actually Touche requested it. stock??
hmmm, that should have booted 3.6 no problem. Have you tried that quick boost in ET6?
anniku989, try those again but disable the " DDR Write Training" and raise "tRFC" to something like 58. It is easy to change after boot w/memset.
Hi, I just finished building and overclocking my first system. Can you please tell me if these Settings are alright for 24/7...
Mobo - EP45-UD3P F6 Bios
CPU - e8500 @ 4.35 GHz
Memory - 2x2GB Mushkin 996599
Cooling - Nirvana 120
Graphics - HIS 4870
Case - Antec 1200
PS - Antec 1000
Robust Graphics Booster [Auto]
CPU Clock Ratio [9x]
Fine CPU Clock Ratio [+0.5]
CPU Frequency 4.35 GHz 458x9.5
CPU Host Clock Control [Enabled]
CPU Host Frequency [458]
PCI Express Freqency [100]
CIA 2 [Disabled]
Advanced Clock Control [All Default-No Changes]
Performance Enhance [Turbo]
Extreme Memory Profile [Auto]
MCH Frequency Latch [Auto]
System Memory Muliplier [ 2.40B]
Memory Frequency 1066 [1099]
Cas Latency Time 5 [5]
tRCD 5 [5]
tRP 5 [5]
tRAS 15 [15]
Advanced Timing Control [All Auto-No Changes]
Load Line Calibration [Disabled]
CPU Vcore 1.18750v [1.300v]
CPU Termination 1.200v [1.300v]
CPU PLL 1.500v [1.500v]
CPU Reference 0.760v [Auto]
MCH Core 1.100v [1.200v]
MCH Reference 0.760v [0.743v]
MCH/DRAM Reference 0.900v [Auto]
ICH I/O 1.500v [1.500v]
ICH Core 1.100v [1.100v]
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
Thanks...
I overclocked my Q6600 to 3.0ghz, the temp is just fine maz of 39C with only air cooling. I ran OCCT after 10 mins, it detailed that core#1 occured an error. What would that imply?
Specs:
Intel Q6600 @3.0 ghz
Gigabyte EP45-UD3R
Corsair Dominator 2x1gb 1066mhz
Palit GTX260 Sonic
Silverstone DA750
WD Raptor 74GB
WD Caviar Black 640GB
this really helped :up:
I guess it’s time for me to go beyond stock :D , is this a good starting point template for a Q9550@3.4 guys?
Code:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ + 0.5 ]
CPU Frequency 3.4GHz............................[ 400 x 8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 400 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 800mv ?? will leave unchanged ]
PCI Express Clock Drive.........................[ 900mv ?? will leave unchanged ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps or 50ps? will leave unchanged]
******DRAM Performance Control******
Performance Enhance.............................[ ????? will leave unchanged ]
(G) MCH Frequency Latch.........................[ ????? will leave unchanged ]
System Memory Multipler.........................[ ????? will leave unchanged ]
Memory Frequency 800............................[ ????? will leave unchanged ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD............................................[ Auto ]
tWTR............................................[ Auto ]
tWR.............................................[ Auto ]
tRFC............................................[ Auto ]
tRTP............................................[ Auto ]
Command Rate (cmd)..............................[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 10 ] ...............[ will leave unchanged ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled since I’m not planning for a high vcore and the board seems to handle this nicely]
CPU Vcore [ 1.21250 ]...................[ 1.20 - 1.25 ]
CPU Termination [ 1.20 ]...................[ 1.20 - 1.30 ] (1.2)
CPU PLL [ 1.50 ]...................[ 1.50 ]
CPU Reference [ 0.760 ]...................[ 0.76 - 0.863] (0.785)
MCH Core [ 1.100 ]...................[ default - 1.3] (1.24)
MCH Reference [ 0.760 ]...................[ 0.765 - 0.863] (0.80)
MCH/DRAM Refernce [ 0.900 ]...................[ 0.900 ]
ICH I/O [ 1.500 ]...................[ 1.500 ]
ICH Core [ 1.100 ]...................[ 1.100 ]
will leave those to auto
DRAM Voltage [ ]...................[ ?? ]
DRAM Termination [ ]...................[ ?? ]
Channel A Ref [ ]...................[ ?? ]
Channel B Ref [ ]...................[ ?? ]
*****************Advanced BIOS Features*********
Limit CPUID Max to 3 ................. [disable]
No-Execute memory Protect ............ [enable]
CPU Enhance Halt (CIE) ............... [disable]
C2/C2E State Support ................. [disable]
C4/C4E State Support ................. [disable]
CPU Thermal Monitor................... [disable]
CPU EIST Function..................... [disable]
Virtualization Technology ............ [enable]
Write Training improves your RAM performance. Sometimes disabling this will make your system stable but also sometimes it can give you such a great improvement that your better off raising your "Static T-Read" value one notch and leaving write training enabled. When you get your system stable you can play around with the RAM more(this is what I am doing now), I usually start off with a high T-Read like 10 or 11 and disabled write training, once that passes I start lowering the T-Read to it's lowest boot able level and then once that passes I try enabling write training.
