this is at stock speed and volts:
i try it with E8500 and i dont know if is good because said me 22° idle and 45° full
i'm watercooled
A screenshot would be appreciated. I didn't have a chance to really test this version out on a Wolfdale.
Any News Ace-a-Rue?
John
Be careful what you wish for. No telling what they will replace it with or how long it may take. It is odd though that John's i reading correctly. This seems to be very rare from what I have seen. I wonder if it is just a quirky read problem or if there really is that much difference in the core temps on some chips. it would be nice to be able to understand this phenomena. I've have a hard time understanding why after all this time we can't get more accurate temp readings at least at the bios level on most motherboards.
It would be interesting if you could isolate each core and see if the one that reads so high atv idle would fail a torture test much sooner than one that shows a lower temp at idle. Maybe you could run an individual core "affinity" test using Superpi or prime or something?
thanks...he is doing ok except bleeding out of his "new" pee hole (boy dog)...he had "huge" multiple stones in his urethra behind his penis...he is 12 years old and he has a genetic disease called "cushing's disease" which causes the stones to form...it is tantamount to having diabetes...i give him a drug which acts like a chemo drug to kill the outter couple of layers of his adrenal gland which is over-producing cortisone...the prescription strength for the drug is elusive since the dynamics internally fluctuate a lot!
i've already stress all four cores at stock speed and cores #0 never moves off 51C...stays the same for idle!
i'm going to try to call intel today to see if i can get an RMA out of them....i truly would like accurate temps over a very high overclock...i could live with 4 ghz and be happy.
Ouch that sounds terrible, poor guy :( I hope he gets well soon as that sounds awful!
Hi xgman
I am not sure if I was the John mentioned in your post but I have relapped my HSF and still have similar results, I'm 99.9% certain it is nothing to do with the mounting or the cooling solution used (Stock Intel XE cooler) I have even set the Fan into performance mode (screaming loud 2800RPM!) and still no difference. Have experimented with disabling C1E, Speed Step and Thermal Monitor and also Auto or Manual Voltage
Still no differences.
Stock Idle Readings
http://img143.imageshack.us/img143/3...temp962gf8.jpg
I am sure that this is a BIOS issue or something along those lines, however I have sent an e-mail off to Intel asking what is going on.
John
i just got off the phone with Intel tech support...they will NOT replace or even RMA my QX9650 with this off the wall temp readouts that you and i have!
the guy was basically reading me the party line...basically, he says if it isn't performance related they will not give you an RMA.
he got me to download the latest Intel Utility to read the processor and he said this utility doesn't work on all boards...guess what, it would not install on my DFI X38...try it on your board to see if it will work: http://www.intel.com/design/motherbd...u/download.htm
he said that third party software reading temps is not supported by Intel and therefore, can not be used to support my case...that is why he wanted to me use this software to read out the processor temp.
i am going to have to write a letter to Intel in oregon to complain...this guy 's name was Darwin and he is located in costa rica.
i am really disapointed in Intel and this tech support guy not even giving me an RMA to check the cpu out...he told me to send it back to the place that i bought it from but i already recycled the box and plastic package...i will give clubit.com a call just to check if they can replace it but i seriously doubt it without the entire package.
EDIT:...well, i called clubit.com and explained about not having the box to return the processor...the girl checked and said i could return it and i will be most likely charged a 15% re-stocking fee even though it is for an exchange....it's not definite but there is good probability that they will charge me....darn...wish i wasn't into re-cycling:D;)
Is there a difference between full load and idle temps for each core?
Also having a CPU-z register dump from one such chip would help me see if there may be other reasons for this unaccurate reading.
(Please use the latest CPU-z for this)
at stock speed, core #0 remains at 51C at idle or at load, when running wPrime 1024M bench (last about 5 minutes with 100% 4 cores loaded)
it appears core #1 and #2 will fluctuate in idle and will increase under wPrime load...they might be close to accurrate
core #3 reads higher than cores #1 and #2 but not as high as core #0...core #3 does increase under load.
PM me your email address and i will email you a cpuz dump from version 1.42.
EDIT:...just did a comparison with EIST and C1E turned on and then off...when i have it on, the two cores that are the same and close to what i believe is accurate temp are cores #1 and #2...NOW...with EIST and C1E turned off, the equal cores or accurate cores appear to switch to cores #2 and #3.
EDIT#2:...i am not so sure about what effect EIST and C1E has on the core temp readouts as far as what numbered cores read out to be close to accurate...i could not duplicate after several re-boots getting cores #2 and #3 to be the even number core temps; the ones that i would think are accurate.
it is plain to me at least core #0 is not reading correctly at all, load or idle!
Interesting stuff there Ace-a-Rue
ASUS have released a BIOS update for the P5E3 today (0808) I am going to flash it when I get home from work as this officially supports QX9650 and addresses some RAM issues.
I'll see if the readouts change with the updated BIOS.
It's blimin annoying that Intel are not interested in an RMA if their chip has a defective component (TDiode)
The Coolest
I have CPU-Z 1.42 is that the version I need to do that register dump with?
John
i think 1.42 is the latest version...go to their site just to make sure; i will!
get this about what the Intel Tech Support guy said about worrying over temps...he said, basically, not to worry about the temp...when it gets to hot it will automatically signal the board to shut down...SO...DO NOT WORRY about temperatures...DO YOU BELIEVE THAT!...he was truly passing the buck by not wanting to RMA the processor....i got clubit.com to give me a return #...i will get charged a 15% restocking fee for not having all the packaging...it's going to cost me $200 by the time it is over.
i am still going to write intel a letter to complain about the handling of my claim and the cavalier attitude of the tech rep...he was courteous to me but in no way was he cooperative!...INTEL:down:
EDIT:...confirmed 1.42 is the latest version of CpuZ
Thanks Ace-a-Rue
Well I did the BIOS flash and that made no difference really, except I now have multiplier adjustment of 0.5 instead of 1.0 and it made my system unstable at previous BIOS' settings, in the old BIOS my VDIMM was 1.86 but now I need 1.88 otherwise it crashes in Windows (still memtest stable though which is odd).
Intel sound like they enjoy passing the buck along, I reckon Intel should have a special tool/utility that will measure temperatures universally and not just on their own motherboards!
The Coolest
I have done a CPU-Z register dump, which part would be of interest to you?
What shall I do with it?
John
Ace-a-Rue >> I'm not sure that a DTS that's not functioning properly is worth $200 or the nerves you're putting into this matter.
As the Intel guy said, the CPU has overheat protection built into it, and there are other ways to check the CPU temperature. May be it'll be less accurate, but this is your decision.
Intel's DTS reading isn't something they officially support anyway, so I don't think that they will give you an RMA for the CPU no matter what you do or who you write to.
JohnZS >>
You can do [ code]paste output here[ /code] tags and that's going to be good enough.
Thanks for your guys' effort :)
Arthur
put my Q6600 back in...off to the dirt track to spin it around a vista install.
XP runs very even on all four cores for wPrime 1024M bench....at idle, 3 cores are within +/- one degree and core #0 is within +4 degrees of the 3 other cores.
art, the intel warranty clearly states that the processor and heatsink will be free from defects in material and workmanship...as i explained to the tech rep...you buy a tv set...you take it home and set it up...then you find the remote is broken...you can walk up to the tv and power it on/off, change channels and so forth...but otherwise, it's defective...what will you do?...i know that i would take it back or call for a pick-up if it is a large unit...i don't think you will accept a tv that you put down $1200 USD for and not expect it to function fully.
i have a feeling my Q6600 is going to breeze right through vista 64 install.:up:
Hi Arthur
I hope this is enough. FYI I had to roll back to BIOS 0703 due to 0808 having problems with my memory (which is a right PITA as it supported 0.5x multiplier on the QX9650!)
