**Need advice on Watercooling my Lian Li V2100B* Similar to Vadim Gaming PC's!!**
I am planning on watercooling my Lian Li V2100B. I will be watercooling an Intel Core i7 930, EVGA X58 Classified MOBO, and 2 or maybe 3 GTX480's. I will have 3 radiators all in one loop for this setup. I'll have a 480mm Magicool Radiator, a 240mm radiator, and a Single 120mm XSPC radiator. The reason I am going with Magicool is because they will fit in the lower section of the case where there is limited space. Here is a picture of the case I found on the internet...
http://img180.imageshack.us/img180/3489/20050328li5.jpg
And here is how I want it to look like eventually.. First the exterior...
http://img687.imageshack.us/img687/2...4timg3009t.jpg
Now here is a very rough estimate of how I want the interior to look like...
http://img707.imageshack.us/img707/5...iimg2915ii.jpg
Here is how the tubing and fittings (I want to go with Koolance but will stick with bitspower) will look like (ignore the excessive radiator setup)
http://img526.imageshack.us/img526/6454/03005.jpg
And the GPU setup when the GTX 480 DD waterblocks come out...
http://img180.imageshack.us/img180/289/03006.jpg
NOTE I am not sure whether to go with PrimoChill Clear Coils or should I go with Pearls?
Anyways, I was wondering where I should get my side panels cut. I need them to look exactly like how it looks above. Has anyone worked with Performance-PCs before? They offer custom modding services as well and was wondering if it's ok to go with them. Lastly, are they any good at sleeving PSU cables? I am spending 100 dollars having my enermax 1050W PSU sleeved by them and was wondering how they would come out.
The water travels in this order: ****Look at my latest posts, my setup has changed a bit****
Reservoir > Pump > 120.4 Radiator > 120.2 Radiator > CPU block > northbridge block > 120.1 Radiator > VGA waterblocks > returns to the reservoir.
Going with two separate loops reduces the flow rate of my CPU loop considerably. This is why I am going with a single loop not to mention it is less messy.
Anyone have any idea whether the GOLD from the CPU block my deteriorate over time?
NOTE, This is my FIRST time watercooling. I know this is a bit ambitious but if your gonna go watercooling, you might as well go 100%.
