XtremeSystems Forums
Reply
Old 02-15-2009, 06:47 AM   #1
Factotum
Send a message via ICQ to Factotum Send a message via MSN to Factotum Send a message via Skype™ to Factotum
Hi guys. What do you think about WC of DFI UT x58-T3e8?
My EK NB MAX suited to NB
My MCW30 suited on SB.
What can be put on VRM?
thanks
Last updated:
You can remove the upper radiator from the north and install WB instead
MOBO W/O upper rad on NB:
I set on NB EK NB S-Max - this 100% compatible
NB's WB to help cool mosfet via heat pipes
NB compatibility list:
EK-NB S-MAX
EK-NB S-MAX Acetal /checked by me/
EK-NB/SB 5 /NOT CHECKED/
EK-NB/SB 5 - Acetal /NOT CHECKED/
MCW30 /checked by Praz/ checked by msgclb/
SB compatibility list:
EK-NB/SB 6 /NOT CHECKED/
EK-NB/SB 6 - Acetal /NOT CHECKED/
PWM compatibility list:
Watercool HEATKILLER SW-16 /CHECKED by me/ this 100% compatible!!!
MIPS MCH149 V1 - NOT compatible /Checked by rioja/
EK-Mosfet DFI UT /NOT CHECKED/
EK-Mosfet DFI UT - Acetal /NOT CHECKED/
Links:
WB PWM - Watercool SW-16 or MIPS?
correct me if i am wrong
Factotum is offline   Reply With Quote
Old 02-15-2009, 09:45 AM   #2
faster3200
faster3200's Avatar
I am not sure about those blocks but they seem fine. I know MIPS makes a full mobo set if you want to WC everything. I am not sure on the UT version but I know the DK has the ability to remove the the heatsink on the NB and still keep the stock cooling for everything else. If the UT version can do that on the SB you should be fine.
faster3200 is offline   Reply With Quote
Old 02-15-2009, 10:43 AM   #3
woffen
woffen's Avatar
I have been eyeballing the MIPS blocks for my DFI UT X58 but it will have to wait for now. Whatever you go with, please put in some pics
woffen is offline   Reply With Quote
Old 02-15-2009, 11:03 AM   #4
Grinch
Xtreme Cruncher
Grinch's Avatar
not to sure what blocks actually fit this board
__________________
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
Grinch is offline   Reply With Quote
Old 02-15-2009, 04:35 PM   #5
SoulsCollective
Xtreme Cruncher
SoulsCollective's Avatar
MIPS makes a set for the DFI board? I just had a look on their site, but couldn't find anything for the X58 LP series, only X48 - are the blocks compatible?
__________________
Rig specs
CPU:
i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64
Liquid-cooled
Sub-loop One
: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Peripherals
Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
Foundational Falsehoods of Creationism
SoulsCollective is offline   Reply With Quote
Old 02-15-2009, 09:11 PM   #6
faster3200
faster3200's Avatar
I remember reading that the V.2 DFI set was compatible with the X58 board. The set I see on their website doesn't look like the same design for the mosfet coolers so it might be V.1 which won't work without modding the mounting for the mosfet. Other than the mosfet the other blocks are compatible
Old 02-16-2009, 12:02 AM   #7
Six
You need:
1 x MCH2033 Northbridge Freezer inkl. 2 Distanzringe
1 x MCH2013 Southbridge Freezer inkl. 2 Distanzringe
1 x MCH2149 Mosfet Freezer inkl. 2 Distanzringe (DFI LANPARTY UT X58-T3eH8 >> need REV. 2)
Six is offline   Reply With Quote
Old 02-16-2009, 01:50 AM   #8
SoulsCollective
Xtreme Cruncher
Does anyone have these blocks and can measure hole spacing for me? I'd love to be able to just get the MOSFET block and reuse my current EK NB/SB 5. Southbridge can be air-cooled on its own, as always.
__________________
Rig specs
CPU:
Liquid-cooled
Sub-loop One
Peripherals
Old 02-16-2009, 02:18 AM   #9
zanzabar
I am Xtreme
zanzabar's Avatar
u wouldent want to liquid cool an intel SB u will just make it hotter, the EK SB sink works way better for its thermal load. and i would suggest mcw30 ont eh NB since its the least restrictive and the NB isnt that high wattage on the x58. then the pwm is the same as every other dfi 8 phase
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
zanzabar is online now   Reply With Quote
Old 02-16-2009, 06:30 AM   #10
Factotum
Originally Posted by Six View Post
You need:
thx, where buy this?
__________________
Core i7 920 D0 Batch#3845B260 200x21 1.30V HT, 24/7 full stable
DFI LP UT X58-T3eH8
G.SKILL Trident 6GB F3-16000CL9T-6GBTD 1600MHz 7-7-7-19 1.60V
GTX285@vMOD
2xVelociRaptor WD1500HLFS RAID0 / Hitachi P7K500 500Gb
Audigy 4 (SB0610), LiteOn LH-20A1S, Logitech G15, Razer Copperhead
Cool Master Real Power Pro 850W (RS-850-EMBA)
Watercooling:
[Swiftech MCP355 + XSPC Laing DDC Reservoir] -> [XSPC RX360 + 3 x GentleTyphoon AP-15] -> [Apogee XT] -> [MCW30] -> [EK-UT x48] -> [MCW60rev2 + MC14]
PrimoFlex Pro LRT Black 7/16 x 5/8 + BP Fat Boy 1/2
Old 02-16-2009, 09:01 AM   #11
Six
www.mips-computer.de
Old 02-28-2009, 06:47 PM   #12
msgclb
msgclb's Avatar
You need:
Are these blocks available in the US?
