XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.4ghz @1.32v under load, corsair ddr2 1066 8gigs, evga gtx260 core 216, pc p&c 750W, EK Supreme HF Nickel, iandh 175 res, Swiftech MCP355, Black Ice GTX G2 240, Lian Li v1200b
silverstone tj07 build log
It´s sunday and i´ve said on sunday pictures will come
fhantastic, beautiful photos!
SORRY FOR MY BAD ENGLISH!
another option, depending on what kind of sleeving/and heatshrink you're using is...its perfectly possible to just wiggle it right over top without removing *might have to shave the edges a bit, but*
Current System:
eVGA 680i SLi "A2" P30 BIOS
intel Core 2 Quad Q6600 (currently at stock)
OCZ ReaperX 4GB DDR2 1000 (running at DDR2 800 Speeds with cas4)
320GB Seagate 7200.10
XFX 8800GT XXX 512MB (stock clocks)
auzentech X-Fi Prelude
PC Power and Cooling Silencer 750 Quad Copper
Win XP Pro
I'm about to sleeve my video card power cables, and I wanted to glance at a few examples to see how others did it. In the process, I thought I'd take a look at MDPC to see some really clean ones. What I saw upset me:
How the heck did Charles do that? What kind of shrink can you get to make a seamless transition from the cable to OVER the connector like that? And where do I get some? Now I'll never be satisfied with anything I do, because I'll never be as good as Charles, lol.
Seriously though, where can I find some shrink like that? I LOVE the way that turned out. I also noticed that in the past he used to sleeve each of the video card wires individually, but for this build he bundled them into one. I think it came out much cleaner and since I'm not on water yet, I need as little air restriction as possible.
So really I'm asking Charles but if anyone else has some insight they can offer I'd really appreciate it. What size sleeving & shrink should I be buying (from MDPC-X, of course) in order to pull this look off? I'm initially thinking I need the "SATA" sets, but I'm not sure.
I have a different idea with the connectors themselves (I'm trying to come up with a way to make it look like one big connector and one medium-sized wire), but I want to make sure I don't shoot myself in the foot at any step along the way.
Thanks!
Inside my murderMod TJ07:
XFX 780i - Q6600 @ 3.2GHz - TRUE Black - 4x2GB Mushkin Athlon XP 1066MHz DDR2
MSI GTX 260 Core 216 OCv3 896MB - Silverstone Decathlon DA800
Seagate 7200.11 500GB in RAID 0 (OS) - Seagate 7200.11 1TB (Storage/Backup) - Stealthed Pioneer DVD-RW
I asked Nils the same question lol.
It's SATA sleeve, Nils isn't sure if he stretched the sata shrink or used the jumbo shrink, either would work though
Hey Jason,
It's the Large shrink on SATA sleeve... just a bit of trial and error Mate.
I wanted to be sure the wires in Daniel's machine didn't move or flop around - even after being transported half way around the planet!
I found that you could put the shrink in place, heat it and then bend it to the shape you wanted before it cooled and hardened. Obviously it took a bit of messing with to get it looking right... as I recall, it's actually two layers of shrink - one to grip the sleeve to the cable and the other to mold the outer shape.
With this method, the wires are held firmly in place...
Hope that helps.
Thanks for the rapid help Charles! I was actually looking at it before and suspecting two layers of shrink.
Back to work!
Any chance I could make the same thing work with the 8-pin cables?
Having stripped my HAF down today, to make way for my new build http://www.xtremesystems.org/forums/...d.php?t=232515
I have the Enermax Rev 1050w psu, and am planning on individually sleeving all the cables. The PCI-e cables that come directly out are 6 + 2, what is the best way to hide the 2 unwanted cables? I can see removing the connectors, but one is still going to have too much cable.
With the modular 6+2, is it OK to just remove the 2 extra wires?
Next up is the front audio connector, only need the HD part, so once again is it OK to remove the non HD connector?
i7 975 EVGA X58 Classified 6Gb Corsair Dominator GT 2 x EVGA 285 FTW 2x 300Gb Velociraptor in RAID 0 WD Black 500Gb
WC loop 1: HK 3.0 Fesser 360 BP VREG BP NB D5 pump
loop 2: 2 x EVGA HC's Fesser 240 D5 pump
Worklog: Project Black Copper
Lian Li PC-P80 | Thermochill PA140.3 | Noiseblocker fans | mdpc-x stuff
Perfect sleeve mate. Top job.
Hi guys
@ aka_GK
wonderful job!
Hardwareluxx.de
Silenthardware.de
thanks guys
What kind of symptoms would I experience if I would have plugged the wrong pins on my 24pin atx cable. Im experiencing random crashes and my Maximus formula flashes it's diagnostics leds...or rather leaves the dram led glowing red etc. I't all started when my Corsair HX1000 had 2 wires coming off from the pins on the 24pin line on their own Not what you'd expect to see from 200€ powersupply.
2600k, Asrock Z77E-itx, 8gig, 256g mSata, 670GTX, 450W SFX = powering a 27" ACD.
did an order today
payment wil be tomorow
Hope it wil be here fast ^^ from Germany to Belguim
proud to be from Belguim ^^
Lightpainting and hardware are my life!
It only took 3 days for my order to get from germany to canada, so im sure you wont be waiting long
AMD PII 1090t
Patriot 1600mhz 2x2gb
Asus Crosshair IV
Corsair HX1000
PC 5870 1gb
2x HAF932 Welded together
Cooling: Cpu Loop
Pa120.3 w\ 3x Scythe GT
Dtek Fusion V2
Mcp 655
Ek 150 w\ 2 bottoms w\1 troy oz silver
DD brass fillport
Primochill Pro Lrt Black/Red tubing
Cooling: Gpu Loop
Mcr 320 w\ 3x Scythe GT
Swiftech mcw80 w/switech fc heatsink
Mcp655
DD fillport
PC: Case: Zalman Z-Machine GT-1000 Black Brushed Alu - Screen: HP W2408H - Mobo: DFI Lanparty DK P45-T2RS PLUS - CPU: Intel C2Q Q9550 - Ram: Corsair Dominator 8GB PC2-8500 - GPU: MSI 460GTX OC 'Cyclone' - Sound: Asus Xonar D2X + Onkyo HT-S5105 5.1 set
Cooling Thermolab Baram + 2x tacens Ventus ice - Storage: OCZ Vertex 60GB, WD Caviar Black 1TB, WD Green 3TB - PSU: Corsair HX520 - Peripherals: Duck Orion TKL (MX Clears) + Roccat Kova mouse
hmm, this sleeving looks alot like Bentley Harris Expando PT Plus which is really good non-fray sleeving. Am i wrong or who makes this murdermod sleeving.
