+ Reply to Thread
Page 1 of 226 1 2 3 4 11 51 101 ... LastLast
Results 1 to 25 of 5644
Thread: Liquid Cooling Case Gallery
    Royal Administrator
    Jul 2005
    New York City
    2
    Thumbs up Liquid Cooling Case Gallery
    Four Simple Rules:
    1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
    2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
    3) Do not quote images,
    4) Finished cases only, no worklogs.
    Optionally, it would be nice if you could list your water cooling components.
    You can find the original thread here: http://www.xtremesystems.org/forums/...ad.php?t=34877 You can re-post your images in this new thread.
    Post away!
    Note: If we get dead links/red X's, post will be deleted. Let's keep this thread clean!
    Xtreme Addict zlojack's Avatar
    Nov 2007
    Toronto, Canada
    0
    Here are my shots of my first ever LC rig. Now working on the second (3-loop H2GO, will post pics when done )
    RIG 1 (in progress):
    Core i7 920 @ 3GHz 1.17v (WIP) / EVGA X58 Classified 3X SLI / Crucial D9JNL 3x2GB @ 1430 7-7-7-20 1T 1.65v
    Corsair HX1000 / EVGA GTX 295 SLI / X-FI Titanium FATAL1TY Pro / Samsung SyncMaster 245b 24" / MM H2GO
    2x X25-M 80GB (RAID0) + Caviar 500 GB / Windows 7 Ultimate x64 RC1 Build 7100
    RIG 2:
    E4500 @ 3.0 / Asus P5Q / 4x1 GB DDR2-667
    CoolerMaster Extreme Power / BFG 9800 GT OC / LG 22"
    Antec Ninehundred / Onboard Sound / TRUE / Vista 32
    Xtreme Addict coolmiester's Avatar
    Sep 2006
    North East UK
    2
    System Spec:
    CM Cosmos S
    CM Ultimate PSU
    Intel Skulltrail Motherboard
    2x Intel QX9775 Quad Core
    2x Zotac 9800GX2’s
    4GM RAM
    Watercooling:
    By me
    Registered User WhiskeyAlpha's Avatar
    Oct 2007
    0
    Intel Q6600 'G0' - 3.6Ghz @ 1.45V .::. ASUS P5K Premium .::. 4GB G.Skill DDR2 PC2-8000 PQ (5-5-5-15) @ 2.1V .::. POV 8800GTX @ 702/1728/1107Mhz .::. Corsair HX 620W .::. 750GB Storage .::. Dell 2007WFP .::. XP pro (x86) / Vista Business (x64) dual boot
    .::. Mountain Mods U2-UFO .::. ThermoChill PA120.3 & PA120.2 .::. D-Tek FuZion .::. EK-FC8800 GTX .::. Alphacool Repack Bay Res(x2) .::. Laing DDC(x2) .::. 1/2" Tygon .::. Feser One Coolant
    Xτræmε ÇruñcheΓ AndrewZorn's Avatar
    Jul 2005
    Molvanîa
    0
    I'm finally somewhat confident about wire management... but disappointed how boring liquid cooling can look with only one of everything...
    Rocketfish Lian-Li
    Top-Mounted MCR320, Apogee XT, MCP655, Bitspower Water Tank Z, two Bitspower angle fittings
    Distilled water, coiled silver strip, Primochill Pro LRT tubing (3/4" OD)
    OLD:
    http://farm5.static.flickr.com/4045/...d6fd37e2_o.jpg
    OLDER:
    http://img123.imageshack.us/img123/5832/p1010228nh1.jpg
    http://img123.imageshack.us/img123/6582/p1010234bb2.jpg
    http://img523.imageshack.us/img523/7769/p1010236ar6.jpg
    http://img523.imageshack.us/img523/4908/p1010244ti9.jpg
    i7 2700k 4.60ghz -- Z68XP-UD4 F6F -- Ripjaws 2x4gb 1600mhz -- 560 Ti 448 stock!? -- Liquid Cooling Apogee XT -- Claro+ ATH-M50s -- U2711 2560x1440
    Majestouch 87 Blue -- Choc Mini Brown -- Poker Red -- MX11900 -- G9
    Xtreme Addict BlueAqua's Avatar
    Aug 2004
    Minneapolis, MN
    6
    More Pictures in my worklog.
