... or in english: Shipwrecked Lian Li
Hi everyone
I will start a new project which will be run quietly because i want to make this special and i also have other things that make me busy at this moment. Btw, this is my first project here at XS forums!
Let me tell you what i'm planning to do:
Fit these two cases together and build an aquarium inside that will occupy the space as big as possible.
Take advantage on the heat produced by the components and direct it to the bottom of the aquarium through a liquid heating the water to a perfect temperature for red belly piranhas. I will use the watercooling system for this!
I haven't done all the calculations yet but if a regular watercooling system isn't enough i already have a by-pass project thought.
Sponsors
OverVoltage
Lian Li
Feser One
Magicool
Scalare
BioAquaria
I have to be thankful to all that make this project completely viable!
Entertain yourself with some infrastructure photos while i'm working on the mesurements and markings in the cases:
Wish me good luck!
