I dont have good experiences with colored liquid, gives a lot of colored trash on the blocks
dont know ive mayhem is giving the same?
Brilliant build so far didnt expect is to be this good.
Update:
The LiLi Tower is of course not on hold. Was only in doubt whether I would let the custom side panels to be laser cutted
or do it myself. Hmm, gonna do it myself.
Measured it 3 times before cutting
Holes for the jigsaw
And after a lot of cutting and filing, 1 x side panel. Others also made but of course in reverse
For the front panel also drawn two pieces
Panel 1
Panel 2
Side has been made and fit. It has the same angle as the reservoir
The part below, only needs to eliminate some cables behind
The right part
And the front panel placed
The display of the aquaero is blue now, I have been using dark blue filter
Other one is still off, still needs to make the cable
And some pictures when it was dark
The front with ........ a blue cross
Line passes through nicely
Total shot
He already runs now for two weeks very smoothly. Needs to do some small things before the final pictures
But these will certainly come.
Grtzzz.
Hi Y'all on this very sunny day (in the netherlands)
Just one small addition to the previous update.
I was hoping my sleeve for the McMod was coming in this weekend, but no.
So cleaned the BBQ after one year of standing still.
In about an hour I'm gonna put half a cow on it, and the feast can begin. In the meantime,
I was still brainstorming about the LiLi tower. I just miss something ........
I know...........the top.
With the last aluminum i have, made some nice pieces.
Can can afford to mess it up because the plates are EOL over here
The two plates measured and marked, holes made for the jigsaw
After some cutting and filing work got everything nice and straight.
And the other panel, slightly different. This for the line around to continue
Still need to drill the holes and the countersunk the bolts.
Now, there's nothing more to do with the outside appearance of the tower (I think)
The inside can still use some light, so tonight's gonna play with loose LEDs and LED strips
And I'm thinking hard to put a blue color in the water.
Think it is very nice effect. I've Looked for Dye Mayhem Deep Blue,
I think one of the better color additives. But nowhere in the Netherlands to obtain.
Belgium either, and I am just told that the dye is EOL.
Now I have no experience with Feser Feser Active UV dye or blue dye active clear / blue entries,
so if anyone has used it already once, please let me know!
Grtzzz.
Update!!!
Today I've got my blue dye so I can finally show you some pictures of the case closed, and especially for the Motm nomination this update
Feser View UV Dye
It was transparant
Add a little bit of dye
Some more
Add about 3 ml
Power up the pump
And everything turned blue
One more to go
Some more
It's now the some blue color as the illuminated glo string in the middle
Other side
So I can finally close the LiLi
The upper right part
The lower right part
And the whole right side
The back with the Coolermaster turbine
Closed the left side
And from above
It's a lot of blue, but I hope you like it
Just need to do some more cable manegement and put some nice lights in it
So to be continued
Grtzzz.
nicwe job kier! Always love your builds
Amazing, is all I can say... I love the Lian Li V35X Series (got one for myself at home) but you`ve done with the 2 is stunning!! There`s not too much blue, it just fits together very well, for me a very complete mod!! I really like it!!
Almost done with the lightning, here some preview pictures, but...............more to come
I used white SMD led strips
Need to make one flatcable for the aquaero, then LiLi Tower is finished
It's like any mess you have up top is made up by the epic-looking bottom half.
Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
Seriously dude, 1 of the nicest, sexiest builds I've seen. Loved your last work. Love the latest.
*bows before you*
PROJECT :: The Xtreme (WET) Dream!!!
PERSONAL H2O BESTS :
E8600 @ 4.8GHz E6750 @ 4GHz QX9650 @ 4.6GHz i7 920 @ 4.6GHz
PERSONAL AIR BESTS :
Sempron140 @ 4Ghz (Stock Cooler) i7 3960x @ 5.4ghz (Air Cooler)
Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
Swift_Wraith : "could someone please check bex for a penis?"
Messy and clean at the same time, didn't hear that one before
Messy, clean and sexy, keep them coming I like it
Also have good news and bad news. The good news is she's finished............the bad news is, done with this build
Have made the flatcable for the aquaero and the Lamptron dots connected
Gonna make some nice last pictures, so one more update to go
very nice work man.
~ Little Slice of Heaven ~
Lian Li PC-A05NB w/ Gentle Typhoons
Core i7 860 @ 3gHz w/ Thor's Hammer
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
OZC Vertex3 SSD 240GB
Last Update: Pictures by night
I know, there's a lot of pics...........better than a large piece of text I think
That's it folks, Hope you like it
Keep on modding
amazing! great work
Corsair Obsidian 650D
Intel i5 2500K - 4.5 GHz
Asus P8P67 Pro B3
G.Skill Ripjaws 2x4GB 1600Mhz 9-9-9-24
Asus GTX460 768mb
Prolimatech Megahalems Rev.B
Samsung 840 Pro 256GB SATAIII
Western Digital Green 3TB x2 in RAID-1
Seagate Barracude 2TB x2 in RAID-1
Cooler Master Silent Pro Gold 800W
Samsung SyncMaster 24'' LCD 2494LW x2
thnx you guys
Just one small addition due to questions about aquaero
The flat cable for the display and aquaero
The Aquaero (old one that I had lying around)
This old versions can not be separated I think, and do not want it demolished. But those who are in the LiLi I could easily be separated
For the cable I ordered 16 wire ribbon cable
female connectors
And headers
One side connected straight
Other side, crossed the wires. Careful split the wires with a knife
And cross it. wire 1 on pin 2, 2 on 1, 3 on 4 and 4 on 3 etc.
Almost finished
Header pushed in
And the cable is finished
Still needed to make one so a good reason for this mini tutorial
Grtzzz.
Beautiful work and the internal pics are gorgeous!
Victory May Be Fleeting, But Obscurity Lasts Forever!
Last Project http://www.xtremesystems.org/forums/...d.php?t=213829
Canceled Project http://www.xtremesystems.org/forums/...d.php?t=265292
New Project http://www.xtremesystems.org/forums/...d.php?t=269440
