unit blowing I got 25 / 29 (stuck) / 37 (stuck) /22 idle and 74 / 74 / 71 / 71 stressed
http://www.plaatjesupload.nl/bekijk/...734301-250.jpg
I could even lower vCore a bit, down to 1.425v
http://www.plaatjesupload.nl/bekijk/...735020-050.jpg
So lower ambient temps are key for me running 4500MHz.
After W7 is installed this evening I'll do a Everest run for comparing bandwidth and latency with Ghostleader and Hoss :)
Just some fun run on windows 7 7201 :D
http://img19.imageshack.us/img19/390...pi32x1run4.jpg
Cheers :up:
Sergio
Awesome work andresergio!!! Would you mind posting your bios template as well? Thanks so much!! Here is a template you can C&P
C.I.A 2 [Disabled]
Virtualization Technology.......................[ ]__________________
Can someone help me with this issue...I had to scale back my 4.45Ghz OC due to the heat of summer, which left me testing stability at a lower OC, which I havent tested before.
Anyways, I could pass over 10minutes of small FFts P95 before error, yet when I run Blend I can only run 23sec, 3min, 6min or below I get errors (it always varies). Now you would think, raise MCH, raise Vdimm, check RAM subtimings, play with GTLs, check Trd, etc. None of any changing of these options helped, in fact I can run only 1.16MCH, and 1.8Vdimm and pass memtest86 test 5.
So I finally and very reluctantly upped my Vcore, which solved the problem...WHATS that all about??? The first 16minutes of P95 tests RAM and MCH, yet I was failing that area, and passing over 10minutes of the most stressful CPU test (small FFTs).
Anyone see any issues or problems?
CPU Clock Ratio.................................[ 10 ]
CPU Frequency 4.15GHz............................[ 415 x 10]
CPU Host Frequency (Mhz)........................[ 415 ]
CPU Clock Drive.................................[ 900mv ]
PCI Express Clock Drive.........................[ 800mv ]
CPU Clock Skew..................................[ 50ps ]
Performance Enhance.............................[ Turbo ]
(G) MCH Frequency Latch.........................[ 333 ]
System Memory Multipler.........................[ 2.00B ]
Memory Frequency 800............................[ 830 ]
CAS Latency Time................................[ 4 ]
tRCD............................................[ 4 ]
tRP.............................................[ 4 ]
tRAS............................................[ 12 ]
tRRD[3].........................................[ Auto ]
tWTR[3].........................................[ Auto ]
tWR[6]..........................................[ Auto ]
tRFC[54]........................................[ 52 ]
tRTP[3].........................................[ Auto ]
Drive Strength Profile..........................[ Auto ]
CPU Vcore [ 1.216 ]...................[ 1.2375 ]
CPU Termination [ 1.20 ]...................[ 1.200 ]
CPU Reference [ 0.760 ]...................[ 0.7600 ]
MCH Core [ 1.100 ]...................[ 1.28 ]
MCH Reference [ 0.760 ]...................[ 0.6800 ]
MCH/DRAM Refernce [ 0.900 ]...................[ Auto ]
ICH I/O [ 1.500 ]...................[ Auto ]
ICH Core [ 1.100 ]...................[ Auto ]
DRAM Voltage [ 1.800 ]...................[ 1.860 ]
DRAM Termination [ 0.900 ]...................[ Auto ]
Channel A Ref [ 0.900 ]...................[ Auto ]
Channel B Ref [ 0.900 ]...................[ Auto ]
I have had that happen also, makes it hard to figure out what v needs to be increased. I have no idea why it happens.
