Page 1 of 3 123 LastLast
Results 1 to 25 of 55
Thread: Another waterblocks on i7 thread
    Jul 2008
    Winterthur, Switzerland
    Hi everyone. These past few weeks I've been doing a lot of test runs for waterblocks on the Core i7. Today, I can present the first set of results.
    Thanks to XSPC and Aqua Computer for providing me with test samples!
    Having said that, let me dive right into the test setup and -methods.
    Test Setup
    Hardware used:
    - Intel Core i7 920 @ 3.7GHz, 1.28V
    - Asus P6T
    - 6GB Mushkin XP12800
    - T-Balancer BigNG and Sensorhub for measuring and logging temp data
    - Three digital thermal probes measuring ambient temps
    - Arctic Cooling MX-2
    Cooling loop:
    - Swiftech MCP355 with EK X-Res top
    - Digmesa Flowmeter
    - Four inline thermal probes
    - XSPC RS360 radiator
    - 3x Nanoxia FX1250 fans @ 1200rpm
    - 13/10mm tubing
    Sftware used:
    - T-Balancer Navigator
    - RealTemp 3.0
    - CoreDamage
    Testing Procedure
    The testing is done with the above hardware set up in a CPU-only loop so that there is no thermal interference from other components in the loop.
    A test run has a duration of 40 minutes during which the CPU is fully loaded using CoreDamage. I did a lot of preliminary testing and determined CoreDamage to be the best suited program, because it produces very high and very stable temperatures. The 40 minutes might seem short, but in my testing I got identical, just as repeatable results after 40 minutes as after 60 or 90 minutes.
    From the 40 minutes of CPU-burning, I collect all the data from the last 20 minutes of each run and average out all the data to get average Core temperatures, average water temperatures and average ambient temperatures.
    Blocks Tested
    Here are the four blocks currently tested, with external and internal pics for each:
    Aqua Computer cuplex XT di (new version):
    Note: This is a new revision of the XT di. Internal pics show a comparison of old vs. new base plates and insides of the top (new version on the left, older version on the right).
    Watercool Heatkiller 3.0:
    XSPC Delta V3:
    EK Supreme:
    Flowrates
    I simply measured the flowrates achieved in the loop with the pump at 12V with each block. Since all other parts of the loop are always equal, this represents the restrictiveness of each block.
    Results:
    The graph really speaks for itself here. Both the XSPC and the HK 3.0 achieve very high flowrates. The XT di is more restrictive, but nothing to worry about, IMO and the EK Supreme is restrictive as ever.
    Orientations
    Each block is mounted and tested six times. Three times in one orientation and three times in an orientation rotated by 90°.
    I test each block in two different orienations that I describe as
    Vertical:
    and Horizontal:
    Vertical and Horizontal are the directions the water flows in when the block is mounted on a mainboard inside a normal ATX-case. This is why I chose these descriptions. The problem here is that the socket's orientation on the mainboard isn't always the same. Some mainboards (e.g. Gigabyte) have 90° rotated sockets. So, to be very clear about this, here is a picture showing the directions of flow accross the CPU itself, and what I refer to these directions as:
    Averaging out the results from three mounts per orientation, this is what we end up with:
    NOTE: Since my post about the EK Supreme orientation, some minor tweaks to the test-setup were made. Also, the test rig was repositioned in the room along with the thermal probes. This is why the Supreme was retested and I got slightly different results from those initial runs posted before.
    As we can see, with the EK Supreme, it doesn't matter which way it's oriented, the cuplex and the Delta V3 perform better in a horizontal orientation and the HK shows improved performance when mounted vertically.
    Temperatures
    Finally, let's take a look at temperatures achieved.
    Here are the three runs in the optimal orientation for each of the blocks:
    EDIT: (The temperatures are sorted from lowest to highest to keep things tidy)
    And here are the averaged out temperatures from the above three runs:
    As we can see, the new cuplex XT di almost catches up with the Supreme on a Core i7. The HK 3.0 is way ahead of the pack, though. The Delta V3 falls behind, thought it's performance isn't half-bad. The very strong competition here just makes it look like the V3's performance is sub-par.
    Although most of you are probably aware of this, I do want to caution against making statement of the "block A is X° better than block B" kind. The actual temperature difference between the blocks is dependant upon the amount of heat the CPU produces. Different model CPUs and different VCores will produce greater, smaller or different results than seen here.