Anyway here is the code
I had a few programs open when doing this, so if it is a bit odd I'll do it again.Code:-------------------------
CPU-Z version 1.42
Processors Map
Number of processors 1
Number of threads 4
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
-- Core 2
-- Thread 0
-- Core 3
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 4
Number of threads 4 (max 4)
Name Intel Core 2 Quad QX9650
Codename Yorkfield
Specification Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz
Package Socket 775 LGA (platform ID = 4h)
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping C0
Technology 45 nm
Core Speed 2003.7 MHz (6.0 x 333.9 MHz)
Rated Bus speed 1335.8 MHz
Stock frequency 3000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.0x
max VID 1.138 V
Features XD, VT
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008002h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00010676 0x00040800 0x0008E3BD 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB4304E
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x0C000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x0C000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x0C004143 0x05C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00000020
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100000
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x45203229 0x65727478 0x4320656D 0x58205550
0x80000004 0x30353639 0x20402020 0x30302E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x18008040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 D 32 KB 1 threads
Cache descriptor Level 1 I 32 KB 1 threads
Cache descriptor Level 2 U 6 MB 2 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x000000E8 edx = 0x00000000 eax = 0x034B605A
MSR 0x00000017 edx = 0x0C100000 eax = 0x88C40922
MSR 0x000000CD edx = 0x00000000 eax = 0x00000804
MSR 0x0000003F edx = 0x00000000 eax = 0x00000000
MSR 0x000000CE edx = 0x001A0922 eax = 0x7F7F0716
MSR 0x000001A0 edx = 0x00000040 eax = 0x62972489
MSR 0x000000EE edx = 0x00000000 eax = 0x877D4B00
MSR 0x00000194 edx = 0x00000000 eax = 0x00000000
MSR 0x0000019C edx = 0x00000000 eax = 0x88470000
MSR 0x00000198 edx = 0x061A0922 eax = 0x8600061A
MSR 0x00000199 edx = 0x00000000 eax = 0x0000061A
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008002h
0x00000001 0x00010676 0x01040800 0x0008E3BD 0xBFEBFBFF
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
MSR 0x000000E8 edx = 0x00000000 eax = 0x003067B6
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01008002h
0x00000001 0x00010676 0x02040800 0x0008E3BD 0xBFEBFBFF
MSR 0x000000E8 edx = 0x00000000 eax = 0x00A62744
MSR 0x0000019C edx = 0x00000000 eax = 0x88350000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01008002h
0x00000001 0x00010676 0x03040800 0x0008E3BD 0xBFEBFBFF
MSR 0x000000E8 edx = 0x00000000 eax = 0x01CD0E20
Chipset
Northbridge Intel X38 rev. 01
Southbridge Intel 82801IR (ICH9R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual (Symmetric)
Memory Frequency 667.9 MHz (1:2)
CAS# 7.0
RAS# to CAS# 7
RAS# Precharge 7
Cycle Time (tRAS) 18
Command Rate 2T
MCHBAR dump
Base address 0x0FED14000
Size 4096
0 1 2 3 4 5 6 7 8 9 A B C D E F
000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
010 58 1B 0A 3D 00 00 00 00 00 00 00 00 00 00 00 00
020 01 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00
030 06 5A 1F 00 10 28 90 01 00 00 00 37 17 44 03 13
040 18 80 03 0B 00 00 EF 00 00 00 00 00 00 00 00 00
050 01 00 80 00 02 01 8F 00 00 00 00 00 00 00 00 00
060 04 02 80 00 08 03 8F 00 00 00 00 00 00 00 00 00
070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
090 55 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A0 00 00 40 12 00 00 D8 00 00 00 00 00 00 00 00 00
0B0 00 00 D8 00 00 00 00 00 00 00 00 00 00 00 D8 00
0C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00
100 00 00 00 00 00 10 00 00 00 08 00 08 00 00 00 00
110 45 2C 00 00 44 89 01 DC 58 00 7E 81 00 00 7D 00
120 5F 7F 8D 50 03 E0 1F 40 05 1F 80 00 10 76 00 00
130 82 36 57 D8 07 26 60 53 80 C1 F1 7D 80 C1 F1 7D
140 06 C1 1C 00 F4 80 1C 00 21 08 E4 01 A3 08 E4 01
150 0F 00 80 07 00 00 00 00 00 00 00 00 00 00 00 00
160 00 00 00 00 2D 00 00 00 2D 00 00 00 2D 00 00 00
170 2D 00 00 00 FF 13 35 01 00 00 00 00 00 FF FF FF
180 00 01 00 00 00 00 00 00 00 00 00 00 11 0E 00 00
190 27 03 00 00 01 00 00 00 00 2E 00 00 10 08 00 00
1A0 FF FF 00 00 DF 0F 00 00 00 00 00 00 28 10 00 00
1B0 D1 00 00 00 70 00 00 00 70 00 00 00 70 00 00 00
1C0 70 00 00 00 70 00 00 00 70 00 00 00 70 00 00 00
1D0 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0 01 58 55 59 07 00 00 00 94 00 00 0F 00 03 00 00
1F0 C0 90 00 00 02 04 06 08 20 2D B0 04 00 00 00 00
200 10 00 10 00 20 00 20 00 86 00 86 00 00 00 00 00
210 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
220 07 01 10 58 00 01 05 10 00 00 00 00 00 00 00 00
230 00 00 00 00 00 00 00 00 00 16 00 00 AA 8C 03 00
240 00 11 00 01 10 23 05 00 00 06 86 0E 00 54 47 00
250 5D 04 30 F0 8A 05 78 74 47 06 0F 30 10 12 A5 15
260 90 3D 56 0B FF 00 10 13 00 FF FF CF 37 BF 02 03
270 00 0E 55 00 01 87 08 00 81 18 14 88 41 00 04 48
280 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
290 1C 09 F2 04 05 01 00 00 05 04 00 00 78 07 00 00
2A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2B0 00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 01
2C0 F0 C5 0C 58 0C 00 00 00 00 00 00 00 00 00 00 00
2D0 00 71 08 8F 00 00 00 00 00 00 00 00 00 00 00 00
2E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
310 00 00 00 00 00 00 00 00 00 00 00 00 36 00 00 00
320 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
330 00 00 00 00 00 00 98 01 00 00 00 12 09 66 00 00
340 00 80 00 00 1A 1A 00 00 00 00 00 00 00 00 00 00
350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
360 00 00 EC 02 00 00 00 02 00 BB 00 00 00 80 00 40
370 5A 1A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 98 01
390 00 00 00 02 00 66 00 00 00 80 00 40 5A 9A 00 00
3A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3B0 00 00 00 00 00 00 00 00 00 00 98 01 00 00 00 02
3C0 00 66 00 00 00 80 00 40 5A 9A 00 00 00 00 00 00
3D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3E0 00 00 00 00 00 00 18 02 00 00 00 12 09 86 00 00
3F0 00 80 42 01 1A 1A 00 00 00 00 00 00 00 00 00 00
400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
410 00 00 18 02 00 00 00 12 09 86 00 00 00 80 42 01
420 1A 1A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
430 00 00 00 00 00 00 00 00 00 00 00 00 00 00 98 01
440 00 00 00 12 09 66 00 00 00 80 00 00 1A 9A 00 00
450 12 00 00 00 12 00 00 00 00 00 00 00 00 00 00 00
460 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
480 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
490 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4A0 CB D2 42 01 0C D3 52 01 59 C5 51 06 00 E0 CB 17
4B0 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
4C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
500 00 00 00 00 00 00 00 00 19 73 00 00 95 1A 00 00
510 33 B2 00 00 7C 03 00 00 60 0C 00 00 89 08 00 00
520 77 22 00 00 02 07 00 00 01 1B 00 00 10 31 00 00
530 65 76 00 00 24 09 00 00 24 09 00 00 00 04 00 00
540 02 00 00 00 07 00 00 00 88 11 00 00 CF 44 00 00