    Registered User Snowfortrick's Avatar
    Nov 2007
    Italy
    0
    Xtreme Enthusiast Dangals's Avatar
    Sep 2007
    Sydney - Australia
    2
    Cosmos S build I did for my partner - specs in sig
    http://i37.photobucket.com/albums/e60/Dangals/good4.jpg
    Dec 2007
    0
    Cosmos
    Here is my original coolermaster cosmos water cooled
    I like turtles
    Registered User matt100's Avatar
    Feb 2006
    chilledpc HQ
    0
    Ok, potted history of my work!
    First watercooled pc back in 2004 I think
    Quickly decided I could get 2 loops in a PC65 and got a bit of a reputation for pulling off small, complicated internal watercooling systems
    http://i20.photobucket.com/albums/b2...r/DSC00063.jpg
    http://i20.photobucket.com/albums/b2...r/db6a6f28.jpg
    Then went after something a bit more extreme and went for phase
    and then smung back completely the other way and went chasing watercooled SFF cases
    Thats almost everything inside an aspire XQpack, CPU, and GPU
    Then tried a bit harder, CPU, NB and GFX in a Shuttle SN25P
    Then I got into heavier case modding, got a black PC7 and had the insides anodised black and fitted 2 loops fully internal..
    well, almost all inside, all except the bling!!
    And now up to date, decided I wanted something bigger with PA120.3 rads, rescued a half knackered PC75 and conspired along with ChilledPC.co.uk to turn it into this!!
    with matching Xbox!!
    Just negotiating a 2nd hand TJ07.. lets see where that ends up!!
    www.chilledpc.co.uk the UK's NUMBER ONE watercooling site!
    Sep 2006
    North East UK
    2
    System Spec:
    Tyan Tiger K8WE S2877ANRF
    2x AMD Opteron 265 dual core SKT 940 Retail (1.8Ghz-0.9nm-2Mb)
    4x 512GB OCZ 3200 EL DDR ECC Reg / Dual Channel
    Gainwards 8800GTX Ultra Golden Sample
    Antec 850 True Power Quattro PSU
    2x 74GB Raptors
    Watercooling:
    2x Danger Den TDX A64 Blocks
    Danger Den NV8800 Block
    Danger Den Hard Drive Block
    Laing DDC 10watt - Alphacool Dual Plexi Res
    HWLabs Custom Made GTX X-Flow
    2x Yate Loon D12SL-12
    Tygon Hose
    Fesser One Liquid
    Sep 2006
    North East UK
    2
    Quote Originally Posted by AndrewZorn View Post
    Coolmiester, you really like that keyboard/mouse combo... I used to have one!
    Ah, how could anyone from that era forget that combo
    Yeah, not the best watercooling from Coolermaster but it was one of my favourite cases of all time even though it only came second but i have fond memories
    And this is a real blast from the past but hey, i'm still pretty proud
    Man i devoted 10 years of my life just about to this stuff & it beats all this easy option laser cutting and powder coating hands down imo
    Xtreme Member johnp1983's Avatar
    Sep 2007
    Italy, Naples
    0
    Xtreme Member ShArKo's Avatar
    Feb 2008
    Buenos Aires - Argentina
    1
    Images Gallery with PicTiger
    Upload Picture with PicTiger
    He is my PC, but right now is disarm in my workshop.........
    Need to put the rad in other place because I can't get out the PSU.......
    Any ideas????
    Intel C2D E8400 @ 4Ghz // Asus Maximus Formula x38 @ FSB 500Mhz// G.Skill Pi 2x2GB 1000Mhz // 9800GTX+ SSC eVGA // WD Raptor X 150GB + Samsung Spinpoint 2TB // DVD-RW DL Asus // Powercooler 850W // CM Cosmos S // Samsung T260N / Edifier R251 // Logitech G9 // Logitech G15 Rev2
    Cooling System: Swiftech Apex Ultra H2O Kit + MCW60
    Feb 2008
    Poland
    0
    MAINBOARD - DFI LanParty LT X38-T2R
    CPU - Intel Core2 Extreme CPU X9770 @ 4250.2 MHz (Xisio P180 Watercooling Project)
    RAM - 2Gb - OCZ 1280Mhz (OCZ2FX12001G)
    HDD - 2x SSD Samsung 64Gb + 4Tb NAS
    VIDEO - BFG Geforce 8800GTX
    MONITOR - Dell 2408WFP
    OLD
    3DMark Vantage - 7342 pkt. screen
    Registered User BooStFeD's Avatar
    Jul 2006
    Maryland - US
    0
    Cooler Master Stacker 810 WATERCOOLED
    Black Ice GTX 360 // Danger Den TDX CPU WB //
    Maze 4 GPU WB // D5 Pump // SwifTech Micro Res.
