looking on performance-pcs website site, what water additive is the recommended 1 now a days? nothing expensive please...... TY
Nothing anymore
wow!! cool, my S/N says movieman..... SWEET
Nothing anymore
http://www.performance-pcs.com/catal...ducts_id=28871
Ultra low maintenance, drop it in and forget about it.
Circles SucQ!
A drop of PTnuke works for me, one little bottle is probably a lifetime supply.
I have a similar question, I've been using Feser One (Colourless one that is UV reactive) - Is this a good coolant to use in my loop? - I've been using it for 6 months now with no noticeable problems. I have a clear reservoir and GPU blocks and they all look clean and clear so I guess it's fine but I have had people tell me Feser One is a bad coolant but I don't really know if that's true or not.
Thoughts?
news remember the battle i had with the forum on coolant?
Well make things short, i won.
Distilled + Silver + (PT Nuke if ur using CCFL's inside your pc 24/7)
Otherwise just distilled + silver.
no doubt... and c2SO4 has a pretty long shelf life on top.
However u dont really need it, unless ur starting your system off in a high light enviorment.
Most of the time the copper in the blocks should keep it in check at the start, then by the time the microbe is strong enough to resist copper, the silver comes in and nukes it.
So most of the time ur usually ahead of the microbe race with just silver at start.
As i said, unless u run lights inside your pc all the time.
Then your growth will outpace the silver, and u'll grow something and then have it die when the silver catches up and that will stink up (foul smelling coolant) your loop.
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Best choice.
Victory May Be Fleeting, But Obscurity Lasts Forever!
Last Project http://www.xtremesystems.org/forums/...d.php?t=213829
Canceled Project http://www.xtremesystems.org/forums/...d.php?t=265292
New Project http://www.xtremesystems.org/forums/...d.php?t=269440
I've never run silver myself, just one wee tiny drop of PTnuke takes care of business for me. I've run many T-lines without any reservoir so there isn't a very good place for a chunk of silver on those setup.
PTnuke works good though. I have litterally let two loops go without a flush for 2 years with that stuff and I only had very minor bits caught in the block which likely came from the rads over time.
I considered silver on my latest build, but went along with Ferser corrosion blocker. It has served me well over the years.
Dutch techies visit www.geekswarm.nl
Hardware: Antec P180b | Corsair HX850W | MSI P55-GD65 | Core i7 860 | 2*2GB Corsair Dominator PC12800 CL7 | Sapphire HD5870 + XFX HD5870 | OCZ Vertex 2 120GB|WD Caviar Black 1TB
Cooling: Swiftech MCP355 + XSPC ResTop | ThermoChill Pa120.2 & TFC X-changer 120 | Swiftech Apogee XT | EK-FC5870 Acetal+Nickel | Tygon 3603 |Feser Ultra Pure + Corrosion blocker | 6*Scythe S-Flex F @ Scythe Kaze Master Ace
Bench: DimasTech Easy 2.5 | MSI-P67A-GD65 | Intel Core i7 2600K | 2*4GB Corsair Vengeance PC12800 CL8 | 2* MSI R6950 CFX
this is very LOL
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
I think he means the April fools joke that got a bit out of hand. This is rather epic, lol. ^_^
At Xtremesystems.org we don't help you save money on your cooling gear, instead we try to make you feel better about the insane ammount you've spent.
Circles SucQ!