550 02 03 00 00 05 70 00 00 77 11 00 00 8F 33 00 00
560 02 02 00 00 41 61 00 00 66 11 00 00 8F 33 00 00
570 02 02 00 00 43 51 00 00 55 11 00 00 0F 22 00 00
580 02 02 00 00 C2 40 00 00 44 11 00 00 8F 22 00 00
590 02 02 00 00 43 31 00 00 33 11 00 00 8F 11 00 00
5A0 01 02 00 00 47 21 00 00 22 11 00 00 8F 11 00 00
5B0 02 02 00 00 41 11 00 00 11 11 00 00 8F 00 00 00
5C0 02 02 00 00 C0 00 00 00 00 11 00 00 8F 00 00 00
5D0 08 00 00 80 02 00 33 44 AA FA 01 00 18 00 00 1B
5E0 03 3C C3 3F 07 38 CC 00 00 00 50 55 00 80 07 00
5F0 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 80
600 10 00 10 00 20 00 20 00 86 00 86 00 00 00 00 00
610 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
620 07 01 10 58 00 01 05 10 00 00 00 00 00 00 00 04
630 00 00 00 00 00 00 00 00 00 16 00 00 AA 8C 03 00
640 00 11 00 01 10 23 25 00 00 06 86 0E 00 54 47 00
650 5D 04 30 F0 8A 05 78 74 47 06 0F 30 10 12 A5 15
660 90 3D 56 0B FF 00 10 13 00 FF FF CF 37 BF 02 03
670 00 0E 55 00 01 87 08 00 81 18 14 88 41 00 04 48
680 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
690 1C 09 F2 04 05 01 00 00 05 04 00 00 78 07 00 00
6A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6B0 00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 01
6C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6D0 00 00 01 A7 00 00 00 00 00 00 00 00 04 02 01 08
6E0 00 00 00 00 04 02 01 08 00 00 00 00 04 02 01 08
6F0 00 00 00 00 04 02 01 08 00 00 00 00 00 00 00 00
700 00 00 00 00 00 00 00 00 00 00 00 00 02 01 08 04
710 00 00 00 00 00 00 00 00 00 00 00 00 36 00 00 00
720 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
730 00 00 00 00 00 00 98 01 00 00 00 12 09 66 00 00
740 00 80 00 00 1A 1A 00 00 00 00 00 00 00 00 00 00
750 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
760 00 00 EC 02 00 00 00 06 03 BB 00 00 00 80 C1 40
770 5A 1A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
780 00 00 00 00 00 00 00 00 00 00 00 00 00 00 98 01
790 00 00 00 02 00 66 00 00 00 80 00 40 5A 9A 00 00
7A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
7B0 00 00 00 00 00 00 00 00 00 00 98 01 00 00 00 02
7C0 00 66 00 00 00 80 00 40 5A 9A 00 00 00 00 00 00
7D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
7E0 00 00 00 00 00 00 18 02 00 00 00 16 0B 86 00 00
7F0 00 80 42 01 1A 1A 00 00 00 00 00 00 00 00 00 00
800 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
810 00 00 18 02 00 00 00 12 09 86 00 00 00 80 42 01
820 1A 1A 00 00 2D 14 76 39 2D 15 56 39 00 00 00 00
830 00 00 00 00 00 00 00 00 00 00 00 00 00 00 98 01
840 00 00 00 12 09 66 00 00 00 80 C1 00 1A 9A 00 00
850 12 00 00 00 12 00 00 00 00 00 00 00 00 00 00 00
860 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
870 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
880 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
890 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8A0 CB D2 42 01 0C D3 52 01 59 C5 51 06 00 E0 CB 17
8B0 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
8C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
900 00 00 00 00 00 00 00 00 40 85 00 00 B7 31 00 00
910 66 B5 00 00 83 0B 00 00 37 0D 00 00 12 04 00 00
920 77 22 00 00 05 06 00 00 01 1B 00 00 10 31 00 00
930 54 77 00 00 24 09 00 00 24 09 00 00 00 08 00 00
940 01 00 00 00 04 00 00 00 88 11 00 00 8F 44 00 00
950 02 02 00 00 80 70 00 00 77 11 00 00 8F 33 00 00
960 01 01 00 00 85 61 00 00 66 11 00 00 0F 33 00 00
970 01 02 00 00 84 50 00 00 55 11 00 00 8F 22 00 00
980 01 01 00 00 C7 41 00 00 44 11 00 00 8F 22 00 00
990 01 02 00 00 05 30 00 00 33 11 00 00 8F 11 00 00
9A0 01 01 00 00 41 21 00 00 22 11 00 00 8F 11 00 00
9B0 01 01 00 00 43 11 00 00 11 11 00 00 8F 00 00 00
9C0 01 01 00 00 05 01 00 00 00 11 00 00 8F 00 00 00
9D0 08 00 00 80 02 00 33 44 AA CA A1 00 18 0C 00 36
9E0 C0 03 F0 03 07 38 CC 00 00 50 55 55 00 F0 07 00
9F0 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 00
A00 00 00 00 00 00 00 00 00 00 00 00 00 66 00 00 00
A10 00 00 00 04 00 01 00 00 00 00 00 00 00 00 00 00
A20 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00
A30 18 06 00 44 00 00 00 00 00 00 00 00 00 00 00 00
A40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A50 00 00 01 00 00 00 00 00 00 00 00 00 90 01 00 00
A60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AB0 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00
AC0 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00
AD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AF0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 00 00 00 00 00 00 89 00 00 00 00 00 00 00 00 00
B10 00 00 00 00 00 00 89 00 00 00 00 00 00 00 00 00
B20 00 00 00 00 09 19 00 00 89 00 00 00 00 00 00 00
B30 00 00 81 00 00 00 00 00 00 00 81 00 00 00 00 00
B40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B50 08 00 08 00 08 00 08 00 08 00 08 00 00 00 00 00
B60 10 00 15 16 00 00 80 00 00 00 00 44 44 00 00 00
B70 41 C6 81 FD 41 00 03 18 08 00 00 00 00 00 00 00
B80 00 00 01 01 02 02 03 03 04 04 05 05 06 06 08 0A
B90 0C 0E 11 14 17 1A 1D 20 23 26 29 2C 2F 32 35 38
BA0 03 03 04 04 05 05 06 06 07 08 0A 0C 0F 12 15 18
BB0 1B 1E 21 24 27 2A 2D 30 33 36 39 3C 3F 3F 3F 3F
BC0 3B 47 3B 47 3B 45 3B 3B 45 3B 45 00 3F 3F 00 00
BD0 21 1D 12 16 3F 3F 00 00 3F 3F 3F 3F 3F 3F 3F 3F
BE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
BF0 84 10 00 00 FF FF 11 84 11 11 11 11 11 11 11 11
C00 54 20 00 40 FF FF FF FF 80 00 00 00 00 00 00 00
C10 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00
C20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C30 01 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00
C40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C50 05 03 03 05 FF FF 00 00 00 00 00 00 00 00 00 00
C60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C80 01 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00
C90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CD0 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00
CE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CF0 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
D00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DF0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E00 00 00 00 00 00 00 00 00 04 00 00 00 C4 01 00 03
E10 00 35 22 00 00 00 00 00 00 00 00 00 00 00 00 00
E20 00 00 00 00 00 00 00 00 00 00 00 00 C0 6D A9 01
E30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E60 F0 FF FF 0F FF F0 00 00 0F 00 00 00 00 00 00 00
E70 00 00 00 66 A4 DD 26 00 20 F0 00 01 00 00 00 00
E80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ED0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EF0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F20 FF FF FF 3F 00 00 00 00 00 00 00 00 00 00 00 00
F30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FF
F70 FF FF FF 0F FF 7F 00 00 00 00 00 00 00 00 00 00
F80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FA0 02 00 02 00 03 00 10 20 AA C2 A2 00 00 00 10 40
FB0 21 D0 F0 10 42 08 00 00 00 00 00 00 0F F0 00 00
FC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FF0 00 00 00 00 00 00 00 00 00 00 00 2F 00 00 00 00
Thanks for your help and interest
John
One of my ideas was that maybe each core had it's own Tjunction, but looking at the dump tells me that they all have a Tjunction Max of 105C.
