Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Exposed Copper/Corrosion on EK 6970 Block..
    Aug 2009
    Louisville, KY
    Ive had this block for a little under a month.. I had to do a rebuild a couple of weeks ago and when I went to take a look at one of my GPU blocks I found this
    http://i.imgur.com/t3fJk.jpg
    http://i.imgur.com/QmqZY.jpg
    My loop is Distilled Water with a silver kill coil. I emailed Eddy from EK about this with these pics and his response was
    >>> EK Edvard König <e.koenig@ekwaterblocks.com> >>>
    Hi!
    This looks like a dirt to me.
    Best regards, Eddy
    Since this email Eddy has ignored the rest of my emails...
    Does anyone know what would cause this to happen on such a new block? I have other Nickel/Acrylic things in my loop and I do not see any exposed copper on them..
    Banned
    May 2009
    Melbourne, Australia
    take some photos in the daylight. we cant make out anything.
    Aug 2009
    Louisville, KY
    Quote Originally Posted by zeropluszero View Post
    I take terrible pics you're correct.. but you can easily see the copper if you zoom in on the pics.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Too much glare to see anything. Get it in some good light, don't use a cell phone flash...
    But seeing copper doesn't equal corrosion.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Xtreme Cruncher
    Jan 2009
    How about opening the block?
    SB 2600K
    MSI P67A-GD65
    8GB 1600/CL8
    GTX580
    64GB SSD
    4TB
    Xonar DX
    BeQuiet Straight Power 680W sleeved
    in
    Cosmos 1000, modded
    TC PA120.3+XSPC RX240mm+XSPC RASA+DDC1T+OCLabs top+EK Multioption 150+ EK-FC580
    Mar 2005
    Slovenia - EU
    Well, sending me such picture it does look like a dirt to me...
    Quote Originally Posted by creidiki
    EKs are like waterblock pr0n
    Mar 2011
    I actually have some black marks in the nickel at the same place on my 6970 block. And the block is about 1.5 month old with just distilled water running through it.
    Oct 2010
    It doesn't look like dirt to me, but those are some terrible pictures. Try taking some without flash, and we'll be able to get a better glimpse.
    Water
    Air
    WC: EK Supreme HF | EK FC-6970 | 2x DDC 3.25 | EK DDC Dual V2 | EK Res X2 250 | TFC X-Changer 480
    Jul 2008
    Looks like a ty plating job to me but would it be worth the hassle of getting a new block? Hell no. The nickle plating over the copper does absolutely nothing but protect the copper from tarnishing.
    MM H2gO - Win 7 Pro
    2 PA120.2 Thermochill
    MCP355 w/XSPC res top
    i5-2500k @ 5.0ghz w/Heatkiller 3.0
    Corsair HX850 - M IV Gene-z
    GTX 480 w/DD 480 ni/cu
    Mar 2011
    DAMN!!! I just looked at my block to get a picture and just saw it had worsen!!! It's just not black marks any longer but bare copper is visible... Looks like I have to RMA the block...
    Oct 2010
    Well, when I posted about the terrible finish on my first block, Eddy promptly contacted me for a replacement. Since your problem is far worse than mine, you should have no trouble.
    Water
    Air
    Aug 2009
    Louisville, KY
    Quote Originally Posted by nvmc View Post
    I thought the same thing.. instead I was told it was dirt
    I am Xtreme
    Dec 2008
    France
    You need to take pics without flash... Otherwise it's really hard to tell...
    Donate to XS forums
    Feb 2010
    Northern California
    that's cause your picture is absolute ..borrow a camera from someone, even if you have to 1 hour photo it.
    you know you're addicted to watercooling when:
    Quote Originally Posted by Onoff312 View Post
    You started with a $200-400 budget and have ended up spending over $1000-2000
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    WOAH did u learn how to take pictures from me?
    You have way too much flash for us to see anything...
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    I had a similar issue with my 285 blocks...
    However, in my case it took two years.
    Nov 2009
    Netherlands
    Quote Originally Posted by NaeKuh View Post
    NaeKuh, I can't believe I'm saying this, but most of your pictures look better .