Is anyone running a watercooled rig with the UD3-series?
I'm wondering what the better NB block would be and what possibly problems might occur.
Any input is much appreciated.
If it gets too hard or expensive I might just stick with a EP45-Extreme.
EDIT: I had e-mail correspondence with someone who owns a UD3P and he claims NB watercooling isn't necessary since the block is cool to the touch and he's running 500FSB+ on a Quad.
does the UD3P and UD3R have a CMOS switch/jumper that's easy to access in the back port?
Rock and Roll./.
http://img.techpowerup.org/090302/vantage24k-x3380.jpg
Great clock Viper
absolutely not! You gotta shove a screwdriver in between the pins to short them out. OR; you could get a jumper to close the pins. Which; by the way,
doesn't come with the board. Although 'everyone has a lotta jumpers, im sure'.
Kinda crappy really; but I have only had to reset my bios once so far, so.....
good in that respect.:shrug:
Hello, finally plugged in my Q9650 into this board this week and got around to 4.302 24/7 stable at vcore of 1.344.
Proof.
Does anybody have a link for a guide on what to do with Cpu Clock Skew and Mch Clock skew?
I read about those two settings in another forum a while back and that if properly tuned they allow you to get away with lower vcore for stability. Ofcourse back then I had a Q6600 and was more concerned with temps so I didn't pay attention to it but now that I've got a Q9650 I am wondering what to do with those two settings.
Thanks in advance.
With this board I am so new I can not answer for sure, my guess would be no. Auto setting usually lets the board decide the setting and if the board determines that disabled is the most stable then that is what you will get on auto. I noticed that when set to auto on my current setting it is the same thing as enabled. Somebody with more knowledge about this board would know for sure.
need some serious help please
those are my current settings
http://s5.tinypic.com/w7by53.jpgCode:******Motherboard Intelligent Tweaker (M.I.T.)******
C.I.A 2 [Disabled]
CPU Clock Drive.................................[ 800mv]
PCI Express Clock Drive.........................[ 900mv]
CPU Clock Skew..................................[ 0ps]
MCH Clock Skew..................................[ 0ps]
Performance Enhance.............................[ Turbo ]
Extreme Memory Profile (XMP)....................[ Auto ]
(G) MCH Frequency Latch.........................[ 400 ]
System Memory Multiplier........................[ 2.00D ]
Memory Frequency ..............1066...... ...800.....[ unchangeable ]
DRAM Timing Selectable..........................[ Auto ]
CAS Latency Time...............[ 5 ].........[ Auto ]
tRCD...........................[ 5 ].........[ Auto ]
tRP............................[ 5 ].........[ Auto ]
tRAS...........................[ 15 ].........[ Auto ]
tRRD...........................[ 4 ]..........[ Auto ]
tWTR...........................[ 4 ]..........[ Auto ]
tWR............................[ 6 ]..........[ Auto ]
tRFC...........................[ 72 ].........[ Auto ]
tRTP...........................[ 4 ]..........[ Auto ]
Command Rate (cmd).............[ 0 ]..........[ Auto ]
Static tRead Value [ 9 ] ................[ Auto ]
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.25 ]...................[ 1.18750V ]
CPU Termination [ 1.20 ]...................[ 1.20 ]
CPU Reference [ 0.760 ]...................[ 0.78 ]
MCH Core [ 1.100 ]...................[ 1.240 ]
MCH Reference [ 0.760 ]...................[ 0.800 ]
MCH/DRAM Refernce [ 0.900 ]...................[ 0.76 ]
DRAM Voltage [ ]...................[ Auto ]
DRAM Termination [ ]...................[ Auto ]
Channel A Ref [ ]...................[ Auto ]
Channel B Ref [ ]...................[ Auto ]
CPU Thermal Monitor................... [enable]
I have a feeling that the RAM speed, voltage, and trimming are all messed up :( , but frankly don’t have the knowledge to judge or decide anything here (googling & reading atm), I tried different settings in the “DRAM Performance Control”, if I set MCH Frequency Latch to 300 it only gives me 2.00D as an option, 400 opens 2.00B, tried both and didn’t notice any difference.
If I set the “System Memory Multiplier” to auto, the number in the “Memory Frequency” goes from 1066…800 to 1066….1280 but was afraid to save and apply this
I did something else that made the memory speed 533 (in cpu-z)and something else that made the trimmings 5-5-5-15 (in cpu-z)
btw, even if I enable the “CPU EIST Function” the CPU multi is still fixed @ 8.5 and the speed is fixed @ 3400 ?! :confused:
Try this...
