welcome?
he was on longer then you.
He's a seasonal cruncher like i am.
welcome?
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Well, now he's joined our cause for real, so I'm gonna welcome him all I want, ya hear me
Well the plan is to WCG on the SkullTrail and QX9650 and GPU Fold on them as well (which works well if you tinker a bit).
The Techstation is always morphing. Right now it has a stellar Dualie in there..but who knows? I am looking at the 9800GX2 to add some oomph.
I am afraid I too willl be a GPU only FOlder for a while...gotta use the CPUs for WCG Cancer research
Thanks, I'll be more active now. Folding was the only passion for me for many moons...but I am throwing it all at WCG for the duration.
Yeah there are times when I happen to have a lot of rigs...and times when I don't lol.
I am in the inbetween time right now
20 Logs on the fire for WCG: i7 920@2.8 X3220@3.0 X3220@2.4 E8400@4.05 E6600@2.4
Use vista as OS because it will drasticly reduce the cpu overhead from any gpu2 folding client.
And uhm.. I should have changed that signature already my quad is back on fah ( it done wcg for v0dka to test, he gpu folded on my account for the same time just to find out how a total fah noob would experience the folding experience with the beta client bugs and server issues )
Yep got V64 on the rigs.
Looking at the DFI X48 and a PNY 8800GT for starters.
I'd like to jump in with the 9800X2 but that's a lotta jing. Plus I alread have LC for a GT.
I flashed my DFI X38 with a 2-day old bios today, which officially fixes the bugs with a HD4870X2.
Since you can flash an X38 with X48 bios and vice versa, I'd guess that problem is history on the X48, too.
theres a X38 that fixes it?
I have an X38 :T
ohhhhh i get to use my card now?
Yeah you do
Grab the latest one here, but it worked with 0807 already, which was out a few days ago. That one only had issues with IDE drives, which was fixed in 821.
OC-wise it's ok, I could hold my OC from 0603 without changing anything.
Expect a slight increase from the ST
Got an Xtreme System? Bring it here! <----
You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
Ze gear:[22:53:09] [@Jaco-XS] i'm gonna overclock this damn box!
Main rig: W3520 + 12GB ddr3 + Gigabyte X58A-UD3R rev2.0! + HD7970 + HD6350 DMS59 + HX520 + 2x X25-E 32gig R0 + Bunch of HDDs.
ESXI: Dell C6100 XS23-TY3 Node - 1x L5630 + 24GB ECC REG + Brocade 1020 10GbE
ZFS Server: Supermicro 826E1 + Supermicro X8DAH+-F + 1x L5630 + 24GB ECC REG + 10x 3TB HDDs + Brocade 1020 10GbE
Lappy!: Lenovo Thinkpad W500: T9600 + 8GB + FireGL v5700 + 128GB Samsung 830 + 320GB 2.5" in ze dvd slot + 1920x1200 @ 15.4"
What chips are you talking about???These old things?
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.4ghz @1.32v under load, corsair ddr2 1066 8gigs, evga gtx260 core 216, pc p&c 750W, EK Supreme HF Nickel, iandh 175 res, Swiftech MCP355, Black Ice GTX G2 240, Lian Li v1200b
silverstone tj07 build log
It took me months to get the Areca1210 working right on the Skulltrail. It never occured to me to try the top slot
But I am so happy with the VelociRaptor I decided to use the Areca for Storage instead of Speed. Hard to beat a quick seek time. Sustained read of the HBA is awesome...but the Samsungs are twice as slow on seek.
I'm guessing Crunching is all about seek times once you get up around 100mb/sec...I would be surprised to see a measurable difference in output from 100 mb/sec to 200 mb/sec. But just in case I installed BOINC in a directory on the array I've seen slight increases using a drive sperate from the OS to run SuperPi so I assume that on a daily scale it would also add up in BOINC.
I'd say what HDD you use has 0 influence on ppd generation
All threads are crunched fully in ram, with only one small write operation to the hdd every few minutes (you can even change the write to hdd intervall manually).
Ahhhh. THat makes sense. The QX9650 is producing Curing Cancer results every 2hours 37 minutes and the Skulltrail is taking almost exactly 3 hours. I fault the RAM for the huge difference in output. The E3110 is at 3.0 and it produce a unit every 3 hours 17 minutes. So far running a server for Crunching looks like a handicap despite the dependability factor.
If it were affordable a mess of E8600s would be the fastest Farm Running CAS3 RAM.
Having a fast cpu and gpu without a fast IO
Is like having a big peni@s without 1 of your balls.
