Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: Intel, AMD to phase out VGA by 2015
    I am Xtreme
    Oct 2004
    U.S.A.
    VGA should be dead already.... this is worst than wack-a-mole.
    read the whole thing here.
    Death to VGA! No, not Spike's painfully lame Video Game Awards (although those could also use the axe) but the analog video connector that's been a staple of PCs for decades. Intel aims to accelerate the adoption of DisplayPort and HDMI video interfaces, and in the process, it's looking to cut the cord not only on VGA ports, but also the digital LVDS interface that connects most laptops to their displays. The chip giant's products will cease supporting LVDS in 2013, and VGA support will be phased out two years after that.
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Can't say I'd miss DVI or VGA at all.
    Apr 2007
    About 10 years too late if you ask me.
    Nov 2010
    Finally! DVI was standardized years ago. Shouldve killed VGA at the same time
    Xtreme Monster
    May 2006
    United Kingdom
    Should have done long time ago.
    I am Xtreme
    Oct 2005
    Quote Originally Posted by Metroid View Post
    Right and SLI will be ala EVGA Classified SR-2
    what?
    Xtreme Monster
    May 2006
    United Kingdom
    Quote Originally Posted by lowfat View Post
    what?
    EVGA
    It was a joke, edited it before it got somewhere unknown
    Nov 2010
    EVGA
    Lol evgas dual CPU motherboard? The new SLI, now you can sli your CPUs too! (lol jk server mobos and clusters beat them to the punch).
    Uhh what section do new members post in?
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    VGA, no... but what's wrong with DVI? c'mon, my monitor uses DVI, and I'm not getting rid of it any time soon. Good non-TN panel monitors aren't cheap, and I hate 16:9 as well...
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Xtreme Cruncher
    Nov 2005
    Rhode Island
    Guess when 2015 rolls around I'll finally have to give up my Trinitrons...
    Fold for XS!
    You know you want to
    Mar 2005
    Quote Originally Posted by Sparky View Post
    dvi is a very large plug taking up space on the gpu slot that could be better used for airflow or extra plugs for multi monitor\digital sound outputs
    if they have much smaller alternatives then why not?
    Mar 2006
    Ohio, USA
    Quote Originally Posted by dasa View Post
    Most high power cards are dual slot, plugs on one and vent on the other seems to work pretty well. Last I checked, there was some stink raised about display port introducing lag or something - I haven't kept up with it to know if that's true anymore or not.
    Still, I'd be really frustrated if they cut out DVI and basically make it impossible for me to upgrade my graphics card without spending a few hundred more on a new monitor, which probably could only be 16:9 at that point Of course, my monitor is already 4.5 years old, I'm not sure of the lifespan of the backlights.
    I am Xtreme
    Oct 2005
    DisplayPort is just all around better and significantly smaller (Mini DisplayPort). I am sure Manufacturers will include HDMI to DVI adapters for a long time after the port is removed from the videocard anyways, so you shouldn't have to worry there.
    Sep 2004
    still in doubt about something.. which one should I use, dvi or displayport ?
    any advantage over the other on a u2711 ?
    [SIGPIC][/SIGPIC]
    TJ07BW | i7 980x | Asus RIII | 12Gb Corsair Dominator | 2xSapphire 7950 vapor-x | WD640Gb / SG1.5TB | Corsair HX1000W | 360mm TFC Rad + Swiftech GTZ + MCP655 | Dell U2711
    Jan 2005
    He was concerned about HDMI/DVI being phased out, they are the same signal just a different plug ... displayport is a different tech, so not sure why you refer to it?
    Quote Originally Posted by Loque View Post
    Displayport has slightly more latency I believe.
    Personally I'd be royally peeved if they canned DVI/HDMI quickly after this... VGA can go, good riddance, but HDMI/DVI would be ridiculous. I love my Dell 3007wfp-hc .
    I am Xtreme
    Oct 2005
    Quote Originally Posted by GoldenTiger View Post
    I mentioned DisplayPort because the article is about the faster adoption of DisplayPort and HDMI by forcing the removal of VGA and DVI. And since HDMI is already common on all videocards.
