hi all.
this is my first time posting here i think , so here we go.
im planning to wc my gaming rig, but now think how many radiators will i need to keep every-thing in check?
the setup:
I7 920 D0 (running air at 3.6ghz 1.15vcore around 76°C load on highest core, crap cooler and mounting i think)
rampage 2 extreme
getting 5870 3 time's but lets say 3x 4890 for heatload would be the same.
i allready got a D5, planning to use it with the primochill T3.
a swiftech 240mm rad in front off the case, should get a other 360mm for in the top off the case.
blocks if got, swiftech GTZ, swiftech NB-MAX for the chipset.
GPU will see what come's out i think.
also im using zalman ZM-F3 led fans @ 800~1200rpm going for how mutch nois i get from them.
now i need to know will the 240mm from swiftech and a other 360mm hold that load nice or should i get a other rad?
and what brand?
what about the flow, thinking a loop for GPU's only and one for the chipset and CPU only(both on the same primochill T3)
thanks in advance blind