I don't know why there is such a difference between cores.
Either a poor callibration of the DTS or maybe bad contact between the cores and the IHS (just shooting in the dark)
ok art, here is my cpuz dump at stock speed with C1E and EIST disabled.Code:-------------------------
CPU-Z version 1.42
Processors Map
Number of threads 4
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
-- Core 3
-- Thread 0
-- Core 2
-- Thread 0
Number of cores 4
Codename Yorkfield
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping C0
Technology 45 nm
Core Speed 3000.3 MHz (9.0 x 333.4 MHz)
Rated Bus speed 1333.4 MHz
FID/VID Control yes
max VID 1.125 V
Features XD, VT
Thread dumps
CPU Thread 0
APIC ID 0
Type 01008002h
MSR 0x000000E8 edx = 0x00000023 eax = 0x275D96D0
MSR 0x00000017 edx = 0x0C100000 eax = 0x88C40921
MSR 0x000000CE edx = 0x001A0921 eax = 0x7F7F0716
MSR 0x000001A0 edx = 0x00000040 eax = 0x60972489
MSR 0x00000194 edx = 0x00000000 eax = 0x00010921
MSR 0x0000019C edx = 0x00000000 eax = 0x88360000
MSR 0x00000198 edx = 0x061A0921 eax = 0x8600091F
MSR 0x00000199 edx = 0x00000000 eax = 0x0000091F
CPU Thread 1
APIC ID 1
Type 01008002h
MSR 0x000000E8 edx = 0x00000008 eax = 0xF5C6891B
MSR 0x0000019C edx = 0x00000000 eax = 0x88440000
CPU Thread 2
APIC ID 3
Type 01008002h
MSR 0x000000E8 edx = 0x00000009 eax = 0x06287FB5
MSR 0x0000019C edx = 0x00000000 eax = 0x885C0000
CPU Thread 3
APIC ID 2
Type 01008002h
MSR 0x000000E8 edx = 0x00000009 eax = 0x6DAFD9F6
MSR 0x0000019C edx = 0x00000000 eax = 0x885A0000
Chipset
Memory Type DDR2
Memory Frequency 400.0 MHz (5:6)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Command Rate 2T
MCHBAR dump
Size 4096
030 06 5A 1F 00 10 28 90 01 00 00 00 37 17 44 03 15
040 1A 80 03 0B 00 00 0F 00 00 00 00 00 00 00 00 00
050 01 00 84 00 02 01 8F 00 00 00 00 00 00 00 00 00
060 08 02 84 00 04 03 8F 00 00 00 00 00 00 00 00 00
110 45 2C 00 00 00 99 00 A9 48 10 7E 81 00 00 7D 00
120 5F 7F 8D 50 07 E0 1F 40 05 1F 80 00 10 54 00 00
130 82 36 57 D8 07 26 00 32 00 42 F2 7D 00 42 F2 7D
140 F0 40 1A 00 0C 01 1D 00 DF D8 E3 01 63 D8 FB 01
160 00 00 00 00 1B 00 00 00 1B 00 00 00 1B 00 00 00
170 1B 00 00 00 FF 11 34 01 00 00 00 00 00 FF FF FF
180 00 01 00 00 00 00 00 00 00 00 00 00 13 0F 00 00
190 02 03 00 00 00 00 00 00 00 32 00 00 10 08 00 00
1A0 FF FF 00 00 D7 0D 00 00 00 00 00 00 A6 05 00 00
1E0 03 18 55 00 8C 00 00 00 F1 00 00 0F 00 03 00 00
1F0 C0 80 00 00 02 04 06 08 20 2F 80 04 00 00 00 00
200 10 00 20 00 20 00 20 00 86 86 00 00 00 00 00 00
220 17 11 00 58 01 02 24 0C 00 00 00 00 00 00 00 00
230 00 00 00 00 00 00 00 00 00 13 00 00 89 7A 11 00
240 00 11 00 01 10 23 05 00 00 07 84 0E 00 22 39 00
250 95 03 2E AC 06 04 68 54 46 B5 0A 2E 0C 0F A5 15
260 91 3D 37 0B 78 00 0E 13 00 30 CC CF 33 BF 02 03
290 1C 09 F2 04 00 00 00 00 11 00 00 00 68 06 00 00
2C0 F0 C5 0C 40 0C 00 00 00 00 00 00 00 00 00 00 00
310 00 00 00 00 00 00 00 00 00 00 00 00 2D 00 00 00
320 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
330 00 00 00 00 00 00 98 01 00 00 00 02 00 66 00 00
340 00 80 00 80 8A 0A 00 00 00 00 00 00 00 00 00 00
360 00 00 DC 01 00 00 00 02 00 77 00 00 00 80 00 C0
370 CA 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CC 00
390 00 00 00 02 00 33 00 00 00 80 00 C0 CA 8A 00 00
3B0 00 00 00 00 00 00 00 00 00 00 CC 00 00 00 00 02
3C0 00 33 00 00 00 80 00 C0 CA 8A 00 00 00 00 00 00
3E0 00 00 00 00 00 00 20 02 00 00 00 02 00 88 00 00
3F0 00 80 00 80 8A 0A 00 00 00 00 00 00 00 00 00 00
410 00 00 20 02 00 00 00 02 00 88 00 00 00 80 00 80
420 8A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
440 00 00 00 02 00 66 00 00 00 80 00 80 8A 8A 00 00
450 2D 00 00 00 2D 00 00 00 00 00 00 00 00 00 00 00
4A0 D6 A5 52 01 D7 A5 5A 01 9E 44 41 06 00 E0 CB 17
500 00 00 00 00 00 00 00 00 00 D0 00 00 78 66 00 00
510 4D 74 00 00 65 08 00 00 D3 01 00 00 87 0D 00 00
520 7D 20 00 00 02 00 00 00 01 1B 00 00 00 00 00 00
530 21 21 00 00 24 09 00 00 24 09 00 00 00 04 00 00
540 01 00 00 00 03 00 00 00 88 11 00 00 4F 44 00 00
550 01 00 00 00 03 70 00 00 77 11 00 00 0F 33 00 00
560 01 00 00 00 03 60 00 00 66 11 00 00 0F 22 00 00
570 01 00 00 00 03 50 00 00 55 11 00 00 0F 22 00 00
580 01 00 00 00 03 40 00 00 44 11 00 00 0F 11 00 00
590 01 00 00 00 03 30 00 00 33 11 00 00 8F 00 00 00
5A0 01 00 00 00 03 20 00 00 22 11 00 00 0F 00 00 00
5B0 01 00 00 00 03 10 00 00 11 11 00 00 0F 00 00 00
5C0 01 00 00 00 03 00 00 00 00 11 00 00 0F 00 00 00
5D0 08 00 00 80 02 00 33 11 CC CC F1 00 90 0C 00 38
5E0 00 00 FF 00 07 38 29 00 55 55 AA AA 00 80 07 00
5F0 00 00 00 00 0F 00 00 00 02 00 00 00 00 00 00 80
600 10 00 20 00 20 00 20 00 86 86 00 00 00 00 00 00
620 17 11 00 58 01 02 24 0C 00 00 00 00 00 00 00 04
630 00 00 00 00 00 00 00 00 00 13 00 00 89 7A 00 00
640 00 11 00 01 10 23 25 00 00 07 84 0E 00 22 39 00
650 95 03 2E AC 06 04 68 54 46 B5 0A 2E 0C 0F A5 15
660 91 3D 37 0B 78 00 0E 13 00 30 CC CF 33 BF 02 03
690 1C 09 F2 04 00 00 00 00 11 00 00 00 68 06 00 00
6D0 00 00 01 64 00 00 00 00 00 00 00 00 00 04 02 10
6E0 00 00 00 00 00 04 02 10 00 00 00 02 00 01 04 00
6F0 00 00 00 02 00 01 04 00 00 00 00 00 00 00 00 00
700 00 00 08 04 02 01 10 00 00 00 00 00 00 02 10 08
710 00 00 00 00 00 00 00 00 00 00 00 00 2D 00 00 00
720 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
730 00 00 00 00 00 00 98 01 00 00 00 02 00 66 00 00
740 00 80 00 80 8A 0A 00 00 00 00 00 00 00 00 00 00
760 00 00 DC 01 00 00 00 02 00 77 00 00 00 80 00 C0
770 CA 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
780 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CC 00
790 00 00 00 02 00 33 00 00 00 80 00 C0 CA 8A 00 00
7B0 00 00 00 00 00 00 00 00 00 00 CC 00 00 00 00 02
7C0 00 33 00 00 00 80 00 C0 CA 8A 00 00 00 00 00 00
7E0 00 00 00 00 00 00 20 02 00 00 00 02 00 88 00 00
7F0 00 80 00 80 8A 0A 00 00 00 00 00 00 00 00 00 00
810 00 00 20 02 00 00 00 02 00 88 00 00 00 80 00 80
820 8A 0A 00 00 2A 15 05 01 AA 55 27 01 00 00 00 00
840 00 00 00 02 00 66 00 00 00 80 00 80 8A 8A 00 00
850 2D 00 00 00 2D 00 00 00 00 00 00 00 00 00 00 00
8A0 D6 A5 52 01 D7 A5 5A 01 9E 44 41 06 00 E0 CB 17
900 00 00 00 00 00 00 00 00 AD 98 00 00 35 10 00 00
910 3D 73 00 00 81 01 00 00 C4 05 00 00 17 0C 00 00
920 5C 71 00 00 02 07 00 00 01 1B 00 00 21 11 00 00
930 42 43 00 00 24 09 00 00 24 09 00 00 00 08 00 00
