First review : http://www.swemod.com/swemod/index.php?do=review&id=37
Intel E6500@3,3GHz, Asus P5K Premium Black Pearl 18th Anniversary Edition, Geil 2x1GB & OCZ Titanium 2x1GB XTC 4-4-4-12 800MHz, Asus ENGTX560 DCII OC/2DI/1GD5, Kingston SSDNow HyperX 3K-SH103S3/120G+WD Scorpio Black 750GB, Corsair HX520W, Samsung 961BF, noname open case, MGE UPS PC500, Win7+SP1 Ultimate x64 lite, Sony P200
That thing is seriously hideous. It's amazing how a small design change can take something from "meh, not bad" to "KILL IT".
Give me a 900 with cable management, black interior and no freaking LEDs and I'll buy it.
Another review : http://www.pcshoptalk.com/forum/show...#content_start
i thought it looked nice, but it does look pretty nasty sidewindow..mod it with the force
PTS,NCIX,PPCS *recommended*
- "Illusive Perceptions" - July-August 08 -
DFI LanParty UT->SLI
X2-3800 LCBIE 0618EPMW / AS5 / IHS Removed
EVGA 8600GTS SLi ! w/ FuZion GFX rev2
OCZ PlAtREV2. 2GB TCCD's | X-FI XTREME-FATALITY
CM 600W DUO | DD WaterWOODbox MODDED
UV1/2"LRT tubing.TDX Lapped.BIP120.2,yateLoons,
ddc.2+petras top, dd dfi nb block , dual uv
Quick update as i recieved mine yesterday..
Definately an ugrade from a 900, it has all the holes needed for cable management, including at the top of the case for the 8pin atx power. And i really like the removable dust filters as it was a pain unscrewing all the screws on the front grills to change the old ones.
I had to rip the front and rear fans out as they are hard wired into the switches on the front and rear, so no way of fully removing the little knobs on the front but other than that, im happy!
Will get some pictures up soon!
Ok, heres some pics of where mine is at, still got a little bit of cable tidying to do but other than that its all done.. for now!
Case Antec 902 with Scythe Kama 120mm LED fans
PSU Zalman ZM750HP
CPU Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz
CPU cooler TRUE 120 Black + Scythe Kama 120mm LED fan
Motherboard Asus Maximus II Formula
RAM 4gb Corsair Dominator 8500C5D CL5-5-5-15-2T
Graphics Sapphire Radeon HD 4870 1GB GDDR5
Nice work looks good
~ Little Slice of Heaven ~
Lian Li PC-A05NB w/ Gentle Typhoons
Core i7 860 @ 3gHz w/ Thor's Hammer
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
OZC Vertex3 SSD 240GB
Looks very clean
Armor.exe worklog
Mobo: Asus Rampage 2 Extreme X58
CPU: i7 920
GPU: ATi HD 4870x2
Sound: Auzentech X-Fi Forte 7.1
PSU : Corsair HX1000
RAM: OCZ 3 x 2GB tri channel DDR3-1600
HDD: WD 640 Black RAID 0 + 1
Watercooled
I was very disappointed when I had the original 900 and it looks like this is only slightly better.
It looks like it still has the pita drive cages. Do you have to pull the cage out to remove the filter too? From the pic in that review it kind of looks like it.
The PSU still has to mount upside down and get air from inside the case instead of from outside like other cases.
I think it is uglier on the outside, the all black inside is very nice though.
Why is the rear fan exhausting while the fan on the TRUE is intaking from the rear? Also where did you get the LED Scythe fan?
Canon 5D Mark II (Canon 50mm f/1.2L | Canon 135mm f/2L | Canon 24-70mm f/2.8L | Contax Zeiss 85mm f/1.4 | Zuiko 21mm f/3.5 | Crumpler 7MDH | Hitech filters + Lee Foundation Kit | B+W filters)
Hasselblad 201F (Zeiss 80mm f/2.8 CF | 2x A12 Back | Domke F-4AF)
Nikon F3HP (Nikkor 50mm f/1.2 | Nikkor 55mm f/1.2)
Images: Flickr
Mobo: ASUS Rampage Formula X48
CPU: Q6600 @ 3.65ghz 1.472v 406x9
RAM: 8GB G.Skill DDR2-1000PQ @ DDR2-1066
Graphics: 2x Visiontek HD4870 512MB 811mhz core 1125mhz mem (4500mhz effective)
Storage: 160GB 2.5 Fujitsu boot, 160GB Seagate & 160GB Western Digital storage
Optical: Sony NEC Optiarc SATA
Sound: Asus Xonar DX
Headphones: Sennheiser HD280Pro w/tack mod
PSU: Corsair TX750
Case: Antec P180B (P182 rev)
Yep, to remove the dust filters you do need to pull the cages out a little bit.
And yes, i mistakenly put the cpu fan on the wrong way round, i will change it but its a real pain in the butt trying to get the clips over the fan when its all fitted to the mobo, i will leave it for when my patience levels are high!
I got the fans from Komponentcentre.com based in sweden..
PSU Zalman ZM750HP
@DizzleDazzle very beautiful case and your LED fans. Can you give us any picture your cable managment both side?
No probs, ill take some extra photos tonight!
PSU Zalman ZM750HP
PSU: Corsair TX750
You will have to remove both side panels and 4 screws to remove a filter? Antec needs to take a look at the coolermaster 690 before they design any more cases.
Yep, i guess they could have designed that better but its not like you need to do it everyday, or even every week, so i can live with it.
As promised here are some pics of the cable management, im still not so happy with it, i really want it to be "perfect" all thanks to some of the builds on here!
I really want to reverse mount the hard drives as that would eliminate alot of the mess at the bottom.
And finally, i have mounted my cpu fan the correct way around!
PSU Zalman ZM750HP
Thanks man, i find myself just staring at it sometimes (alot of the time) although looking at the pic of the cable management inside the case, its still not "right", i really need to tidy it up some more!
Edit.
I really want to reverse mount the HDDs, is it the same process as the 900? does anyone know of a decent how 2 anywhere? i have seen the antec 900 thread but it doesnt go into detail in exactly what you need to do to do this..
PSU Zalman ZM750HP
I think the original is better in the looks department. The new holes are nice.
This is why i moved away from the Ante cases. I found their depth very limited with the HDD bays they need to use the side mounted bay drives to eliminate the cable mess.
But the 900 2 seems to be slightly better than both the 1200 and 900 v1.
Good job on the 900 2 btw, nice clean pics.
2700K+H80 - EVGA GTX680 2GB - GIGABYTE G.1 SNIPER M3 Z77 - CORSAIR F3 120GB SSD - CORSAIR AX-850+MMOD BLUE/BLK - CORSAIR VENGENCE BLUE 1600MHZ -
LIAN LI PC-60FNWX - CORSAIR SP2500S - DELL U2711 - CORSAIR M60 - FILCO MJ2 TKL BROWN
Great case!
Before I had decided to construct my own case, this was one of my options.
The case looks decent enough.
But i think it has been released a bit too late.
It combinds the best bits of the 900 with the 1200.
Though i dont quite like the name.
Should have kept up with the antec gaming names, the 300,900,1000,1200 :P
Anandtech review : http://www.anandtech.com/casecooling...oc.aspx?i=3514
very interesting case
Intel Xeon W3520 4200MHz HT
Foxconn Bloodrage
3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
MSI GTX480 M2D15 850/1700/2000
Samsung F1 1TB
Corsair TX950W
Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
NEC 2690WUXi
Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
*New* CM 690 II Advanced Watercooled
*Coming soon* Stacker 832 Rebirth!
