BIOSTAR, a top provider of mining motherboards and graphics cards, introduces a turnkey solution for mining at home with iMiner A578X8D/iMiner A564X12P/iMiner A578X6. The iMiner series comes as a single unit black box machine that supports ethOS and is fully equipped with BIOSTAR TB250-BTC series motherboard, CPU, GPU, memory, and power supply. It allows ultra-mining flexibility as it supports GPU mineable crypto currencies such as Ethereum, Monero, Bitcoin Gold and Zcash.
All iMiner systems are based on the Intel 3930 CPU and Intel B250 chipset for maximum mining power. BIOSTAR iMiner A578X8D with ETH hashrate of 220 MH/s (?5%) uses the popular BIOSTAR TB250-BTC D+ with 8 x AMD RX570 8G graphics card and a high performance 1600W single rail 12v power supply (optional) with dual-ball bearing fans to offer ultra durable operation 24/7. BIOSTAR iMiner A564X12P with ETH hashrate of 148 MH/s (?5%) uses the BIOSTAR TB250-BTC PRO with 12 x AMD RX560 4G graphics cards on a 1300W power supply. BIOSTAR iMiner A578X6 with ETH hashrate of 165 MH/s (?5%) also uses the BIOSTAR TB250-BTC PRO with a modest 6 x AMD RX570 8G (which can be expanded for up to 12 GPUs) with a 1300W power supply.