1 x MCH2033 Northbridge Freezer with 2 spacers
1 x MCH2013 Southbridge Freezer with 2 spacers
1 x MCH2149 Mosfet Freezer with 2 spacers (DFI Lanparty UT X58-T3eH8>> need REV. 2)
__________________
| ASUS P6T Deluxe | Intel Core i7 965 3838A610 | Swiftech Apogee GTZ – Swiftech MCP655-B Pump – Thermochill P120.3 Radiator - XSPC Bay Reservoir |
| Corsair Dominator GT 6GB (3 x 2GB) DDR3 2000 | EVGA GTX 260 Core 216 | Corsair 850W PSU |
| Windows 7 64-bit |
msgclb is online now   Reply With Quote
Old 02-28-2009, 06:51 PM   #13
zanzabar
I am Xtreme
zanzabar's Avatar
dont liquid the SB, the only use like 7W and will get hotter when liquid cooled, thats only need on NV chipsest and some amd but not for the intel south bridge
use one of thees
http://www.petrastechshop.com/encnonfocoso.html http://www.petrastechshop.com/enslonfocoso.html
__________________
Old 02-28-2009, 08:08 PM   #14
rioja
why do u suggest to use even active aircooling for sb?
mcw-30 is not too restrictive and might do it job a far more effective than the enzo
especially when you have all other parts watercooled, mcw-30 on sb would be very suitable
__________________
Intel Xeon W3520 4200MHz HT
Foxconn Bloodrage
3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
Foxconn 8800GTX
Samsung F1 1TB
Seasonic M12-700
Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
NEC 2690WUXi
Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
Loop 2: Laing DDC1-T -> EK-FC8800 -> Thermochill PA120.2 -> EK Res 150
rioja is offline   Reply With Quote
Old 02-28-2009, 08:23 PM   #15
zanzabar
I am Xtreme
zanzabar's Avatar
some people like active i would get the passive but if u have xfire or sli and u are covering the sb then the active can be useful. the SB will get heated up by the liquid so its pointless to cool it and its more restriction that u dont need. on the intel platform the SB is a glorified basic raid controller
__________________
Old 02-28-2009, 08:29 PM   #16
Eddie3dfx
Xtreme Mentor
Eddie3dfx's Avatar
I don't know about the new x58, but the old x38 tr2 measures as follows.
58.7mm for sb and 61.49mm for nb.
__________________
Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
Eddie3dfx is offline   Reply With Quote
Old 03-01-2009, 02:28 AM   #17
anubis_is_evil
anubis_is_evil's Avatar
can you post your mobo with that block mate ? do MCW30 also fit in the NB ?
thx..
anubis_is_evil is offline   Reply With Quote
Old 03-01-2009, 04:37 AM   #18
SoulsCollective
Xtreme Cruncher
Doing some more reading, I'm now planning to reuse my EK NB/SB 5 block and just whack it on top of the NB plate, leaving the heatpipe system in place for SB and MOSFETs. According to Eddy it should fit, given that the spacing is the same as the X48 board.
__________________
Rig specs
CPU:
Liquid-cooled
Sub-loop One
Peripherals
Old 03-01-2009, 06:04 AM   #19
Factotum
first post updated
__________________
DFI LP UT X58-T3eH8
GTX285@vMOD
Watercooling:
Old 03-01-2009, 06:09 AM   #20
SoulsCollective
Xtreme Cruncher
Factotum, I should point out that your links in your OP and the picture used both refer to the LP DK X58 T3EH6, not the LP UT X58 T3EH8 - the UT board has the SB heatsink linked to the NB with heatpipery and a much larger PWM heatsink. May want to fix that.
__________________
Rig specs
CPU:
Liquid-cooled
Sub-loop One
Peripherals
Old 03-01-2009, 06:31 AM   #21
Factotum
SoulsCollective
I don't have pictures of UT, but it's correct for LP UT X58 T3EH8, checked
__________________
DFI LP UT X58-T3eH8
GTX285@vMOD
Watercooling:
Old 03-01-2009, 06:42 AM   #22
anubis_is_evil
from the look of PWM heatsink..i guess PWM block(EK/Heatkiller) that you listed will not fit....it will work i presume, but the mounting will be different...
here is picture of the heatsink mounting.....right pic is the heatsink mounting...left is the pic of backside motherboard showing heatsink is mounted(i guess)...EK/Heatkiller mosfet block are created with straight mounting...thats what makes me think they dont fit..
Old 03-01-2009, 07:08 AM   #23
Six
Mips Mosfet fit only for:
- DFI LANPARTY UT P35 T2R
- DFI LANPARTY LT P35 T2R
- DFI LANPARTY LT X38 T2R
- DFI LANPARTY UT X38 T3R
- DFI LANPARTY UT X48 T2R
- DFI LANPARTY LT X48 T2R
- DFI LANPARTY UT X58-T3eH8 >> need REV. 2
Old 03-01-2009, 07:25 AM   #24
rioja
so u wanna say that nb+sb+pwm could be cooled by only one single waterblock? this is very interesting idea, coz one block is better than three not sure about temps though
i'm gonna migrate from x38 to x58 soon and will check it out
__________________
Foxconn Bloodrage
Foxconn 8800GTX
Samsung F1 1TB
Seasonic M12-700
NEC 2690WUXi
Old 03-01-2009, 07:38 AM   #25
Praz
Temps with MCW30 on the Northbridge.
__________________
#1 Rule Of The Internet - The majority of writing stated as or giving the impression of fact is little more than the author's opinion. And more times than not that opinion is based on little or no knowledge of the topic.
Praz is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