    ASUS P5B DELUXE // E8400 @ 4410MHz 490*9 1.41v
    2x2GB MUSHKIN ASCENT DDR2 1066
    SAPPHIRE OC HD5970 2Gb @ 900-1150
    Corsair HX1000w // SB Audigy 4
  18. #18
    Registered User HisShadow_'s Avatar
    Aug 2008
    in the shadows...
    0
    Exclamation hisshadow ownz ... :P
    The BlackBox~
    Asus Crosshair (Bios1207) /
    PhenomX4 9850 BlackEdition@3.0Ghz [OC=200x15@1.44V] +
    Custom Water Cooling:
    D-TEK FuZion v2 /
    2 X D-Tek FuZion V2 GPU Blocks /
    Swiftech Ramsinks /
    Swiftech MCP655 Pump w/Speed Controller /
    Swiftech MCR320-QP Quiet Power Radiator 3X120mm /
    Swiftech MCRES-MICRO Reservoir /
    D-Tek High Flow Fittings 1/2in ID Hose Barb (cpu block,radiator,reservoir) /
    FeserOne Feser Tube UV Blue 1/2IN ID 3/4IN OD Tubing /
    Breeze Miniature Hose Clamps 7/16in. to 25/32in. /
    Coolant: 100% Distilled Water(650ml) /
    TIM: Arctic Cooling MX-2 Thermal Paste /
    Temps: idle@22C / load@40-50C
    OCZ ReaperX HBC/EBE PC2-6400 DDR2 4GB(2x2GB) 800MHz~ 4-4-3-15@2.1V /
    2x BFG GeForce 8800GT-OC in SLI /
    Seagate Barracuda 250GB SATA2 + Western Digital 250GB MyBook USB Drive /
    Tagan BZ-800Watt Modular PSU /
    Antec1200 Case +11x120mm 1x200mm Case Fans /
    Windows Vista Ultimate 64bit (Perfect 5.9 Vista Score) /
    Dual Display (dvi to hdmi)@1080P~ 42"SHARP Aquos LCD HDTV + 32"SONY Bravia LCD HDTV
    Benchmarks: 3DMarkVantage: P10946 / 3DMark06: 12724 (no oc)
    Some cpu-z validations for those interested ->
    and now the shiny p0rn ... enjoy ... (theres lots i know and i dont think i care :p)
    http://www.hisshadow.com/BlackBox/Showcase/5.jpg
    http://www.hisshadow.com/BlackBox/Showcase/6.jpg
    http://www.hisshadow.com/BlackBox/Showcase/7.jpg
    http://www.hisshadow.com/BlackBox/Showcase/8.jpg
    http://www.hisshadow.com/BlackBox/Showcase/9.jpg
    http://www.hisshadow.com/BlackBox/Showcase/10.jpg
    http://www.hisshadow.com/BlackBox/Showcase/11.jpg
    http://www.hisshadow.com/BlackBox/Showcase/12.jpg
    http://www.hisshadow.com/BlackBox/Showcase/13.jpg
    http://www.hisshadow.com/BlackBox/Showcase/14.jpg
    http://www.hisshadow.com/BlackBox/Showcase/15.jpg
    http://www.hisshadow.com/BlackBox/Showcase/16.jpg
    http://www.hisshadow.com/BlackBox/Showcase/17.jpg
    http://www.hisshadow.com/BlackBox/Showcase/18.jpg
    http://www.hisshadow.com/BlackBox/Showcase/19.jpg
    http://www.hisshadow.com/BlackBox/Showcase/20.jpg
    http://www.hisshadow.com/BlackBox/Showcase/21.jpg
    http://www.hisshadow.com/BlackBox/Showcase/22.jpg
    http://www.hisshadow.com/BlackBox/Showcase/23.jpg
    http://www.hisshadow.com/BlackBox/Showcase/24.jpg
    http://www.hisshadow.com/BlackBox/Showcase/25.jpg
    http://www.hisshadow.com/BlackBox/Showcase/26.jpg
    http://www.hisshadow.com/BlackBox/Showcase/27.jpg
    http://www.hisshadow.com/BlackBox/Showcase/28.jpg
    http://www.hisshadow.com/BlackBox/Showcase/100.jpg
    http://www.hisshadow.com/BlackBox/Showcase/105.jpg
    http://www.hisshadow.com/BlackBox/Showcase/109.jpg
    http://www.hisshadow.com/BlackBox/Showcase/110.jpg
    http://www.hisshadow.com/BlackBox/Showcase/111.jpg
    even more to come soon....
