Like the title says, either full coverage or just the VRMs like EK did with the Asus CH5.
Tiborrr? Tim? *nudge*
Ω Raven Build Blog
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
" Inter Arma Enim Silent Leges" - In times of war, the law falls silent.
I have already validated the test sample today. The waterblock should be available in 2-3 weeks:
http://www.ekwaterblocks.com/index.p...t01returnid=17
Like EK-FB ASUS Crosshair V it will be cheap and will not cover southbridge. We will bundle a rather chunky looking aluminum heatsink to cool the southbridge since no-one wants to cut the original heatpipe cooler!
Disclaimer: I've put an EKWB sticker over the acetal top which I managed to scratch badly
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
tiborr: Why not paint that alu heatsink black (at least for acetal blocks), and maybe put EK logo on it to mach looks?
Holy moly that is a fantastic looking board. Especially without the stock heatsink.
Ω Raven Build Blog
I vote for black as well, for both the Giga and Asus 990fx boards.
Shame the Gigabyte UD5/UD3 dont have the same layout.
The aluminum heatsink will be black anodized, guys, this is a sample directly from the machine :P
We have compatible SB waterblocks in our arsenal if anyone wishes to cool the SB950 with water.
About Giga 990/970 UD3/UD5. We believe we have some older compatible FB kits compatible with these boards. Please consult www.coolingconfigurator.com
Best Regards,
Niko
EK Water Blocks R&D
ekwb.com
Ω Raven Build Blog
Here's the hydraulic curve for this waterblock. Very decent, compares to Supreme HF!
EK Water Blocks R&D
ekwb.com
EK-FB GA-990FXA-UD7 mounted on the motherboard:
EK Water Blocks R&D
ekwb.com
Seems that there are no "full cover" blocks for the UD5 then??
X299X Aorus Master
I9 10920x
32gb Crucial Ballistix DDR4-4000
EVGA 2070 Super x2
Samsung 960 EVO 500GB
4 512gb Silicon Power NVME
4 480 Adata SSD
2 1tb HGST 7200rpm 2.5 drives
X-Fi Titanium
1200 watt Lepa
Custom water-cooled View 51TG
http://www.coolingconfigurator.com/s...ist?mb_mbs=454
No, not at the moment, but it seems like the EK-FB KIT GA AMD might fit. I cannot visually confirm that since the southbridge cooler's mounting holes are not visible.
EK Water Blocks R&D
ekwb.com
Attachment 120088Hey Tiborrr you actually don't need to cut the heatpipe if you want to use the stock Gigabyte SB heatsink.
After an hour using a small chisel tool, mini torch and an exacto-blade I got the heatpipe off from the SB heatsink without causing damage or irreversible damage.
Ω Raven Build Blog
Hah, looks epic. Great work, Ω!
EK Water Blocks R&D
ekwb.com
I ordered this one http://indomo.se/14763-EK-FB-GA-990FXA-UD7-EN-Nickel yesterday
something
