So you kept the same setup and got the RMA board back and now ti works? I ask b/c my UD3R board has the same dual boot issue.
How long did they have the board for?
To Radaja, Panging & OC Nub : If you wanna know what's the DDR3 version really gat in terms of potential,
just have a look sometimes on my french thread, I'm hardly workin' on it for now ;)
http://soj.mesdiscussions.net/soj/in...jet_2430_1.htm
I think 600fsb is possible with dualie's...but the PC16000 is hard to go in the specs and I don't know if it comes because of me, the mobo or the D9s :D
I had just purchased the GB board and was testing on the table when it showed up. I tried 3 different sets of RAM, multiple bios and settings, and it would not boot in dual channel. RMA'd to newegg and had a board back in a couple of weeks round trip. This one worked out of the box.
just got my UD3P in today. ill be back in a while after i get it installed. btw its a v1.1 if that means anything
That just means its revision v1.1, which overclocks the same as v1.0, or so I heard.
I bought EP45-UD3LR and i like it so far ;)
http://i91.photobucket.com/albums/k2.../LoadTest1.jpg
Old test but works ;)
So any more info about that mobo ? any owners ?
got her up and running. bios is F8, gonna update it to the latest. also whats the normal operating temps for the P45? ET6 is saying 60C :eek: for my NB. i can barely touch the heatsink for more than a second. im going to be putting a fan over it (old 80mm AMD Opty HS fan :p: ) other than that i like this board thus far!
thanks for the input.yea im not looking for easy,but i remembered when the ddr3 UD3P came out and no one could get very high FSB.but maybe the newer bio's helped?all i know is your doing some awesome clocks with yours.the EP45-Extreme looks great too and the price is decent at newegg right now.:up:
Looked at the Extreme board also radaja, was concerned that getting the Ultra120 to fit may be a problem, also the sata ports may get in the way of larger GFX cards.
heres 4.7ghz, its down the thread i bit, some of the voltages r overkill like mch core, and main thing that helps the high fsb for me is the vtt and mch ref :D u may need for vcore tho;) wasnt that stable
http://www.xtremesystems.org/forums/...d.php?t=211385
also if u look through the first 20-40 (i dont really know where it is up its there some where) of this thread i have settings for 4.6ghz that were very stable, it may also help
CPUMARK 99!!!! I thought I was the only one still using that ancient single-threaded thing, as seen on this thread -
http://www.xtremesystems.org/forums/...d.php?t=193665
I only managed a pathetic 588 score .. grr.. HardtoQuad x48 mobo..
XmX
Q9550 @ 525x8.5 4.46 GHz air-cooled. Windows Vista 32-bit.
http://img5.imageshack.us/img5/9859/20090505105206.png
http://img5.imageshack.us/img5/3005/20090505112340.png
Q9550 @ 530x8.5 4.50 GHz air-cooled. Windows Vista 64-bit.
http://img27.imageshack.us/img27/173...0507010604.png
http://img27.imageshack.us/img27/738/20090507014855.png
What do u think about this? :D
Memories are Elpida Patriot Viper 1200 MHZ and they don't want to run lower PL stable ... or is me that doesn't know what to set up in BIOS. I just wish I had some of those great D9 sticks. But I can't find any here in my country :( . I'm from Roumania
http://img412.imageshack.us/img412/9...500mem1200.jpg
EDIT: What do u think I could improve on this OC?
Great results ,compatriot din pacate ai dreptate greu de gasit D9GKX la noi in Romania.:up: try raport 1:1 and multiplier 7.5*600=4.5GHZ the performance it's even higher.:up:
USA people....Micro Center has 3 great deals on Intel CPUs:
E7400 Retail Box $99.99 http://www.microcenter.com/single_pr...uct_id=0301964
E8400 Retail Box $139.99 http://www.microcenter.com/single_pr...uct_id=0299046
Q9400 Retail Box $179.99 http://www.microcenter.com/single_pr...uct_id=0301968
"What do u think about this? "
I think it looks very good. < 1.4v 4500 and 10hrs Orthos. Nice setup and work getting it to run so well.
I got this tonight. 1.45 vcore.
[IMG]http://img24.imageshack.us/img24/7366/49b.jpg[/IMG]
coop nice post count 666 lol
wanna trade E8500 i'll put it on my phase :D
what settings did you use for that run ?
I did not notice post count. :devil:Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 9
Fine CPU Clock Ratio...................: 0.5
CPU Frequency .........................: 4.902GHz (516X9.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 516
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control
CPU Clock Drive........................: 800
PCI Express Clock Drive................: 1000
CPU Clock Skew (ps)....................: 50ps
MCH Clock Skew (ps)....................: 100ps
DRAM Performance Control
Performance Enhance....................: Turbo
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: 333MHz
System Memory Multiplier ..............: 2.40D
Memory Frequency (Mhz) ................: 1238MHz
DRAM Timing Selectable ................: Manual
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
Everything In Advanced Timing Control on auto.
but tRFC 56 and Drive Strength Profiles OC-1200
DDR Write Training: Disable
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Disabled]
CPU Vcore..............................: 1.45V
CPU Termination........................: 1.38V
CPU PLL................................: 1.61V
CPU Reference..........................: 0.914
MCH/ICH
MCH Core...............................: 1.40V
Reference..............................: 0.794
MCH/DRAM Ref...........................: 1.12v
ICH I/O................................: 1.5V
ICH Core...............................: 1.100V
DRAM
DRAM Voltage...........................: 2.26v
DRAM Termination ......................: Auto
Channel A Reference....................: Auto
Channel B Reference ...................: Auto
I'm done with s775 but I can't help but take peeks in here every now and then and I have to say this; this thread may just about hold the most impressive overclocks on the planet. Says a lot about the mobos the thread is dedicated to, but it also says a lot about the overclocking talent in here. Kudos, guys!! Keep up the good work. :up:
Looking good so far.
http://i679.photobucket.com/albums/v...gg/Capture.jpg
Guys Does my UD3LR SUCK ?
Its Q6600 time again, first go I got 4.32GHz easy :D
http://img10.imageshack.us/img10/1082/wprime32m.jpg
