I swapped to other BIOS chip using BIOS 1901 and 1:2 divider is working now. I took the cpuz SS then tried to run everest and it crashed unfortunately.
678 MHz CL5 @ 2.45v
http://i720.photobucket.com/albums/w...678mhz245v.jpg
678 MHz CL5 @ 2.45v
Stop teasing us with ya mad rams ! but really Everest shows awesome bandwith etc but this is hardly reflected in eg Superpi32... I take everest with a BIG grain of salt !
Hehe sorry about that!
Yes Everest is just synthetic, it's nice for a quick demo but I also prefer something real like 32M to show performance. In my experience the M2F just can't pass SPI32M over 534 FSB / 640 MHz PL8. I have a feeling the MCH is at it's limit around there.
I'm fighting the P45 UD3P at the moment mate, stuck there at 570FSB Hyperpi 32Mb stable, 575 always gives me one error after each pass, tried zillions of combinations (volts, GTL's, PL's, timings,... ), other rams etc... think it's the limit of my board's chipset... it has to end somewhere lol
Yeah its tricky sometimes to make it pass, I assume that's on 1:1? I can get 550 FSB 1:1 PL 10 to pass but over that it falls part rapidly, same on my P5Q-Deluxe. Skews really helped me with stability, delay 150ps on each channel was the optimal setting at 534 - 542 FSB & 640 - 651 MHz ram with PL 8.
Ok, so Quad cores and the MIIF board don't mix. What CPU are you using to achieve these high FSB's??? 8600??? I figure if I'm going to keep this board I might as well, get a CPU that I can have fun with. 480fsb with a quad is nice but 600+++ would be like heaven!
Simonix is usiing an 8600 see his valid link: Here
The MIIF does fine w/ quads, and for 24/7 you aren't going to get much higher clocks from a dual than a quad (4.2-4.4GHz vs 4.0-4.2GHz). So, ~200Mhz higher w/ the duals, but half the cores.
If you're just talking about benching then yes, the duals can be a lot more fun. You can get near the same results w/ an E8400 E0 as you can w/ the E8600, though, unless you get some extreme cooling. The E8400 has a 9x multi, and if you can get 600FSB then that puts you at 5.4GHz. You're well into extreme cooling at that speed, and the extra multi wouldn't be any good for anything else.
The main thing you want to do if you're shopping for a good dual to play w/ is to try and get a really good batch from somebody. A used chip that is a proven good OCer, or perhaps go to a store that lets you sift through the boxes to find a good batch. It doesn't matter if it's an E0 E8400, E8500, or E8600 as long as you get a really good batch.
I think you'll need DI or LN2 for that speed, and it wouldn't be 24/7 in any case. All these high FSB speeds you're seeing are not 24/7 stable. I haven't done a lot of duallie super-high FSB 24/7 testing, but I'd say 533 would be getting near the limit for 24/7 stability. Maybe 550-575 if you're lucky. But then you can't run anything but a 1:1 divider, and have to settle for a looser PL.
9x500 w/ 5:6 divider and PL=8 Stronger is a good goal to reach for.
Gotcha. Makes a lot more sense now.
Someone mentioned how the PL levels on the P45 were 1 number higher for the same value on P35/X38/X48. So, PL=7 on X38 is the same as PL=8 on P45. That being said, I was able to hit PL=6 at similar RAM speeds on my P35 P5K-Premium, and have to use PL=8 on my MIIF. Didn't need pull-ins to do it, but the 90nm chipset boards definitely had an advantage w/ bandwidth.
guys i need to change dissipation system on my M2F..ni got really nice results but NB temp are too high..i could even go on in OC if i reduce my temps..
what aftermarket cooler could i use for SB and NB ?
noctua NC U6 fit into NB without hurts ram slots ? no problem for Sb i think, even blue ice cooler is sufficient for SB.
i have even seen extreme sprit 2 by thermaltake that is smaller but i don't know if it's able to dissipate well.. i want to replace all pipes on my board ..i'm 55 °C on NB in idle :down:
Exteme spirit works well and is a cost effective soloution alittle noisey tho if you dont run it on a fan controller.
