Is this http://www.petrastechshop.com/12evalcafan8.html a good fan for this Rad http://www.performance-pcs.com/catal...oducts_id=4541
Trying to choose a fan that is decorative as well as effective
Coolermaster Cosmos S
BenQ 241w
Asus Chrosshair II
OCZ Reaper HPC Edition 4GB
Gigabyte Oden 1200w psu
AMD Phenom 9950BLK@ 3000
Swiftech MCP355, D-TEK FuZion v2
Tygon B-44-4x,XSPC Dual Bay Res.
SAMSUNG Spinpoint F1 1TB
Radeon HD 4870 X2
Black Ice GT Stealth 360 XFlow
Bada Bing Bada Boom
I guess you already have the radiator?
It shouldn't be a bad fan if the specs are well rated. Maybe google it to see if the CFM is really well rated.
Another option is to get some trusted high CFM fans (you can look at the fans sticky review by Vapor) and paint it yourself with a metallic look
Q6600 G0 L740B126 Lapped, 2x1Gb Kingston HyperX DDR2-1200
Gigabyte 8800 GTS 512Mb OC 756-1890-1000
TT Toughpower 750 W (W0116) new 8xPCI-E Rev.
Western Digital Caviar SE16 WD6400 AAKS rocks
WC: Swiftech H2O-Apex Ultra 220 GT + PA120.3 5v
OCZ XTC RAM Cooler, HR-05 IFX + 80mm FAN (NB), 2x HR-09U type 2 (mosfets), Modded Zalman ZM NB-47J (SB), Arctic-Cooling MX-2
Vista 32 bits
- ASUS P5K Premium bios 0612: (3.84GHz 8x480) @1.432v
- P5B Deluxe: 3.60GHz (9x400) @1.33v *** Old Setup (P5B deluxe)
OCCT 2.x Final Download
aw heck bro... what are you going for?
it seems,
Effective Water Cooling = Yate Loons + MCR320 or Thermochills + Distilled Water + Nuke + Pump & Essentials
anything beyond is bling... right?
so... if you are going for looks, well, you've already gone the "nice lookin" route... nothing wrong... i too go for colors and layouts...
so perhaps you should really be asking...
will _____ rad and _____ fan be able to cool _____ cpu?
and telling some of the folks here what you plan to put in your loop... CPU, NB, SB? Video?
and have fun...
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands in times challenge and controversy."
Dr. Martin Luther King Jr.
DIY: Self Clinching Nuts
Canon EOS 7D | Tokina 12-24mm f/4 | Canon EF 24-105 f/4 L | Canon EF 70-200 f/2.8 L IS Mk II | Canon EF 35mm f/1.4 L | Canon EF 400mm f/5.6 L | Canon EF 100-400mm f/4-5.6 L
Hmm the specs on that fan are a really ambitious. I doubt it has that CFM at that DBA.
I was thinking the same thing. 84 CFM at 31 dBA? I would be VERY suprised if this was accurate.
Yes I all ready have the Rad.
I'll be using all the parts in my sig.
Trying not to jump ship on AMD would like for them to stay around, believe competition is for the consumer. AMD CPU's don't overclock that well so straddling the fence on the whole bling efficiency thing.
Hope that helps you help me
BenQ 241w
Asus Chrosshair II
Radeon HD 4870 X2
Bada Bing Bada Boom
Some people like to say: all you have is crap, you should ditch it and buy this top notch bling bling...
Anyway, for your radiator, you looked right, you need a high CFM fan. The panaflo and sanace are known to be part of the best fans. The S-Flex G series could be great ones too, but no tests I know about. Just all the series from D to F are great.
If you don't care about absolute performance and you don't feel easy to paint yourself a fan, you coul dgo with one of these and give it a try. Even if moves 60CFM only, it should be enough for your setup
Vista 32 bits
BenQ 241w
Asus Chrosshair II
Radeon HD 4870 X2
Bada Bing Bada Boom
Will it help to use a push pull setup. I don't seem to be ale to find any reviews on this Rad so thats the reason for all the ?
BenQ 241w
Asus Chrosshair II
Radeon HD 4870 X2
Bada Bing Bada Boom
Circles SucQ!
Not a great rad but as long as you don't ask it to cool 2 x GPU as well as a O/C CPU it should be OK with most 70 to 88 CFM fans around.