    Jun 2005
    Nothing of mine uses VGA anymore. In fact, none of my video cards even have VGA ports on them. They've all got at least 2 DVI and an HDMI port.
    Seriously, I'm glad we're finally moving away from these gawd awful large data cords on our computers. They phased out serial and parallel ports years ago, so the only large plug we now have is DVI and VGA. Hell, even ribbon cables for IDE drives have been replaced by tiny SATA cables on the inside of our computer. Small serial ports are the norm at the moment.
    In my book, DVI is fine because it's fully digital. However, Since HDMI is virtually the same thing as DVI, but smaller (and able to carry audio) I don't see DVI being around too much longer... And for those of you that want your IPS panels to last another 10 years, it'll be ok. DVI -> HDMI cables are pretty cheap, so as long as HDMI stays, your massive monitors with dual-link DVI connections will be just fine. DVI/HDMI isn't going anywhere any time soon.
    Now that I don't have a CRT anymore, good riddance VGA. You won't be missed.
    PII 965BE @ 3.8Ghz /|\ TRUE 120 w/ Scythe Gentle Typhoon 120mm fan /|\ XFX HD 5870 /|\ 4GB G.Skill 1600mhz DDR3 /|\ Gigabyte 790GPT-UD3H /|\ Two lovely 24" monitors (1920x1200) /|\ and a nice leather chair.
  18. #18
    Mar 2009
    In a van down by the river
    Nice having half dozen mini-Dp and still have full slot exhaust.
  19. #19
    Xtreme Addict Chrono Detector's Avatar
    May 2009
    Good riddance to VGA. DVI will stay for a while, and I'm not too fond of HDMI with all their scaling issues, argh. I wish HDTV's would have a DVI port as well so I don't have to deal with HDMI.
    AMD Threadripper 12 core 1920x CPU OC at 4Ghz | ASUS ROG Zenith Extreme X399 motherboard | 32GB G.Skill Trident RGB 3200Mhz DDR4 RAM | Gigabyte 11GB GTX 1080 Ti Aorus Xtreme GPU | SilverStone Strider Platinum 1000W Power Supply | Crucial 1050GB MX300 SSD | 4TB Western Digital HDD | 60" Samsung JU7000 4K UHD TV at 3840x2160
  20. #20
    Oct 2007
    Singapore
    DisplayPort is designed to replace digital (DVI) and analog component video (VGA) connectors in computer monitors and video cards, as well as replace internal digital LVDS links in computer monitor panels and TV panels.[1]
    maybe let display port to take over all other connectors would be better.
  21. #21
    Jan 2009
    am i the only one who have better picture with dvi versus hdmi? idk, every time i connect the monitor with hdmi, the screen gets blurry and the resolutions are messed up?
    [MOBO] Asus CrossHair Formula 5 AM3+
    [GPU] ATI 6970 x2 Crossfire 2Gb
    [RAM] G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 1600
    [CPU] AMD FX-8120 @ 4.8 ghz
    [COOLER] XSPC Rasa 750 RS360 WaterCooling
    [OS] Windows 8 x64 Enterprise
    [HDD] OCZ Vertex 3 120GB SSD
    [AUDIO] Logitech S-220 17 Watts 2.1
  22. #22
    NooB MOD
    Jan 2006
    South Africa
    Quote Originally Posted by [XC] Lead Head View Post
    I'll get an adapter for my P1110
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
  23. #23
    I am Xtreme
    Oct 2005
    Quote Originally Posted by god_43 View Post
    Then your monitor either has something wrong w/ it or it isn't setup right. ∂
  24. #24
    Sep 2006
    Stamford, UK
    The responses to this article highlight the problem with the display port industry, there is just too much choice. Especially considering they all do pretty much the same thing, time to standardize methinks...
    FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
    eXceed TJ07 worklog/build
  25. #25
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    hmmmmmmmm i dont think so
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
