Well with the settings bellow:
I can run stable orthos or prime until the FFT`s 768 or 896 around 1h of test. When within that zone the computer restart, but the curious is if i run just this FFT`s on custom test i pass without problem.Code:******Gigabyte EP45 UD3P******
E8500 500 X 8.5 4250MHz BIOS F7
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ 0.5 ]
CPU Frequency 4.0GHz...........................[ 500 x 8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 500 ]
PCI Express Frequency (Mhz).....................[ 102 ]
C.I.A 2 ..................................................[Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 700mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance .............................[Standard]
Extreme Memory Profile (XMP)....................[ Disabled ]
(G) MCH Frequency Latch.........................[ 400MHz ]
System Memory Multipler.........................[ 2.00D ]
Memory Frequency 1066...........................[ 1000 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD............................................[ 4 ] Auto
tWTR............................................[ 4 ] Auto
tWR.............................................[ 8 ] Auto
tRFC............................................[ 68 ] Auto
tRTP............................................[ 4 ] Auto
Command Rate (cmd)..............................[ 2T ]
******Channel A Timing Settings******
Static tRead Value [ 11 ] ................[ 9 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.25 ]...................[ 1.42500 ]
CPU Termination [ 1.20 ]...................[ 1.34 ]
CPU PLL [ 1.50 ]...................[ 1.61 ]
CPU Reference [ 0.760 ]...................[ 0.878 ] ET6 Show 0.815
MCH Core [1.1 ]...................[ 1.30 ] Tested 1.28-1.38
MCH Reference [0.760 ]...................[ 0.808 ] ET6 Show 0.72 Tested 0.74
MCH/DRAM Refernce [0.900 ]...................[ Normal ]
ICH I/O [1.500 ]...................[ 1.570 ]
ICH Core [1.100 ]...................[ 1.200 ]
DRAM Voltage [1.800 ]...................[ 2.140 ] Tested 2.1-2.18
DRAM Termination [0.900 ]...................[ Normal ]
Channel A Ref [0.900 ]...................[ Normal ]
Channel B Ref [0.900 ]...................[ Normal ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
Any suggestion to get stability beyond that?
