i wouldn't say that because my x2 4000 had a vid of 1.35 and did 3.245 GHz @ 1.46
Yeah, we all know that enthusiasts are world class engineers :rofl:Quote:
According to our sources, AMD worked with some selected enthusiasts to enable LN2 cooling as well and the CPUs should not suffer from “cold bug”. Does this means we’ll start seeing 5GHz+ clocks on AMD processors as well?
It's just the way it was worded made it sound like being an enthusiast made you an engineer :p:
Like AMD needs some random overclocker with LN2 to get their chips working with lower temperatures. :ROTF: Does the overclocker tell them how to fine tune their process and fix few glitches in the march? :rolleyes:
I imagine it's more like "What is it you like to see? What is your process for overclocking?" Be certain that the engineers designing these chips often aren't world-class overclockers. They're world-class CPU engineers, and there's a bit of a disconnect there. By getting input from real-world enthusiasts, they can do their engineering magic to accommodate certain chip behavior if they want to.
It doesn't sound far-fetched to me at all. We see it all the time with motherboard manufacturers hiring overclockers to do testing. Why would it be absurd in the realm of CPUs?
AMDs have had a nasty coldbug since the 90nm A64s, I'm SURE this isn't the frst AMD's heard of it and I'm sure they know it's an issue to enthusiasts. Why collaborate with enthusiasts for them (the enthusiasts) to tell them what has been common knowledge for all this time?
Let's be real, Oj101, it was probably a lot more involved than:
"Hello, AMD guys!"
"Nice to meet you!"
"Cold bug!"
"Oh, ok! We'll fix it!"
"Bye!"
"See you!"
:D
I'll counter you with a why not and my expanded scope/involvement. There's not really any compelling reason not to see what the WC OCers are doing in detail if they want to appeal to enthusiasts. Getting frequencies up is one thing. Getting a chip to respond favorably to the techniques in use is a bit of another.
Because being an engineer doesn't make you a world class subzero overclocker, and so collaborating with these enthusiasts allows you to test your new processor with this sort of cooling under real enthusiast conditions by providing them samples, and then reporting the results to the actual engineers maybe?
It does not really benefit them directly, but if they keep the enthusiasts happy then this will work in their favor. They probably won't set any performance records when the chip can be run at LN2 temps, but it still be attractive to many overclockers if they can use it under LN2, even if it is just for some fun. This will get AMD in a more positive light for those particular enthusiast and they will do the talking for AMD. A bit of a marketing strategy as enthusiasts are probably the most vocal group of customers and enthusiast have quite a bit of influence on the consumer market.
AFAIK the cold bug was one of SOI side effects. I'd like AMD to come closer us though.
I have none either, but I recall reading something about it in some random AMD thread. Though, I agree that it could be very well possible that what I read was false and it could be possible that I don't recall it properly or I could've misunderstood the whole point or... :p:
Edit: Did some googling and it turns out that SOI indeed has nothing to do with this.
I'm not even saying they are trying to fix something like a cold bug but when you have someone like Macci in the house, i just can't see what would be wrong about asking him to have some freezing sessions and report his findings, then in the design process they could be lucky and find a light modification that is not too costly and helps a lot with cold bug. Or maybe they just don't care :shrug:
Every CPU has a coldbug at some temperature, but for some it's at such a low temperature that you won't ever reach it with LN2.
It is possible to go subzero with the current Phenom chips like this one:
http://www.xtremesystems.org/forums/...d.php?t=206289
But it still has a cold bug somewhere, just not at the temperatures that he was reaching.
The same was for certain Penryn quad-cores at the start of this year, some would crash when used under LN2 and some were fine. It's just that Intel's 'coldbug temperature' has always been much lower than AMD's and that's why it's much more obvious on AMD chips.
Yes, indeed, But wasn't it K8 which brought severe coldbug for AMD? E.g. K7 was much more flexible under subzero cooling and could go far beyond where K8 got bugged.
http://www.pcper.com/comments.php?nid=6455
Update: The Phenom II reached 6 GHz+ at 1.9v on liquid nitrogen (boiling point -321F/-196C at 1 atm). Testing looks to have been done on a Gigabyte 790GX motherboard that is currently available.
:shock::shock::shock::shock::shock::shock::shock:Quote:
