amazing cpu you have there.
no coldbug at 391 for -18°C is truely amazing
have you tested what it does under normal air/water?
SO CLOSE 33MHz from the WR !!!
http://valid.x86-secret.com/show_oc?id=96038
Regardrs from Switzerland
Roger
Nice result... Do you have temp of evap on full load, or nay picture of system?
tnx
My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LN² Pots, LD GFX-R1 Dice/LN² Pots,
LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
LD PC-V8 Watercooling Cases: LINK
LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
www.ldcooling.com
Find US on Facebook
Nice SS
Gaming/benchmarking rig - Intel Core 2 Duo E6600 ES || Asus p5b deluxe vcore, vdroop, vmch and vdimm mods || ATi x1900xtx + ATi x1900 CF edition || 2x1024 Team Xtreem 667 3-3-3-8 || SilverStone 650w || 2x EK blocks for VGA's + D5 + BIX2 || LittleDevil Single Stage
PIC 1 - PIC 2 - PIC 3
Nice work! That SS looks very clean.
Small Update !!!
http://valid.x86-secret.com/show_oc?id=96365
Regards
Roger
nice dude!
Cmon roger, pull out those last mhz's
- Schmetterling
put it on DIce man...
LN² will cold bug a lot, but cascade, or just few better single stage i think you can up more...around 3.8-3.83GhzOriginally Posted by splmann
French Overclockers roxxxxxx
OCM Team addict
Overcrash is right; LN2 isn't the solution here (and cascade will be too cold as well and very boring to use with your chip). Go for a powerful single stager unit; something like Piotres' -88°C unloaded rotary direct die.
May be, you could consider using Dry Ice, as far as I know, DI is a good choice in order to get a real time control on temp...
Best Regards,
Xavier
"I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
push the cpu just a bit more
Where courage, motivation and ignorance meet, a persistent idiot awakens.
@massman
you told me push the CPU looking here !!!!!!
WR Opteron 148 goes to Switzerland !!!!
http://valid.x86-secret.com/show_oc?id=97911
Gruss
Roger
Well done man!!
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
Man, You have legendary 0530APMW ...so let's cool it really good ...dry-ice/ R1150 cascade and You can be fighting for 4 Ghz ...
Awesome CPU
Regards
Peter
http://WWW.PIOTRES.COM
My productions (phase-change and containers) : Click here to see links...
Phase-change units, cascades, chillers and Ln2/DI containers builder - contact : piotres@piotres.com
yay ..!!!! well done....
Nicely done dude... keep it up! 3.8GHz is on the way
Best Regards,
Xavier