940 00 00 00 00 00 00 00 00 88 11 00 00 4F 44 00 00
950 00 00 00 00 00 70 00 00 77 11 00 00 0F 33 00 00
960 00 00 00 00 00 60 00 00 66 11 00 00 0F 33 00 00
970 00 00 00 00 00 50 00 00 55 11 00 00 0F 22 00 00
980 00 00 00 00 00 40 00 00 44 11 00 00 0F 11 00 00
990 00 00 00 00 00 30 00 00 33 11 00 00 0F 00 00 00
9A0 00 00 00 00 00 20 00 00 22 11 00 00 0F 00 00 00
9B0 00 00 00 00 00 10 00 00 11 11 00 00 0F 00 00 00
9C0 00 00 00 00 00 00 00 00 00 11 00 00 0F 00 00 00
9D0 08 00 00 80 02 00 33 11 CC CC F1 00 90 0C 00 38
9E0 00 10 0F F0 07 38 21 00 55 55 AA 56 00 F0 07 00
9F0 00 00 00 00 0F 00 00 00 02 00 00 00 00 00 00 00
A00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00
B60 10 00 15 16 00 00 80 00 00 00 00 BD BD 00 00 00
BC0 37 43 37 43 35 41 35 35 41 35 41 00 3F 13 00 00
BD0 21 1D 12 16 3F 3F 00 00 3F 15 3F 15 3F 13 3F 13
BF0 8C 31 00 00 FF FF 10 84 10 10 10 10 10 10 10 10
C00 34 20 00 40 07 07 0B 0D 80 00 00 00 00 00 00 00
C30 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
C50 0F 17 1F 3E 00 00 00 00 00 00 00 00 00 00 00 00
CD0 00 00 00 00 00 7F 00 00 98 04 00 FF 29 00 00 FF
CE0 00 00 80 00 09 00 00 00 00 00 00 00 00 00 00 00
E00 00 00 00 00 00 00 00 00 44 00 00 00 C4 01 00 03
E70 00 00 00 AE 99 DD 26 00 20 F0 00 01 00 00 00 00
FA0 02 00 02 00 03 00 11 20 AA C2 A2 00 00 00 10 C0
FB0 21 D0 F0 10 42 08 00 00 00 00 00 00 0F 08 00 00
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number F2-6400CL5-2GBPQ
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 266 400
CAS# 4.0 5.0
RAS# to CAS# delay 4 5
RAS# Precharge 4 5
TRAS 10 15
TRC 16 24
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 4.0 5.0
RAS# Precharge 4 5
TRAS 10 15
TRC 16 24
Dump Module #1
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 08 30 01 02 00 07 3D 50 3D 60 32 1E 32 24 01
20 17 25 05 12 3C 1E 1E 00 06 3C 70 80 14 1E 00 00
30 00 03 00 00 00 00 00 00 00 00 00 00 00 00 12 A0
40 7F 7F 7F 7F CD 00 00 00 00 46 32 2D 36 34 30 30
50 43 4C 35 2D 32 47 42 50 51 00 00 00 00 00 00 00
Dump Module #2
Monitoring
Mainboard Model LP LT X38 (0x23F - 0x2DB6538)
LPCIO
Vendor ITE
Model IT8718
Vendor ID 0x90
Chip ID 0x8718
Revision ID 0x2
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0x4
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
20 87 18 02 00 00 40 0F 00 03 08 00 00 07 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0 1.22 Volts [0x4C] (CPU VCORE)
Voltage sensor 1 1.10 Volts [0x45] (VIN1)
Voltage sensor 2 3.31 Volts [0xCF] (+3.3V)
Voltage sensor 3 4.87 Volts [0xB5] (+5V)
Voltage sensor 4 12.03 Volts [0xBC] (+12V)
Voltage sensor 5 -4.99 Volts [0x4E] (-12V)
Voltage sensor 6 -7.30 Volts [0x72] (-5V)
Voltage sensor 7 4.87 Volts [0xB5] (+5V VCCH)
Voltage sensor 8 3.30 Volts [0xCE] (VBAT)
Temperature sensor 0 16°C (60°F) [0x10] (TMPIN0)
Temperature sensor 1 36°C (96°F) [0x24] (TMPIN1)
Temperature sensor 2 33°C (91°F) [0x21] (TMPIN2)
Fan sensor 0 4193 RPM [0xA1] (FANIN0)
Dump hardware monitor
LPC Register space, base address = 0x0290
00 13 16 42 00 FF FF 06 00 00 80 40 09 07 A2 FF FF
10 D0 D0 D0 77 D0 40 7F 5C 00 FF FF 00 00 00 00 00
20 4C 45 CF B6 BC 4E 72 B5 CE 10 24 20 55 05 05 05
30 FF 00 69 50 EC AE CC A7 DA 9C 54 24 55 41 CC A7
40 54 7F 54 7F 54 7F 00 0D 2D FF FF FF FF FF FF FF
50 FF 31 55 7F 7F 50 E8 00 90 00 00 12 84 F8 08 88
60 14 19 7F 21 98 01 FF FF 14 19 7F A1 88 80 FF FF
70 14 19 7F 21 98 80 FF FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 02 FF
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Intel Core 2 Quad QX9650 hardware monitor
Temperature sensor 0 51°C (123°F) [0x36] (core #0)
Temperature sensor 1 37°C (98°F) [0x44] (core #1)
Temperature sensor 3 13°C (55°F) [0x5C] (core #3)
Temperature sensor 2 15°C (58°F) [0x5A] (core #2)
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x29E0
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x8086
Subsystem ID 0x29E0
Int. Line 0x00
Int. Pin 0x00
Capabilities
Vendor Dependant Capability
Offset E0h
Dump
00 86 80 E0 29 06 00 90 20 01 00 00 06 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 E0 29
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 40 D1 FE 00 00 00 00
50 00 00 02 00 03 20 00 00 00 00 00 00 00 00 00 00
60 01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00
90 10 11 11 11 01 00 00 00 40 00 4B 00 00 1A 79 00
A0 40 00 00 13 00 00 00 D0 00 00 00 D0 00 00 F0 CF
B0 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 49 00 00 00 00 00 00 79
E0 09 00 0C 01 20 40 78 80 43 44 0B 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 90 0F 01 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x29E1
Revision ID 0x01
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
Capabilities
Subsystem Vendor Capability
Offset 88h
Subsystem ID 0x29E1
Sub. Vendor ID 0x8086
Power Management Capability
Offset 80h
Version 1.2
Message Signalled Interrupts Capability
Offset 90h
PCI Express Capability
Offset A0h
Device type Root Port of PCI-E Root Complex
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Link width 8x (max 16x)
Extended capabilities
Virtual Channel
Offset 100h
Root Complex Link Declaration
Offset 140h
Link Entries # 1
Port Number 2
Dump
00 86 80 E1 29 07 00 10 00 01 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 01 03 00 F0 00 00 20
20 B0 FD B0 FD 41 FD 71 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 04 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
80 01 90 03 C8 08 00 00 00 0D 80 00 00 86 80 E1 29
90 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 10 00 42 01 00 80 00 00 00 00 00 00 02 45 21 02
B0 00 00 81 10 00 00 04 00 00 00 48 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00
F0 00 00 01 00 03 E1 3F 80 90 0F 01 00 00 F0 00 F0
100 02 00 01 14 00 00 00 00 00 00 00 00 00 00 00 00
110 01 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x29E9
Revision ID 0x01
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 88h
Subsystem ID 0x29E9
Offset 80h
Version 1.2
Offset 90h
Offset A0h
Port 3
Version 2.0
Physical slot #4
Presence detect yes
Link width 16x (max 16x)
Virtual Channel
Offset 100h
Offset 140h
Link Entries # 1
Port Number 3
Dump
00 86 80 E9 29 07 00 10 00 01 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 04 04 00 D0 D0 00 00
20 00 F8 F0 FB 01 D0 F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 08 00
