X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 4 of 4
Thread: How do I make my storage solution work properly?
    Mar 2007
    Okay, don't get me wrong, I really do like Windows 10. My computer runs better than it did before and some of the little glitches I had with W7 are now gone. The problem I have is that I had certain hard drives set for certain things. I had my capture video on D, my rendered video on E, my pictures, music, and docs on F. If I use the default storage folders in the settings along with that new folders are created and I can't place things exactly where I want them. What can I do? Anyone else in this dilemma?
    2-ASUS VS248H-P Black 24" Monitor, ASRock Z77 Extreme4 LGA 1155 Intel Z77, Kingston Hyper X Blu 16GB, EVGA GeForce GTX 570 HD
    Intel Core Xeon E3-1245 V2, NZXT Sentry Mesh Fan Controller, Koutech IO-RCM621 Front Panel Multi-format Card Reader, Asus BW-12B1ST Internal Blu-ray Writer
    SAMSUNG 830 Series 2.5" 256GB SATA III , HITACHI Deskstar 7K3000 HDS723020BLA642 2TB, HITACHI Deskstar 7K3000 HDS723020BLA642, Western Digital 2 TB HDD
    Antec High Current Pro HCP-750 750W TX, CORSAIR Hydro Series H60 High Performance Liquid CPU Cooler, Windows 10 Professional Retail, Antec P183 V3
    Join XS BOINC Team StyM's Avatar
    Mar 2006
    Tropics
    i'm confused on what you want... sorry ...
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    "quick access"
    Right click, try using "quick access" on folders and drive.
    It will put icon in the file explorer near the top.
    Remove the other quick access selections if needed.
    As far as setting up applications where to access from and save to is usually in that apps preferences.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    you can also right click on the folders in quick access and go to properties. then you can go to the location tab and select move. that will let you move the symbolic link for documents, movies, ect to whatever folder you intended.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