    Maximo~ Intel C2Q Q6600(G0)@3.5Ghz@1.376V / Asus MaximusFormula / OCZ ReaperX 4GB 800Mhz 1:1~4-4-3-15 2T@2.1V / EVGA GTX280 FTW@710/1545/1215 / PhysX: BFG 8800GToc / Seagate250GB / Tagan BZ-800Watt ModularPSU / Antec1200case+11x120&1x200case fans / VistaUltimate64bit / DualDisplay@1080P~ 42"SHARP Aquos+32" SONY Bravia
    WaterCooling~ D-tek FuZionV2 CPU / 2x D-tek FuZionV2 GPU +Uni-Sink+RamSinks / MCP-655/ MCR-320 / MicroRes / FeserTube uvBlue 1/2"id 3/8"od / 100%Distilled Water(725ml) / TIM:MX-2
    3DMark Vantage - P14215
  19. #19
    Xtreme Member zuess's Avatar
    Aug 2007
    Ontario,Canada
    0
    Since I enjoy looking at everyone's rigs so much, here's a case I made.
    You can see more in my buildlog.
  20. #20
    Xtreme Member MorGo7h's Avatar
    Sep 2007
    Belgium
    0
    System: E8400 // P5Q-E // Ballistix // HD3850 // HX520 http://valid.x86-secret.com/show_oc.php?id=419486
    Thermochill pa120.3 // D-tek FuZion bowed+ costum nozzle // MCW60 // EK150 // dcc1 18w w/top
  21. #21
    Xtreme Member Gir92's Avatar
    Apr 2008
    0
    Swapped out the crappy 780i in favor of a Asus P5Q-E P45. The 780i couldn't even boot with my Q6600 G0 at anything above 3.65, but right now I'm sitting happily at 3.81Ghz fully stable. The P45 chipset is a LOT cooler than the 780i as well.
  22. #22
    Xtreme Member mpower1001's Avatar
    Mar 2008
    Boston, Ma
    0
    • Case : Silverstone TJ07 Black
    • Sound : Asus Xonar Essence STX
    • Video : XFX 6950 Modded to 6970
    • Board : ASUS Maximus V Formula Z77
    • CPU : Core i5-3570K @ 4.5 Ghz
    • CPU Cooler : EK-Supreme HF w/Plexi Top
    • Memory : 16GB Samsung 2133mhz 10-9-10-29
    • PSU: Enermax Revolution 85+ 1050w
    • HDD : Crucial 250gb M4 SSD
    • Radiator : Thermochill PA 120.3
    • Reservoir : EK-Multioption Res 250 Rev.2
    • Water Pump : Laing DDC-3.2 w/XSPC Top
  23. #23
    Sep 2006
    Chicago, IL
    0
    Motherboard: Asus Maximus II Formula
    CPU: Q6600
    Memory: 2x2Gb G.Skill 1066
    Graphics: Sapphire HD 5850
    Power Supply: Corsair 620HX
    Audio: Auzentech X-Fi Prelude
    W/ Sennheiser HD 555 & Klipsch ProMedia 2.1
    Display: Asus VW266H
    Cooling: Apogee XT, EK FC-5850, MCP-655, TFC 360, EK Res
  24. #24
    Registered User PilatuS's Avatar
    Oct 2006
    The Netherlands
    0
    Haven't posted my PC for quite a while, so here it is again
    Specs: Intel Core i7 950 @ 4.2GHz with EK Supreme waterblock. Sapphire HD7970 @ 1125/1575 with EK waterblock. ASUS Sabertooth X58. 3x 2GB OCZ Reaper @ 1600MHz. 128GB Crucial M4. 2x 2TB WD Green. Corsair AX750. XSPC RX480 Radiator. Laing DCC-1T pump. 4x Scythe Gentle Typhoon 120mm @ 6 volt. 4x Sharkoon Silent Eagle 80mm @ 6 volt. Modified Lian-Li PC-71.
  25. #25
    Xtreme Member ThatGuy16's Avatar
    Oct 2007
    0
    3DMark06: 20974
+ Reply to Thread
Tags for this Thread