80 01 90 03 C8 08 00 00 00 0D 80 00 00 86 80 E9 29
A0 10 00 42 01 00 80 00 00 00 00 01 00 02 35 21 03
B0 40 00 01 11 80 25 04 01 00 00 48 00 00 00 00 00
F0 04 00 01 00 03 E1 3F 80 90 0F 01 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2937
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000FF00
Subvendor ID 0x8086
Subsystem ID 0x2937
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 50h
Dump
00 86 80 37 29 05 00 90 02 02 00 03 0C 00 00 80 00
20 01 FF 00 00 00 00 00 00 00 00 00 00 86 80 37 29
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
50 09 00 06 20 00 00 00 00 00 00 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 27 00 00 00 00 00 00 00 00 01 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 86 0F 02 00 00 00 00 00
bus 0 (0x00), device 26 (0x1A), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2938
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FE00
Subvendor ID 0x8086
Subsystem ID 0x2938
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 50h
Dump
00 86 80 38 29 05 00 90 02 02 00 03 0C 00 00 00 00
20 01 FE 00 00 00 00 00 00 00 00 00 00 86 80 38 29
30 00 00 00 00 50 00 00 00 00 00 00 00 15 02 00 00
bus 0 (0x00), device 26 (0x1A), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2939
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FD00
Subvendor ID 0x8086
Subsystem ID 0x2939
Int. Line 0x13
Int. Pin 0x04
Capabilities
Offset 50h
Dump
00 86 80 39 29 05 00 90 02 02 00 03 0C 00 00 00 00
20 01 FD 00 00 00 00 00 00 00 00 00 00 86 80 39 29
30 00 00 00 00 50 00 00 00 00 00 00 00 13 04 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 26 (0x1A), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x293C
Revision ID 0x02
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFFF000
Subvendor ID 0x8086
Subsystem ID 0x293C
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 50h
Version 1.1
Dump
00 86 80 3C 29 06 00 90 02 02 20 03 0C 00 00 00 00
10 00 F0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 3C 29
30 00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00
50 01 00 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 FF 01 00 00 00 00 01 00 00 01 00 20 00 C0
70 00 00 DF 0F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 09 00 06 20 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 88 85 40 00 86 0F 02 00 0A 17 02 20
Multimedia device
bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x293E
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFF4000
Subvendor ID 0x8086
Subsystem ID 0x293E
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Offset 60h
Offset 70h
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Virtual Channel
Offset 100h
Offset 130h
Link Entries # 1
Port Number 15
Dump
00 86 80 3E 29 06 00 10 00 02 00 03 04 08 00 00 00
10 04 40 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 3E 29
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 01 00 00 07 07 00 00 00 00 00 00 00 00 00 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
C0 00 04 00 01 00 00 00 00 31 00 A3 02 00 00 00 00
D0 61 00 A3 02 00 00 00 00 00 00 00 00 00 00 00 00
100 02 00 01 13 01 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 80 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00
130 05 00 01 00 00 01 02 0F 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2940
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Port 1
Version 1.0
Physical slot #2
Presence detect no
Link width 0x (max 1x)
Offset 80h
Offset 90h
Subsystem ID 0x2940
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 1
Dump
00 86 80 40 29 07 00 10 00 02 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 05 05 00 F0 00 00 20
20 00 F4 F0 F7 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 10 01 04 00
40 10 80 41 01 00 80 00 00 04 00 10 00 11 44 11 01
50 10 00 01 10 60 05 80 00 00 00 00 00 04 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 86 80 40 29 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 80 00 11 08 00 00 00 00
E0 00 0F C7 00 06 07 08 00 30 00 00 00 00 00 00 00
100 02 00 01 18 00 00 00 00 01 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x2946
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x06
Int. Line 0x13
Int. Pin 0x04
Capabilities
Offset 40h
Port 4
Version 1.0
Physical slot #2
Presence detect yes
Link width 1x (max 1x)
Offset 80h
Offset 90h
Subsystem ID 0x2946
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 4
Dump
00 86 80 46 29 07 00 10 00 02 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 06 06 00 C0 C0 00 00
20 D0 FD D0 FD F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 13 04 04 00
40 10 80 41 01 00 80 00 00 04 00 10 00 11 24 11 04
50 40 00 11 30 60 05 98 00 00 00 48 01 04 00 00 00
90 0D A0 00 00 86 80 46 29 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x294A
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x07
Int. Line 0x11
Int. Pin 0x02
Capabilities
Offset 40h
Port 6
Version 1.0
Physical slot #2
Presence detect yes
Offset 80h
Offset 90h
Subsystem ID 0x294A
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 6
Dump
00 86 80 4A 29 07 00 10 00 02 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 07 07 00 B0 B0 00 00
20 C0 FD C0 FD F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 11 02 04 00
40 10 80 41 01 00 80 00 00 04 00 10 00 11 24 11 06
50 40 00 11 30 60 05 A8 00 00 00 48 01 04 00 00 00
90 0D A0 00 00 86 80 4A 29 00 00 00 00 00 00 00 00
bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2934
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000FC00
Subvendor ID 0x8086
Subsystem ID 0x2934
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 50h
Dump
00 86 80 34 29 05 00 90 02 02 00 03 0C 00 00 80 00
20 01 FC 00 00 00 00 00 00 00 00 00 00 86 80 34 29
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2935
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FB00
Subvendor ID 0x8086
Subsystem ID 0x2935
Int. Line 0x13
Int. Pin 0x02
Capabilities
Offset 50h
Dump
00 86 80 35 29 05 00 90 02 02 00 03 0C 00 00 00 00
20 01 FB 00 00 00 00 00 00 00 00 00 00 86 80 35 29
30 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00
bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2936
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FA00
Subvendor ID 0x8086
Subsystem ID 0x2936