no problem mate keep in mind that its just stable on SPI32 and CRYSIS 64 and all other games, as its a low vid 1,1875 can't ibt it...im just playing till 4700 (will be my next)
sorry this is my first time i fill a template
cheers :up:Code:******Gigabyte EP45 UD3P******
Robust Graphics Booster.........................[ Turbo ]
CPU Clock Ratio.................................[ 9x ]
CPU Frequency 4.60Hz...........................[512x9]
CPU Host Clock Control..........................[ enabled ]
CPU Host Frequency (Mhz)........................[ 512 ]
PCI Express Frequency (Mhz).....................[ 102 ]
C.I.A 2 [Disabled]
PCI Express Clock Drive.......................[ 900mv ]
CPU Clock Skew.................................[ 0ps ]
MCH Clock Skew................................[ 50ps ]
Performance Enhance [Turbo]
Extreme Memory Profile (XMP)..................[profile1]
(G) MCH Frequency Latch........................[333mhz ]
System Memory Multipler.........................[2.40B ]
Memory Frequency 1066.........................[1229]
DRAM Timing Selectable..........................[manual]
CAS Latency Time..........................[ 5 ]
tRP..............................................[ 5 ]
tRRD............................................[ 3 ]
tWTR...........................................[ 3 ]
tWR.............................................[ 4 ]
tRFC............................................[ 50 ]
tRTP............................................[ 3 ]
Command Rate (cmd)..............................[ auto ]
Static tRead Value [ 0 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ auto ]
tRD Phase1 Adjustment [ 0 ] ................[ auto ]
tRD Phase2 Adjustment [ 0 ] ................[ auto ]
tRD Phase3 Adjustment [ 0 ] ................[ auto ]
tRD 2rd (Differnt Rank) [ 0 ] ..................[ 9 ]
tWR 2wr (Differnt Rank) [ 0 ] .................[ 7 ]
tWR 2rd (Differnt Rank) [ 0 ] .................[ 8 ]
tRD 2wr (Same/Difft Rank) [ 0 ] ................[ 8 ]
Dimm 1 Clock Skew Control.......................[auto]
Dimm 2 Clock Skew Control.......................[auto]
DDR Write Training..................................[auto ]
Drive Strength Profile.........................[auto]
Data Driving Pull Up Level....................[auto]
cmd Driving Pull Up Level.....................[auto]
ctrl Driving Pull Up Level......................[auto]
clk Driving Pull Up Level.......................[auto]
Data Driving Pull Down Level..................[auto]
cmd Driving Pull Down Level...................[auto]
ctrl Driving Pull Down Level....................[auto]
clk Driving Pull Down Level.....................[auto]
CPU Vcore [ 1.18750 ]...................[1,43750v ]
CPU Termination [ 1.20 ]...................[1,38 ]
CPU PLL [ 1.50 ]................... [1,57 ]
CPU Reference [ 0.760 ]..................[0,899 ]
MCH Core [1.100 ]...................[1,46 ]
MCH Reference [0.760 ].................[0,914]
MCH/DRAM Refernce [0.900 ]..............[auto]
ICH I/O [1.500 ]...................[1,500 ]
ICH Core [1.100 ]..................[1,200 ]
DRAM Voltage [1.800 ]..................[2,22 ]
DRAM Termination [0.900 ].................[auto ]
Channel A Ref [0.900 ]...................[auto ]
Channel B Ref [0.900 ]...................[auto ]
ALL DISABLED...
No-Execute memory Protect..................[ ]
CPU Enhance Halt (CIE)........................[ ]
C2/C2E State Support..........................[ ]
C4/C4E State Support..........................[ ]
CPU Thermal Monitor............................[ ]
CPU EIST Function..............................[ ]
Virtualization Technology......................[ ]
Sergio
Thats an awesome CPU andressergio, great job with 512fsb.
QX9650 at 515x8.5 waku by Dtek-Fuzion & TripleRad
Gigabyte EP45-UD3P (air + 90cfm fan)
Gigabyte HD4670
2 x 1024mb Crucial BallistiX Tracer pc2-8500
Corsair HX1000
http://www.pctunerup.com/up//results... prio-norm.PNG
I have this complete MIPS Freezer Kit (POM) that I organized the group purchase here:
http://i566.photobucket.com/albums/s...R/bd94b66d.jpg
http://www.xtremesystems.org/forums/...d.php?t=210836
It's still in box never used, I will post on sale here in XS and eBay.
Interested please PM me.
Thanks a lot! I've been running my 9650 at 4500mhz for as long as this board has been out. I never have any blue screens, locks, restarts, absolutley no stability issues at all. Yet i cant complete P95 or Intel Burn test for any length of time. At this point, it doesnt really matter a whole lot because it does what i want it to do. I just want to try other peoples settings to see what happens. If i'm not mistaken, your 24/7 Clock is 4500mhz right? Do you mind posting your settings for that as well? or maybe just let me know what is different from your above post. Thanks again and i will try your settings now.
Hey guys need a bit of help weird problem not sure when maybe after vista 64 sp2 update my lan started acting up , it disconnects when im in utorrent .. tested router other pcs on network, seems to be isolated to my pc so next I put in a old linksys nic 100 card , I mean this thing this is from like 2000 lmao and its running better than my onboard lans , cant properly check on my dual boot windows 7 cause the utorrent wont work at all cuase of compatibility problems ... so could it be mine lan going bad could it be a setting or is it a sp2 problem , redid newest drivers also and tried both lans , work fine under regular usage in firefox with internet download manager
Update : so far my old lan card is doing much better ill get some screen pics up
I think for sure its a compatibility problem with the new realtek lan drivers and Vista 64 sp2 and not a hardware problem , maybe look into getting a good lan card for like 20 bucks
I finally got My Cpu Stable enough at 4.6Ghz(with 8 Gigs of ram) to run Vnatgae and 3d Mark06 in Win 7 7201
http://i43.tinypic.com/53qlck.jpg
Physics disabled in Vantage
http://i43.tinypic.com/v8j4m1.jpg
Thanks to everyone who helped me get this :up:
I still have to see if i can bring vcore down. But my cpu likes lots of volts compared to what everyone one else is using. But my temps are still good
