How r the 27A week CPUs. I have one, n will be benching soonnn .
Sound: Asus Essense ST | Wharfedale Diamond 9.1 | Norge 2060 Stereo amp | Wharfedale SW150 sub (coming soon)
Camera Gear: Canon 6D | Canon 500D | Canon 17-40L | Canon 24-105L | Canon 50mm f1.4 | Canon 85mm f1.8 | Rokinon 14mm f2.8 | Sigma 10-20EX HSM | Benro A3580F + Vanguard SBH250 | Bag full of filters and stuff
Intel Core 2 Duo E6400 ( Best personal 1M spi : 14.562s )
Gigabyte GA-P35-DS3P F5
OCZ Vindicator with 120MM Fan
2 x 1024MB Crucial Ballistix PC8500
2 x 512MB Transcend PC5300 /w D9GMH @ 651Mhz
2 x 512MB Corsair PC6400C5 /w Promos @ 567Mhz
Nvidia GeForce 7600GT 256MB GDDR3
Corsair HX 520W
All stock voltages exept for ram which needed 1.9v
If I go anything higher it gives errors on orthos...
Week 27 CPU
I might try some more but I have bad IHS. Im using AF7PRO and temps on cores are 50C stressed at dual prime @3ghz... I've seen much better temps
I've already tried some more but I want to stay close to stock as much as possible. 3.2ghz didnt want to boot OS, no clue why.
my 6400
Zalman 7700 cu + P5B Deluxe
Nice clocks n Results guys..
My gay motherboard (asus p5n32sli se deluxe) stopped at 300mhz fsb... nothing will get it higher I got 24 seconds 1M!!! WOO HOO! Just an hour ago, my board decided to break down further, and I'm stuck with stock speeds...
Lenovo Thinkpad X220 - Core i5 2410m, 4gb
waiting on 28nm video cards...
My E6400 is bad. L628A. I ran 1M at 3704 with 1.5v vcore in BIOS (P5B Deluxe) with Mini Typhoon air cooler and lapped IHS. I didn't really gain anything with the IHS lapping and higher vcore doesn't help OCing. I tried with 6x multi and my board stops at 500MHz FSB.
You don't even need 3800 Mhz to get sub 15s SuperPi 1M 3735 Mhz on E6400 is enoughOriginally Posted by The_Hardstylez
Platform:
I'm by no means the ultimate Pi tweaker, but:E6400 630A448 @ 1.59V
Thermaltake Sonic Tower
Asus P5B Deluxe Wifi-AP unmodded
2x1 Gb Corsair 6400C3 @ 2.45 Vdimm
8800GTX
PCP&C 850W
The key here is to stay on 1066 strap ( = boot @ 400fsb and clockgen up - this offsets at least 100 mhz of raw cpu speed). And the other Pi tweaks, like closing explorer, and so on.
My cpu can do 1M at least to 3850 Mhz on air, and mem is capable almost on DDR2-1200 4-4-4-8, so it is clear the board is crapping out in my case here... so more Vmch (remember, here the board is unmodded) would probably bring me some more Pi goodness for sure
away & gone
You sure it wonh't go any higher? What's your temp?Originally Posted by aasmaukr
P5B Deluxe Wifi | E6400 L629B (4GHz@water) | Corsiar Twinx 8500 | 7900GT 520M | 2,1TB HDD | [Homemade watercooling] [Overklokk built SS Phase Change]
Core 2 Duo 4GHz Club!
Yup.. I'm pretty sure that's where it stops. I tried a couple different BIOSes and played a bit with voltages and mem timings. Btw, my mem does 525MHz 1M with 4-4-4-10 timings and 2,45v (in BIOS) so that's not what's stopping me.
I'll test with another P5B-Dlx and I'll also see how it likes better cooling (SS).
Thanks for the tip mrlobber I got my new board today ( p5b dlx).
I'am gonna try it.
Corsair HX 520W
has anybody had much luck oc the e6400 L630A?
mine seems to be maxing out at 3.2ghz with 1.525v. the fsb doesnt want to go over 400.
E6400 @ 3.2Ghz L630A 1.5v - GSkill HZ 0606 5-5-5-12 1000Mhz 2.13v -
P5B Deluxe - TuniqTower - XFi Music - Armour Case
Sub 15 with a E6300 is possible .....
...if you got a desent mobo and ram,no mods only watercooled
L627A B2
Sub Zero Lives
I get 16 seconds over here at 3.62/3/4/5GHz
4.1ghz super pi.Supertalent ddr2 800@1026 5-5-5-18,P5B-DELUXE,scythe infinity,.....I need some micron d9, to go higher .Windows xp pro sp2, with no tweaks.
My old E6400, just had the CPU a few days and at that time i didn't know that "better" timings are slower on P5B..
Primestable 3600MHz 1,43V.
PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
And here is my:
http://images.people.overclockers.ru/107441.jpg
14.515sec
E6400 L630A406 B2 @ 4043MHz 1.7v under chiller +13 | Full unmoded Asus P5B Dlx | Geil PC8500 Plus @ 1011MHz 4-4-4-12 2.45v
So is it good? I think that I should have highes score...
You need some tweaks (both hardware and software), guys .
I have sub-14s @ 4117MHz, with everything I know (and I'm not an ultimate Pi tweaker, believe me ) tweaked properly, so 4+GHz and ~14,5s is not the best reachable , keep tweaking and trying .
http://img482.imageshack.us/img482/8131/spi1vo3.jpg - this is on the previous page of this topic also.
JMKS look at mi timings its 5-5-5-18.When i get ram to go 4-4-4-8@1000+ im going to score sub 14s.
Krompirusa, tighter timings don't add up (that) much on C2D.
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
tiborrr is right....there's no chance you will be able to shave THAT much off the times with 4-4-4-x....even if you had a 975x board and 3-3-3-x i don't think you'd be able to do sub-14 relative to your current times..........it is possible as the polish guy showed but you need to work on tweaking more too + get a 2GB kit of RAM...that will help in times tooOriginally Posted by krompirusa
JMKS As for my result: IMHO you aren`t right... You have +1Gb Ram /+75MHz CPU /15MHz Ram freq = I think it could made 0.5sec.
I need to take a screenshot when I do SPi runs, I was just doing them for stability testing and broke into 13.8x with 4200MHz. System isn't stable after 4200MHz which is weird, I can bench 3D at 4200 and I can do 32M at 4200 but 4208 causes a crash, I think that might be the limit of my chip and/or memory. I wish I knew more tweaks for SPi, wish one of the masters would tell us everything