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 50h
Dump
00 86 80 36 29 05 00 90 02 02 00 03 0C 00 00 00 00
20 01 FA 00 00 00 00 00 00 00 00 00 00 86 80 36 29
bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x293A
Revision ID 0x02
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFFE000
Subvendor ID 0x8086
Subsystem ID 0x293A
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 86 80 3A 29 06 00 90 02 02 20 03 0C 00 00 00 00
10 00 E0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 3A 29
PCI to PCI Bridge
bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0x92
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x08
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Subsystem ID 0x244E
Dump
00 86 80 4E 24 07 00 10 00 92 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 08 08 20 A0 A0 80 22
20 E0 FD E0 FD F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
50 0D 00 00 00 86 80 4E 24 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2916
Revision ID 0x02
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x2916
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset E0h
Dump
00 86 80 16 29 07 01 10 02 02 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 16 29
40 01 04 00 00 80 00 00 00 81 04 00 00 10 00 00 00
60 83 85 8A 8B D0 00 00 00 84 8B 87 89 F8 00 00 00
80 00 00 08 34 01 08 3C 00 01 01 3C 00 91 02 0C 00
A0 24 02 00 00 00 02 00 00 13 00 00 00 00 03 00 40
B0 00 00 F0 00 00 00 00 00 55 55 55 59 00 00 00 00
D0 33 22 11 00 67 45 00 00 C0 C0 00 00 00 00 00 00
E0 09 00 0C 10 00 00 C4 00 60 00 00 00 00 00 00 00
F0 01 C0 D1 FE 69 A8 00 00 86 0F 02 00 00 00 00 00
RAID Controller
bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2822
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000F900
Address 1 (port) 0x0000F800
Address 2 (port) 0x0000F700
Address 3 (port) 0x0000F600
Address 4 (port) 0x0000F500
Address 5 (memory) 0xFDFFD000
Subvendor ID 0x8086
Subsystem ID 0x2920
Int. Line 0x13
Int. Pin 0x02
Capabilities
Offset 80h
Offset 70h
Version 1.2
PCI Capability class 0x12
Offset A8h
Offset B0h
Dump
00 86 80 22 28 07 00 B0 02 02 00 04 01 00 00 00 00
10 01 F9 00 00 01 F8 00 00 01 F7 00 00 01 F6 00 00
20 01 F5 00 00 00 D0 FF FD 00 00 00 00 86 80 20 29
30 00 00 00 00 80 00 00 00 00 00 00 00 13 02 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
70 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 08 00 00 00 00 00 00 00 00 00 00 00 00 00
90 A0 00 3F AD 93 01 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 12 B0 10 00 48 00 00 00
B0 09 00 06 20 00 00 00 00 00 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x2930
Revision ID 0x02
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFFC000
Address 4 (port) 0x00000500
Subvendor ID 0x8086
Subsystem ID 0x2930
Int. Line 0x0B
Int. Pin 0x02
Dump
00 86 80 30 29 03 00 80 02 02 00 05 0C 00 00 00 00
10 04 C0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 01 05 00 00 00 00 00 00 00 00 00 00 86 80 30 29
30 00 00 00 00 00 00 00 00 00 00 00 00 0B 02 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0330
Revision ID 0x07
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x01
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Device type PCI-E to PCI/PCI-X bridge
Port 0
Version 1.0
Link width 8x (max 8x)
Offset 5Ch
Offset 6Ch
Version 1.1
PCI-X Capability
Offset D8h
Advanced Error Reporting Capability
Offset 100h
Power Budgeting Capability
Offset 300h
Dump
00 86 80 30 03 07 00 10 00 07 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 01 02 02 40 F0 00 A0 22
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 04 00
40 80 6E 00 FF 10 5C 71 00 01 00 00 00 00 20 0A 00
50 81 F4 03 00 00 00 81 00 00 00 00 00 05 6C 80 00
60 00 00 00 00 00 00 00 00 00 00 00 00 01 D8 02 C8
D0 00 00 00 00 00 00 00 00 07 00 C3 50 00 01 00 00
E0 FF FF FF FF FF FF FF FF 01 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 57 00 00 00
100 01 00 01 30 00 00 10 00 00 00 00 00 10 20 06 00
110 00 00 00 00 00 00 00 00 14 00 00 00 01 00 00 04
120 0C 1B 00 00 00 00 01 01 00 01 01 00 08 00 00 00
130 A8 17 00 00 40 13 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 1 (0x01), device 0 (0x00), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x0332
Revision ID 0x07
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x01
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Port 0
Version 1.0
Offset 5Ch
Offset 6Ch
Version 1.1
PCI-X Capability
Offset D8h
Offset 100h
Offset 300h
Dump
00 86 80 32 03 07 00 10 00 07 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 01 03 03 40 F0 00 A0 22
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 07 00 C3 50 02 01 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00
RAID Controller
bus 2 (0x02), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x17D3
Model ID 0x1210
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x01
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFDBFF000
Address 2 (memory) 0xFD400000
Subvendor ID 0x17D3
Subsystem ID 0x1210
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset C0h
Version 1.1
Offset D0h
PCI-X Capability
Offset E0h
Dump
00 D3 17 10 12 D6 00 30 22 00 00 04 01 08 40 00 00
10 00 F0 BF FD 00 00 00 00 08 00 40 FD 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 D3 17 10 12
30 00 00 00 00 C0 00 00 00 00 00 00 00 12 01 80 00
40 00 F0 FF FF 00 F0 00 40 00 00 FF FF 00 00 0E FE
50 00 00 C0 FF 00 00 00 00 00 00 00 00 00 00 00 90
60 00 00 00 FC 00 00 00 00 00 00 00 FC 00 00 FF 8F
70 00 00 00 00 00 00 00 00 74 15 00 00 02 03 01 00
80 02 00 08 00 00 04 03 00 00 00 00 00 FF 57 00 00
90 0C 00 00 40 00 00 00 80 00 00 00 C0 00 00 00 40
A0 00 00 00 00 00 30 40 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00
C0 01 D0 02 02 00 00 00 00 00 00 00 00 00 00 00 00
D0 05 E0 82 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 07 00 45 00 70 02 B3 09 00 00 00 00 0F 00 00 00
VGA Controller
bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0193
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFA000000
Address 1 (memory) 0xD0000000
Address 3 (memory) 0xF8000000
Address 5 (port) 0x0000DF00
Subvendor ID 0x1682
Subsystem ID 0x2252
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.1
Offset 68h
Offset 78h
Device type PCI-E Endpoint Device
Port 1
Version 1.0
