For ram overclocking choose Biostar.
You can set the multiplier in the AI Tweaker settings, but then you can also set it somewhere else - it's in the next section to the right in BIOS. Make sure that's not set on Auto... it's the same place where you can disable/enable Virtualization, C1E, etc etc etc.
Try playing with the GLT references for cores 1/3 and 0/2... Sometimes one of the four cores will be weaker than the others and require more voltage.
Yes, board needs new bios to properly support QX chips.
Multiplier is set to 8 , not auto .
I played with GTL Refs.
Now i have :
GTL 0/2 : 0.630
GTL 1/3 : 0.670
CPU PLL : 1.58
FSB Term. : 1.48
NB : 1.30 ( was 1.34, it seems that , i have to set it high again )
NB. GTL REF: AUTO
With these settings i get error in small FFTs in 8 minutes.
I'll set NB to 1.34 now.
Any other advices ?
By the way, is my Vcore enough for 425x8 ?
Edit:
With GTL REFs set to 0.630 and 0.670 got error in 1 minute. :shakes:
Now set the GTL REFs to AUTO and increased Vcore by 0.00625 = 1.3750
GLT on auto ;) i can run 500x10 whit auto on GLT
bios 1103 is best to E8600
1201 slow,s the mem,try a run superpi,an look;)
low volt om vcore,set a high NB volt
bios 1103 E8600 @ 4.6GHZ vcore 1.38XXv an fsb 1.3/NB 1,5v or 4.6GHZ “vcore 1.42500 an fsb 1.3,NB 1.26v
Okey, i'll do it.
But now
Vcore : 1.3750
PLL: 1.58
NB: 1.34
FSB TERM. : 1.48
GTL 0/2 , 1/3 : AUTO
GTL NB : AUTO
Stable for about 45 mins.(small FFTs)
As you said ; if it gives error again i'll change NB GTL REF.
Is there any danger to set the GTL REFs for CPU to AUTO ?
You're kidding right? uhhhh . . What has it been almost 2 years QX chips have been out? I don't get it??? All my older asus boards going back 3 chipsets supported the QX multis? This can't be right. Anyway when you set the multi in the manual section it should automatically change it in the cpu section as well. Something just is messed up here. :mad:
Or it's only with 1201 and 65nm Quads , as the York here works fine mate...
http://users.pandora.be/OAP/P5QDlx/xgman.JPG
Can I have your template plz just to test your settings (don't go bonkers on the ram as I only have 4gb kits here)
LLC enabled or Disabled ?
I knew I shouldn't have sold my QX9650. Seriously, wtf?
Can you adjsut multi up? I could not..10x would result in only one boot, then had to clear CMOS. That was enough for me to stop using the board, same qx9650...i mean really, all I want was 10x400, and couldn't get it.
I figured..$200 for the board...yeah, I know why it's so cheap...because the deluxe is part of value line!
Anyway, I thought maybe I had some other component that caused the issue, but everything is now working fine on BlackOPs...
for me up to 11 or so is no problem, have you guys tried a reflashn pop the battery and then see what happens could be a corrupt flash...
http://users.pandora.be/OAP/P5QDlx/xgman2.JPG
Yep, even swapped out the bios chips and tried flashing the secondary. You could look back through the thread for when I mentioned it, but I got rid of the board...had no issues with my E6600 or Q6600, so I figured must have been bios issues with QX...:shrug: Crap I hope it wasn't a duff board as I sold it to someone I don't really know...crap!
I usually run my Qx at 10 multi with 400FSB , I really haven't noticed any erratic behaviours with any bios... just with the E now I have some issues with LLC since 1201...
Well don't feel sad for the guy you sold it too... OC'ing is never warranted is it.. I sold my Qx9650@4ghz at 1.35 which I found very bad (CPU seriously degraded after my bench runs with the 780i), the new owner is so happy with it... he's having a ball...
And Xgman I'll pas it through mate, so your Qx is stuck at 9 in fact...
I can't get rid of an Unknown PCI Device in Device Manager :(
Got rid of Unknown Device by just letting the mobo-cd autostart but the other one is still there. I've disabled onboard audio, LAN2, firewire, IDE and expressgate in BIOS.
If I enable it my board (P5Q-E) seems to crash randomly, while booting XP, during surfing,... this E8400 on it does 4ghz at 1.21vcore, I have to set 1.275 in bios to get there without LLC... With LLC even with 1.225 it isn't stable... I flashed back to 1103 and now I can use LLC again on the E mobo... I tried 2 reflashes but prob persists on my mobo...with 1201 bios...
My P5Q dlx has no isues with it at all...
Did you properly install all the ATI drivers mate ?
