Details
Summary:
Electrical conductivity or EC is a commonly used indicator to measure water purity. While conductivity itself isn't the only measurement goal, total dissolved solids (TDS) in ppm (Parts per million) are also routinely converted from this number. To keep it simple, I'm just measuring the conductivity in this test and including a conversion table that was included with the meter to TDS if you are so inclined. Distilled waters typically should be better than 10uS where municipal water systems could be as high as 500-800uS. In water cooling we have had all sorts of numbers thrown out there with suggestions that grocery store distilled wasn't good enough. In addition there was not any data in regards to how quickly this water becomes ionized in the loop which is important when considering the relevance of purity.
Wal-mart brand amongst others tested extremely pure at under 1uS
All of the distilled waters tested well under the 10uS suggestion by wiki's definition.
Bottled spring waters and others not purified with distillation however tested at a variety of levels, some not much better than tap:
So "Distilled Types" all tested out ok, but what happens when put in contact with metals?
Ionization tests
Just a few minutes of metal contact agitation:
Few weeks not quite a month in the loop:
Charted Results:
While there are some EC meter measurable differences, the 1-5uS amounts are insignificant relative to the ionization that occurs later when added to the loop. The very pure distilled water (regardless of brand) is almost instantly ionized at very high levels. 0.7uS Wal-mart distilled converts to roughly .35ppm TDS or 0.35 parts per million or 0.00000035%, tiny and insignificant to say the least.
Conclusion as of 3-24-12
1) There is no such thing as Nonconductive fluid, all no matter how pure instanly become conductive. You spill it you have problems.
2) Tap, Spring bottled, and spring drinking waters are not recommended due to higher ionic concentrations of unknown contents. At least with distilled the ions are metals that match what the loop is made of.
3) Any distilled water or ultra pure water is ok, there is a measurable difference in the bottle by a few uS, but there is no practical difference once added to the loop. 1uS or even 5uS doesn't matter when the ionization jumps to 20 instantly and 80 in just a few weeks.
Distilled is distilled.
Cheers!
Martin