For 3.4ghz you might need more then 1.18 vcore, try running at a voltage nearer to your VID at first and then lower it if you can. Remember with Load Line enabled you are going to notice about a 0.03v drop from your bios setting in CPUZ, so if your target voltage is 1.25 you need 1.28 set in bios. I am not good enough at setting reference voltages but since you are only trying for a 425FSB overclock you should not be raising your Termination and MCH core levels high enough that the auto setting will hold your stability back to much and one of the better OC guys can help you set your reference volts later. You might end up needing slightly higher Termination and MCH levels, I am new to this board but I am sure this will start you in the right direction. I never use any of the Advanced BIOS crap like Virtualization/Thermal Monitor/No-Execute since this can cause stability problems, especially turn off Virtualization unless you actually use it to run Virtual OS's. Also, with your RAM being a 2x2gb 1066mhz kit I would use the 2.4B setting to get a bit closer to your standard ram speed(example is 425fsb x 2.4b = 1020mhz RAM speed). If you can, use the Ram multi's that are attached to the 333mhz and 400mhz latch but other latches can be used as well depending on what RAM speed you are aiming for. Also make sure you set your Ram voltage to specs, I am assuming the spec for your kit is 2.1v and the 1.050 reference for that voltage is good.Code:******Motherboard Intelligent Tweaker (M.I.T.)******
Fine CPU Clock Ratio............................[ + 0.0 ]
CPU Frequency 3.4GHz............................[ 425 x 8.0 ]
CPU Host Frequency (Mhz)........................[ 425 ]
C.I.A 2 [Disabled]
Performance Enhance.............................[ Standard ]
(G) MCH Frequency Latch.........................[ Auto ]
System Memory Multiplier........................[ 2.40B ]
Memory Frequency ..............1066...... ...1020
CAS Latency Time...............[ 5 ].........[ 5 ]
tRCD...........................[ 5 ].........[ 5 ]
tRP............................[ 5 ].........[ 5 ]
tRAS...........................[ 15 ].........[ 15 ]
tRFC...........................[ 72 ].........[ 54 ]
Command Rate (cmd).............[ 0 ]..........[ 2T ]
Static tRead Value [ 9 ] ................[ 9 or 10, lower is better if it boots and is stable ]
Drive Strength Profile..........................[ 1066 ]
CPU Vcore [ 1.25 ]...................[ 1.28V ]
CPU Termination [ 1.20 ]...................[ 1.30 ]
CPU Reference [ 0.760 ]...................[ Auto ]
MCH Core [ 1.100 ]...................[ 1.26 ]
MCH Reference [ 0.760 ]...................[ Auto ]
MCH/DRAM Refernce [ 0.900 ]...................[ 1.050 ]
DRAM Voltage [ 2.10 ]...................[ 2.100 ]
DRAM Termination [ ]...................[ 1.050 ]
Channel A Ref [ ]...................[ 1.050 ]
Channel B Ref [ ]...................[ 1.050 ]
No-Execute memory Protect ............ [disable]
Virtualization Technology ............ [disable]
EDIT: I changed your overclock from 8.5x400 to 8x425 since this board can easily handle 425FSB. With 425FSB you should get much better RAM performance then with the 400FSB you were aiming for. Your perfect Vcore could be lower then what I put in the code but since I do not know your VID or if you have passed a small ftt run at 1.8vcore I changed it to 1.28(~1.25 in reality) just to get you started. If for some reason the 2.4B multi does not boot due to the bug associated with it you can try 2.5A for 1062mhz RAM.
well I initially set the vcore @ 1.28 then started lowering it till 1.1875 (nothing less worked) and passed about 20 minutes prime95 (the one in the screenshot), I don't really know how else to determine what’s best since all seemed to handle prime95 fine unless 20 minutes is too short, I also tried to follow what OC Nub mentioned in his post
I forgot to disable Virtualization, don't really care about Thermal Monitor (CPU overheating thingy) and No-Execute (buffer overflow attacks thingy) but saw some templates with both enabled and said why not
I saw the 2.4 settings but didn't try it, will test it today (found good info here)
yes spec is 2.1
I’m at work now, will try the settings you attached when i go home, I’ll even try to see if 8.5X425 works after I settle the memory settings.
did you notice the 5-7-7-7-20 timings? this can't be normal right?
@fatguy
my BIOS setting
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto or Fast
CPU Clock Ratio ..........................: 8
CPU Frequency ...........................: 3.0
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 375Mhz
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< 800
PCI Express Clock Drive.................: <<< 900
CPU Clock Skew (ps)....................: <<<
MCH Clock Skew (ps)...................: <<<
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 3.00A
Memory Frequency (Mhz) ..............: 1050
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................15
tRRD...........................................3
tWTR..........................................5
tWR............................................6
tRFC...........................................56
tRTP...........................................4
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength ............................1066
Channel A
Static tRead Value.........................:10
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Specs:
Gigabyte EP45-UD3R
Palit GTX260 Sonic
Silverstone DA750
WD Raptor 74GB
First overclocking attempt on EP45T-UD3R / TG Xtreem PC3-15000 2GB kit.
http://img11.imageshack.us/img11/238...0303141611.png
and here's on the next booting with 500x9 and at DDR3-2000.
this one is not nearly stable enough to try SuperPi, i still need to work on some bios setting yet.
http://img11.imageshack.us/img11/452...0303200906.png