    Temperatures in relation to flowrates
    The last part of testing consists of lowering flowrates by using a shutoff valve and measuring how this impacts temperatures. I lower the flowrates to predetermined values with 30l/h or 60l/h increments. converted to GPM, the increments don't make as much sense as in l/h, but the important point is that each block is tested at identical flowrates.
    Because of this, the following graph does not take into account the different levels of restrictiveness each of the blocks has.
    Here, it's interesting to see that all block but the EK Supreme show almost identical curvatures. The Supreme is the one block among these tested here that gains more cooling performance with increased flow than the rest.
    Quick Conclusion
    The Watercool Heatkiller 3.0 really takes the cake here. It delivers great cooling performance while being very un-restrictive at the same time. It looks like the EK Supreme, while still a great block, no longer reigns supreme...
    The new cuplex is definitely better than the previous one: It's less restrictive and the performance is better since the last version wasn't this close to the performance of the Supreme yet. It's still a gorgeous block and I can recommend it to anyone who likes it's looks.
    The XSPC is very un-restrictive but it's cooling performance can't shine in this comparison. It is the cheapest block among these tested here, though and i was very impressed with how well crafted it was. For anyone looking for a low-budget block for a system where maximum performance isn't the highest priority, the Delta V3 is definitely worth a look.
    This report is a brief of a full article I did in German: Link
    The data is all here, but in the DeXgo-article there are a lot of extra pics and more detailed descriptions of each block.
    Cheers,
    Shane
    Sep 2007
    Germany, Solingen
    once again
    Your results meet my expectations and my own experiences on socket 775.
    Aug 2005
    Washington
    Thank you.
    Engineering The Xtreme
    Feb 2007
    MA, USA
    thanks for the test, when I go i7 this heatkiller 3 is gonna be my waterblock
    Feb 2006
    Vienna, Austria
    great review!
    i think that the biggest advantage of the heatkillers are those deep channels, great flow and huge surface area!
    Core i7 2600k|HD 6950|8GB RipJawsX|2x 128gb Samsung SSD 830 Raid0|Asus Sabertooth P67
    Seasonic X-560|Corsair 650D|2x WD Red 3TB Raid1|WD Green 3TB|Asus Xonar Essence STX
    Core i3 2100|HD 7770|8GB RipJawsX|128gb Samsung SSD 830|Asrock Z77 Pro4-M
    Bequiet! E9 400W|Fractal Design Arc Mini|3x Hitachi 7k1000.C|Asus Xonar DX
    Dell Latitude E6410|Core i7 620m|8gb DDR3|WXGA+ Screen|Nvidia Quadro NVS3100
    256gb Samsung PB22-J|Intel Wireless 6300|Sierra Aircard MC8781|WD Scorpio Blue 1TB
    Harman Kardon HK1200|Vienna Acoustics Brandnew|AKG K240 Monitor 600ohm|Sony CDP 228ESD
    Nov 2007
    +1
    why don't put ybris eclipse in this test?
    sorry for my english
    WAITING FOR SOMETHING...
    FULL LIQUID BY YBRIS
    Ybris A.C.S. FULL CHROME Limited Edition N°058 | Ybris A.C.S.-G FULL CHROME Limited Edition N°058 | SANSO PDH-054 12V A.F. | Feser Xchanger Q.R. 480 with Feser Xtender blue\Scythe Ultra Kaze 3000rpm | Tecnofront Bay Trap | Tygon R-3606 3\8" 1\2"
    Oct 2007
    EK Supreme FTW+++++++++++...falls!
    It's no longer the top, but I love my GTZ.
    Current Project: City of Light, (sortof) Updated 3/25 - A New Arrival
    Unoriginal Macho Energy
    Dec 2002
    Hmm, I find it rather odd the huge differences in temps... would be much better if you plotted each mount like I used to do so we can get a real picture of what is going on. It is way too vague to draw any conclusion IMO.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Jul 2008
    Quote Originally Posted by G-UNIT91 View Post
    +1
    Don't have one. Do you have connections to the guys at Ybris? I tried sending them e-Mails but I didn't get any replies.
    Quote Originally Posted by nikhsub1 View Post
    Could you elaborate? What data do you want to see?
    Feb 2007
    he would like to see the data of all the mounts.
    Jul 2008
    Damn! I actually forgot posting that graph and didn't notice at all!
    Here's the graph in question:
    It was meant to be in the first post all along, of course. I'll edit it into the first post right away.
    Dec 2002
    Do you have a robot doing your mounts? I could never keep them that consistent! This tells me that none of the blocks are bowed...