Virtual Channel
Offset 100h
Offset 128h
Dump
00 DE 10 93 01 07 00 10 00 A2 00 00 03 08 00 00 00
10 00 00 00 FA 0C 00 00 D0 00 00 00 00 04 00 00 F8
20 00 00 00 00 01 DF 00 00 00 00 00 00 82 16 52 22
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
40 82 16 52 22 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 01 00 80 04 2C 01
80 10 28 00 00 01 2D 01 01 48 00 01 11 00 00 00 00
100 02 00 81 12 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 04 00 01 00 00 00 00 00
130 21 81 07 00 00 00 00 00 00 00 00 00 00 00 00 03
Ethernet Controller
bus 6 (0x06), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x11AB
Model ID 0x4362
Revision ID 0x22
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDDFC000
Address 2 (port) 0x0000CE00
Subvendor ID 0x11AB
Subsystem ID 0x5321
Int. Line 0x0B
Int. Pin 0x01
Capabilities
Offset 48h
Version 1.1
Virtual Product Data Capability
Offset 50h
Offset 5Ch
Offset E0h
Device type Legacy PCI-E Endpoint Device
Port 0
Version 1.0
Offset 100h
Dump
00 AB 11 62 43 00 00 10 40 22 00 00 02 08 00 00 00
10 04 C0 DF FD 00 00 00 00 01 CE 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 AB 11 21 53
30 00 00 00 00 48 00 00 00 00 00 00 00 0B 01 00 00
40 00 00 F0 01 00 80 A0 01 01 50 02 FE 03 20 00 13
50 03 5C 00 80 00 00 00 01 00 00 00 01 05 E0 82 00
70 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 10 00 11 00 C0 0F 28 00 00 20 1B 00 11 A4 03 00
F0 48 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 00 00 00 10 00 00 00 10 00 11 20 06 00
110 01 00 00 00 00 00 00 00 1F 00 00 00 01 00 00 04
120 01 04 00 00 24 01 00 06 EC D7 3F 85 00 00 00 00
Ethernet Controller
bus 7 (0x07), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x11AB
Model ID 0x4360
Revision ID 0x22
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDCFC000
Address 2 (port) 0x0000BC00
Subvendor ID 0x11AB
Subsystem ID 0x5221
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 48h
Version 1.1
Offset 50h
Offset 5Ch
Offset E0h
Port 0
Version 1.0
Offset 100h
Dump
00 AB 11 60 43 07 00 10 40 22 00 00 02 08 00 00 00
10 04 C0 CF FD 00 00 00 00 01 BC 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 AB 11 21 52
30 00 00 00 00 48 00 00 00 00 00 00 00 11 01 00 00
40 00 00 F0 01 00 80 A0 01 01 50 02 FE 00 20 00 13
70 00 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 10 00 11 00 C0 0F 28 00 00 40 1B 00 11 A4 03 00
100 01 00 01 00 00 00 00 00 00 00 10 00 11 20 06 00
120 01 08 00 00 24 01 00 07 45 E3 9B 91 00 00 00 00
OHCI FireWire Controller
bus 8 (0x08), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3044
Revision ID 0x80
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFDEFF000
Address 1 (port) 0x0000AF00
Subvendor ID 0x15BD
Subsystem ID 0x1006
Int. Line 0x14
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 06 11 44 30 87 00 10 02 80 10 00 0C 08 40 00 00
10 00 F0 EF FD 01 AF 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 BD 15 06 10
30 00 00 00 00 50 00 00 00 00 00 00 00 14 01 00 20
50 01 00 02 E4 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 12/18/2007
DMI System Information
manufacturer OEM
product OEM
version OEM
serial OEM
UUID FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
DMI Baseboard
vendor DFI Inc.
model LP LT X38
revision 1.0
serial unknown
DMI System Enclosure
manufacturer OEM
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 Extreme
clock speed 2997.0MHz
FSB speed 333.0MHz
multiplier 9.0x
DMI Memory Controller
correction 8-bit parity
Max module size 2048MBytes
DMI Memory Module
designation A0
size 2048MBytes (double bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB0 (external)
port type USB
DMI Port Connector
designation USB1 (external)
port type USB
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI4
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCI5
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI6
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI7
type A5
width 32 bits
populated yes
DMI Extension Slot
designation _DMI.BIN
type PCI
width 32 bits
populated no
DMI Extension Slot
designation unknown
type A5
width 32 bits
populated yes
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
data width 64bits
size 2048MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
DMI Memory Device
designation A2
format DIMM
type unknown
data width 64bits
size 2048MBytes
DMI Memory Device
designation A3
format DIMM
type unknown
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Resources
Port I/O Space, BA=0xFF00
Port I/O Space, BA=0xFE00
Port I/O Space, BA=0xFD00
Memory I/O Space, BA=0x00000000FDFFF000
Memory I/O Space, BA=0x00000000FDFF4000
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0xFB00
Port I/O Space, BA=0xFA00
Memory I/O Space, BA=0x00000000FDFFE000
Port I/O Space, BA=0xF900
Port I/O Space, BA=0xF800
Port I/O Space, BA=0xF700
Port I/O Space, BA=0xF600
Port I/O Space, BA=0xF500
Memory I/O Space, BA=0x00000000FDFFD000
Memory I/O Space, BA=0x00000000FDFFC000
Port I/O Space, BA=0x500
Memory I/O Space, BA=0x00000000FDBFF000
Memory I/O Space, BA=0x00000000FD400000
Memory I/O Space, BA=0x00000000FA000000
Memory I/O Space, BA=0x00000000D0000000
Memory I/O Space, BA=0x00000000F8000000
Port I/O Space, BA=0xDF00
Memory I/O Space, BA=0x00000000FDDFC000
Port I/O Space, BA=0xCE00
Memory I/O Space, BA=0x00000000FDCFC000
Port I/O Space, BA=0xBC00
Memory I/O Space, BA=0x00000000FDEFF000
Port I/O Space, BA=0xAF00
Memory I/O Space, BA=0x00000000E0000000, size=0x1000
Port I/O Space, BA=0x408, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Memory I/O Space, BA=0x00000000FED14000, size=0x1000
Memory I/O Space, BA=0x00000000FED1C000
Port I/O Space, BA=0x290
Port I/O Space, BA=0x2E
FYI, my Q6600 is working 'fine' on this DFI board...i am believing more now that the 9650 is defective...i could not install vista or it did install but it would quickly freeze in windows desktop...i am asking other posters in the DFI X38 thread if they have the 9650 installed and running vista either at stock speed or overclocked.
i'm at 3960 mhz with the Q6600
I'm having the same issue on an Abit 35 pro with 2 different 9650's. I am going to try them in a new board tomorrow and see if anything changes. BTW, my Q6600's temps are within 1-2 of each other on this board.
