Results 1 to 9 of 9
Thread: Bitspower Angle Fitting, BP-WTP-C26
    Nov 2010
    Hey guys, quick question:
    How do I get this barb (BP-WTP-C26) to face in the desired direction when it is screwed into a water block?
    No matter what angle I start screwing in the threads, it will end in the same undesired direction.
    Does there exist some sort of swivel adapter?
    http://www.sidewindercomputers.com/big14shsianf1.html
    Thanks for any ideas and input.
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Apr 2006
    Hong Kong
    I've just re-done my loop and got a bunch of rotary fittings in there, many angled at 45 degrees or 90 degrees etc.
    I'm really, really terrified that the seals between each segment that allows for rotation is going to be pulled apart by torque from the tubing.
    :S
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Feb 2010
    Northern California
    make your tubing more correct length.
    you know you're addicted to watercooling when:
    Quote Originally Posted by Onoff312 View Post
    You started with a $200-400 budget and have ended up spending over $1000-2000
    Nov 2010
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    The top one allows u to put any barb or attachment u choose.
    But if u total the cost with barb its more expensive then the bottom one which is set with a barb.
    If you want to splurg get the top one, and add a barb too it.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Feb 2010
    Northern California
    especially if you're not set on tubing size, or barb / compression.
    Jul 2006
    norway
    rotary for those pesky/impossible streches
    Asus Rampage II Extreme
    intel i7 930 @4.3 ghz
    12 GB patrot pdp 2000 EL 3x4 bg @ 821mhz, 8-9-8-24 1T
    XFX 5970 black edition @ 950 | 1200 (shappire bios)
    240 GB Vertex 3 MAX iops OS disk | 2x ocz agility 60gb in raid0 128k stripe size | 2x wd black 1 TB in raid 0
    win 7 Home Premium 64 bit
    coolermaster haf 932
    Corsair HX 1000 psu
    ASUS VG236H 23-inch 3D Display 120 hz
    cooling:
    ek full cover WB for 5970 with nickel backpate
    -ek mosfet WB
    -ek full cover x58 motherboard WB
    (all above in copper acryl)
    -swiftect micro res
    -swiftech xt cu block
    -mist 120.2 radiator
    -mist 120.3 radiator
    -swiftech mcp 655 pump
    Mar 2009
    Toronto ON
    I found you don't ned as many rotary as you have fittings, just where you need exact bends or lines. I used 6 rotary on 16 fittings in a good build I did, you should be safe with half.
    Sent from my X10a using Tapatalk
    MagisD
    ____________________________
    Lurker, Dreamer, Planner, Noob
    6 Quad rads 1 case Maybe I went a little overboard....Overkill Cube