    I am Xtreme
    Aug 2008
    are you guys using sub second sampling time when acquiring temps? realtemp's lowest sampling time is 1sec
    Admin
    Feb 2005
    Ann Arbor, MI
    1800x4 (CPU) and 1800x6 (air in) for me as well.
    Nice testing! Kind of in awe at the high flowrates of the HK and the simultaneous great temps, looks like a great block
    Jul 2008
    No, but I tested a bunch of different programs for loading the cores and found out that CoreDamage delivers higher temps with greater stability than any other program. Prime95 at fixed 8K is less hot and has slightly more fluctuations in temperature. Ultimately, this makes a big difference for repeatability.
    Also, I thinly spread out the thermal paste over the whole surface of the IHS for each mount, since this is the method that gives me the most repeatable results.
    Finally, I use MX-2 as thermal grease because again, this is the grease that showed the least variation accross five mounts out of a sample of four or five greases that I tested.
    So basically, I put a lot of work into making sure that variations between mounts are minimal. And it pays off. In my prior testing on 775, I had huge deviations between mounts...
    Quote Originally Posted by mcoffey View Post
    I don't, log every 1 second. But I do average out over 1800x4 data points to get my average core temps on a run. 1800x3 for average rad air in temp.
    andyc
    I log every 5 seconds and use the data of the last 20 minutes of the run.
    So that's 240x3 for ambient and 240x4 for water temps.
    I am Xtreme
    Aug 2008
    Quote Originally Posted by HESmelaugh View Post
    yep i agree with the thin tim all over the surface...thats how i do it too...good choice...its repeatability is better than putting a dot in the center...
    also i know you did 6 mounts so i'm assuming you took the best 3? which results to low deviation? good job nonetheless
    Nov 2007
    you have PM...
  18. #18
    Jul 2008
    Honda: Yes, I do six mounts. Then I look at the results to determine which orientation is better. The graph shows the three mounts of the better orientation.
    I was thinking of maybe doing five mounts and omitting the highest and lowest results, treating them as outliers due to measurment error. But I'm quite happy with the deviations so I stuck to three mounts and tested the orientations instead.
    On two blocks I tested, I got the exact same result on all three mounts, down to the decimal. (results of those and further blocks will be posted later)
    Made me very proud of my mounting skillz.
  19. #19
    I am Xtreme
    Aug 2008
    I've always wondered about this really. As far as useful data to the average, or above average user, why not use the best mount?
    andyc
    sounds good....if i consider the best..then all else would be errors..
    i have bad logic sometimes
    i like highlighting the best mount..then adding the two good mounts out of the five....all else are considered errors(mine of course)
  20. #20
    Oct 2008
    Sweden, Dalarna
    How about adding this one to the "Liquid Cooling · Information/Guides & Reviews/Tests" post?
    Really nice results! The heatkiller really preforms on i7s!
  21. #21
    Xtreme Guru
    Aug 2003
    Athens, Greece
    Thanks for sharing your results. Great work!
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
  22. #22
    Xtreme Mentor
    Oct 2005
    Wow the HK3 owns...
    Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
    —Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
  23. #23
    Sep 2007
    Germany, Solingen
    Quote Originally Posted by Hondacity View Post
    ...i like highlighting the best mount..then adding the two good mounts out of the five....all else are considered errors(mine of course)
    One of the best features of the Heatkiller is the mounting system with the original backplate. You won´t have any bad mountings
  24. #24
    Feb 2009
    And I was going to order the XSPC Delta V3 for my i7, looks like I'll have to change that if I can attain such a similar flow rate through the block
  25. #25
    Jun 2008
    Hanover Park, IL
    I've been looking hard for something beyond the anecdotal to justify ordering a HK. Thanks, HESmelaugh!
    One question: What backplate(s) did you use for testing?
    Again, thanks for the hard work!
    i7 940 + HK LT, GTX 480 SLI
    ASUS P6T DLX V2, 6gig Corsair Dominator 1600
    2XDDC 3.2 18watts, PC LRT, pure distilled+silver, TC PA120.3/TFC 120.1
    2x150gigWD RaptorX, 4x1tbWD BLK SG, 1.5tb external drives
    SB Titanium PCI-X, Logitech z2300, Triton AX PC Pro
    2xMemorex DL DVD burners-USB attached
    Samsung 225BW & 204B
    MM U2 UFO powder coat+12x120MM fans, Enermax Galaxy EVO 1250W, Windows 7 U64