Vantec icberq copper cooler works very well with slight mod to mounting holes and looks nice
Cannot comment on the noctua, but I do recall someone posting that it works but not sure if it was this board or not..
So, I've been running stability tests on my MIIF, Q9650, & DDR2 1000 - I was having trouble completing SuperPI and HyperPI but it was stable for 12hrs blend on Prime95 @ 480fsb ... I thought it was ok. I recently tried IBT & it failed. I reset my bios and all settings go default and it still fails IBT I am currently running HCI memtest to recheck ram. I was running 1.43v on the core to run the 480fsb (8.5multi) - could the CPU be failing or the mobo?
EDIT: How about an E8600 for this board? I've decided to run my other quad with my UD3R board. What fsb could I expect with an E8600 in a 24/7 scenario? Also heard there is an E8700 coming out, any idea when or is it bs?
8700 is due out soon I think..
To switch from a quad to a dualie I think you will regret it.
I have a 8400 on my second MIIF and its a dog compared to the 4.2GHz Q9650.
480fsb is very doable on this board, It took me 20 mins maybe to dial in my 4.2GHz settings, all my chips will do 500FSB on this board.
I would recheck your settings
This is my 4200MHz setup
http://i237.photobucket.com/albums/f...200_10loop.jpg
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 467
CPU Clock Skew : Advanced 100ps
North Bridge Clock Skew : Advanced 100ps
DRAM Frequency: DDR2-1121
Dram Clock Skew CH1 A1 : Normal
DRAM Clock Skew CH1 A2 : Normal
Dram Clock Skew CH1 B1 : Normal
Dram Clock Skew CH1 B2 : Normal
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 55
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: Enabled
Dram Read Training : Disabled
MEM OC Charger : Enabled
Ai Clock Twister : Stronger
Transaction Booster : Manual
Common Performance Level [8]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
PCIE Frequency : 103
CPU Voltage : 1.325
CPU PLL Voltage : 1.59275
FSBT : 1.37825
DRAM Voltage : 1.9
North Bridge Voltage : 1.45775
South Bridge Voltage 1.5 : 1.55300
South Bridge Voltage 1.1 : 1.20600
CPU GTL Reference 0 : Auto
CPU GTL Reference 1 : -45mv
CPU GTL Reference 2 : Auto
CPU GTL Reference 3 : -45mv
North Bridge GTL Reference : AUTO
North Bridge DDR Reference : AUTO
Load Line Calabration : Enabled
CPU Sread Spectrum : Disabled
That all seems to be working except for my memory sub timings are on auto and I have to use PL 10 with the DDR2 1000 I am running 1:1 btw
I am testing currently using Prime95 blend, then I'm going to test with IBT - I've never seen what you have for results with your IBT screenie, what did you do? btw, my system will not pass the "max stress" test under IBT
EDIT: ah poop, failed both Prime blend & OCCT - upping vcore to 1.38 vtt to 1.37
Thats mine :
http://img27.imageshack.us/img27/327/e8400h.th.jpg
8700? i know that Fugger has told that isn't confirmed ...
8700, wow! Didn`t know !
Is that a joke ? So take a look at this mates :D
http://www.hwbot.org/quickSearch.do?...+(3.50Ghz)+(0)
This page is mine :rofl:
thank you for reply, i probably go for extreme spitir so it's compatible without mods..i think oi can set 60% of speed from bios if it will be noisy, it's active dissipation so it's sufficent :) i'll post the mod as soon as i do :) the shop near home sells extreme spirit so it's easyer than ever :D
Shops in Europe are taking orders for E8700 now.
As far as I know there going to be released as Intel has not stated when 775 will be EOL
i7 is still in its infancy and i5 has not seen retail yet, so I cant see Intel dropping 775 yet.
select no to "turn on error dection" and you will get the same output
What test are you failing in Prime?
Please post back with your results