    Anyway, it doesn't look like dirt, but it's hard to tell from the pictures.
    “Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's Guide
    It's better to ask dumb questions now, than to look stupid later
    Mondays:
  18. #18
    Crunching For The Points! NKrader's Avatar
    Dec 2005
    Renton WA, USA
    i see the vigin mary. somwhere in there..
    OMFG
  19. #19
    Mar 2010
    Irvine, CA
    I have something like that going on on my blocks, but it was only near the gpu core, so I thought it was maybe because the water boiled in there. But maybe theres a defect? I wonder if I could get a replacement
    Project Elegant Dreams
    CPU: Intel 980x (3005F803T) @ Stock , Mobo: Rampage III Extreme, Ram: 24GB Corsair Vengeance 1600 C9 1T 1.51v GPU: SLI EK'd Vanilla GTX580, 0.875v @ idle.
    Sound:Asus Xonar Xense w/Sennheiser PC350
    SSD: 2x OCZ Agility 3 120GB RAID-0 on ICH10 Storage: 2x1.5TB Hitachi 5K3000, 1.5TB WD Black, 1TB F3, various other HDD's Case: Obsidian 800D, PSU: Corsair AX1200,
    Water Cooling
    Main Loop
    EK Supreme HF
    EK GTX480 blocks on EVGA 580s
    MCP355 and MCP35X in serial
    Dual BlackIce GTX480 Rads
  20. #20
    Mar 2005
    Slovenia - EU
    Hey, EK is currently investigating these cases and trying to find logical explanation.
    Once we find the answer we will present it to you immediately.
    But I have to say that nickel is nickel. We have tested the thickness of nickel layer with the blocks that were shipped back to us and everything looks fine ~4micron layer.
  21. #21
    Aug 2009
    Louisville, KY
    I agree that my pics suck.. I took them with a cell in a dark room.
    I already put the rig back together a week or two ago. I really dont want to tear down the rig to pull the block off unless Eddy is going to send me a replacement. I think the pics show the exposed copper even though they do indeed suck.
  22. #22
    Mar 2011
    Nickel or not, it's coming off and the only thing in my loop is distilled water.
  23. #23
    Banned
    Apr 2010
    What did you use to clean your blocks? It is possible that whatever you used damaged the platting. I have seen similar results (my friend) on his CPU block just after he cleaned with vinegar and reinstalled. Also, the platting around the in-flow seemed to take on the damage first. I am wondering if the flow + pressure caused the platting to fail in that area.
  24. #24
    Jan 2004
    Quote Originally Posted by Xrim View Post
    Do you by chance have a killcoil or some other form of silver in that loop somewhere with the distilled water? If so, see this thread:
    http://www.xtremesystems.org/forums/...d.php?t=270567
    Dimastech Easy Dual v2.5 (black)-----Silverstone Strider 1500w-----ASUS Maximus IV Extreme-----Intel 2600K-----Corsair Dominator GT (4x4GB) DDR3 2000-----2x Samsung 840 Pro 256GB SSD's-----2x GTX Titan 6GB SLI-----Dell 3008WFP
    Watercooling Loop: EK Supreme HF Rev. 2 - Acetal-----2x EK-Titan Acetal connected via EK-FC Terminal Dual Parallel-----2x Swiftech MCR320 Drive Radiators w/ built-in MCP35X Pumps-----EK-MultiOption RES X2 - 250 Advanced-----6x Scythe GT 1850rpm Fans-----Primochill LRT 3/8" ID - 5/8" OD (Red)-----Bitspower Carbon Black Fittings-----Distilled Water + PT_Nuke PHN + Feser Base Corrosion Blocker
  25. #25
    Jan 2008
    Reading few threads with the same issues.. All have one common, "distilled" water + this + that...
    Why not using the on shelf watercooling liquid.. Fluid xp+ and many brand..etc. They got clear fluid also.. Many years without problems..
    $10-$30 per bottle better that up ur $100+ blocks..
    FS: MM UFO Horizon Black + Clear Side/Top
